fatcode
Joined: Apr 03, 2004 Posts: 19596 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Fri Jan 04, 2013 2:04 pm Post subject:
fatcode
Not sure what you mean ... opened the patch here and the rnd and clr buttons on CtrlSeq1 work just fine here, even when I have no connection between editor and synth.
I'm not aware of any setting that could be wrong to prevent this from working ...
And when I opened the patch first time here the sequencer had some pattern - not a straight line ...
This was on a PC of course  _________________ Jan |
fatcode
Posted: Fri Jan 04, 2013 2:18 pm Post subject:
Hi, thanks for trying - I don't have a PC at hand so I cannot try.
I'm wondering is it's a bug on the editor - hopefully someone with a mac will try it |
Audio files: 116
G2 patch files: 317
Posted: Fri Jan 04, 2013 2:28 pm Post subject:
I have a Mac, but dont have the NM Classic software installed on it ... and it seemed a bit messy to do so ... if not I could give it a try, although I don't have it set up for MIDI. _________________ Jan |
fatcode
Posted: Fri Jan 04, 2013 2:38 pm Post subject:
I use rosetta to run the Clavia editor on Snow Leopard - very easy to set up with the midisport
I've opened the patch with nomad and in Nomad there is no rnd buton at all ! |
Audio files: 116
G2 patch files: 317
Posted: Fri Jan 04, 2013 3:36 pm Post subject:
Hmm, seems not possible on 10.5 ... _________________ Jan |
varice
Joined: Dec 29, 2004 Posts: 626 Location: Northeastern shore of Toledo Bend
G2 patch files: 46
Posted: Fri Jan 04, 2013 5:28 pm Post subject:
| Blue Hell wrote: | | ...Not sure what you mean ... opened the patch here and the rnd and clr buttons on CtrlSeq1 work just fine here, even when I have no connection between editor and synth... |
Hmm, that seems odd to me. The random and clear functions should occur in the DSP code on the hardware, not in the Editor. I don't have a G1 setup (or even a Mac) to test that, but I can verify that the PC G2 Editor does *not* randomize or clear the sequencer without the synth connected. _________________ varice |
fatcode
Posted: Fri Jan 04, 2013 5:38 pm Post subject:
I gave it a go on my girlfriend's PC laptop and everything seems to work ok- hmmm must be the beta editor
Anyone using the OS X editor on Snow Leopard out there that can help ? |
Audio files: 116
G2 patch files: 317
Posted: Fri Jan 04, 2013 6:15 pm Post subject:
| varice wrote: | | I can verify that the PC G2 Editor does *not* randomize or clear the sequencer without the synth connected. |
, it does here tho, how weird
Anyway .. fatcode, does the "Synth" menu work for you on the Mac?
that one will work here only when the NM is connected. _________________ Jan |
varice
G2 patch files: 46
Posted: Fri Jan 04, 2013 8:10 pm Post subject:
| fatcode wrote: | | I gave it a go on my girlfriend's PC laptop and everything seems to work ok- hmmm must be the beta editor. |
I see that you found an old post about this:
http://electro-music.com/forum/topic-20027.html
So, it looks like it is a bug with the beta G1 Editor.
I’m curious though. The PC G1 Editor can do these functions without the synth connected (while the G2 Editor cannot). But, can you assign the rnd and clr buttons to front panel knobs and trigger these functions without the G1 Editor connected to the synth? _________________ varice |
Audio files: 116
G2 patch files: 317
Posted: Sat Jan 05, 2013 4:09 am Post subject:
why did I not read that yesterday ... sorry for the confusion. _________________ Jan |
fatcode
Posted: Sat Jan 05, 2013 6:11 am Post subject:
I connected the modular via PC on Virtual box - seems to be working ok there (it might be a way to use the G1 under Lion )
Well, it must be a bug in the OS X editor
I'll try to find out if I can get the rnd seq working with a knob |
