rnd in sequencer not working ! Help !
Page 1 of 1 [12 Posts]
fatcode
PostPosted: Fri Jan 04, 2013 1:41 pm    Post subject: rnd in sequencer not working ! Help ! Reply with quote  Mark this post and the followings unread
Hi, getting back on the G1 after some time. Forgot after many year how great this machine is.
I'm trying to get the CtrlSeq1 module to generate a random sequence in the patch below but I just get a straight line - I'm I missing something ?
I click the rnd button but nothing the sequence is a straight line
Also Clr does not restore values at 0.... what's going on ? Did I miss some setting ?
I'm on mac under snow leopard using the beta editor for OSX
Patch 12a.pch
 Filename:  Patch 12a.pch
 Filesize:  1.29 KB
 Downloaded:  18 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Fri Jan 04, 2013 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome fatcode
Not sure what you mean ... opened the patch here and the rnd and clr buttons on CtrlSeq1 work just fine here, even when I have no connection between editor and synth.
I'm not aware of any setting that could be wrong to prevent this from working ...
And when I opened the patch first time here the sequencer had some pattern - not a straight line ...
This was on a PC of course Confused
fatcode
PostPosted: Fri Jan 04, 2013 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, thanks for trying - I don't have a PC at hand so I cannot try.
I'm wondering is it's a bug on the editor - hopefully someone with a mac will try it
Audio files: 116
G2 patch files: 317
PostPosted: Fri Jan 04, 2013 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a Mac, but dont have the NM Classic software installed on it ... and it seemed a bit messy to do so ... if not I could give it a try, although I don't have it set up for MIDI.
fatcode
PostPosted: Fri Jan 04, 2013 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use rosetta to run the Clavia editor on Snow Leopard - very easy to set up with the midisport
I've opened the patch with nomad and in Nomad there is no rnd buton at all !
Audio files: 116
G2 patch files: 317
PostPosted: Fri Jan 04, 2013 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, seems not possible on 10.5 ...
varice
G2 patch files: 46
PostPosted: Fri Jan 04, 2013 5:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
...Not sure what you mean ... opened the patch here and the rnd and clr buttons on CtrlSeq1 work just fine here, even when I have no connection between editor and synth...
Hmm, that seems odd to me. The random and clear functions should occur in the DSP code on the hardware, not in the Editor. I don't have a G1 setup (or even a Mac) to test that, but I can verify that the PC G2 Editor does *not* randomize or clear the sequencer without the synth connected.
varice
fatcode
PostPosted: Fri Jan 04, 2013 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I gave it a go on my girlfriend's PC laptop and everything seems to work ok- hmmm must be the beta editor
Anyone using the OS X editor on Snow Leopard out there that can help ?
Audio files: 116
G2 patch files: 317
PostPosted: Fri Jan 04, 2013 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
Laughing , it does here tho, how weird Confused
Anyway .. fatcode, does the "Synth" menu work for you on the Mac?
that one will work here only when the NM is connected.
varice
G2 patch files: 46
PostPosted: Fri Jan 04, 2013 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
fatcode wrote:
I gave it a go on my girlfriend's PC laptop and everything seems to work ok- hmmm must be the beta editor.
I see that you found an old post about this:
http://electro-music.com/forum/topic-20027.html
So, it looks like it is a bug with the beta G1 Editor.
I’m curious though. The PC G1 Editor can do these functions without the synth connected (while the G2 Editor cannot). But, can you assign the rnd and clr buttons to front panel knobs and trigger these functions without the G1 Editor connected to the synth?
varice
Audio files: 116
G2 patch files: 317
PostPosted: Sat Jan 05, 2013 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
varice wrote:
G2
why did I not read that yesterday ... sorry for the confusion.
fatcode
PostPosted: Sat Jan 05, 2013 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I connected the modular via PC on Virtual box - seems to be working ok there (it might be a way to use the G1 under Lion )
Well, it must be a bug in the OS X editor
I'll try to find out if I can get the rnd seq working with a knob
Niio1
