  bingsatellites Mostly Ambient
Korg MS2000 paint getting rusty...
Page 1 of 1 [9 Posts]
paugui
PostPosted: Fri Dec 28, 2012 5:28 pm    Post subject: Korg MS2000 paint getting rusty... Reply with quote  Mark this post and the followings unread
Hi
I got a Korg MS2000 before the summer and now that I got back home (was away from late September until mid December), I noticed it has some paint coming off at the corners of the button and it seems to be rusty as the paint comes off...
It had some scratches before but those are not getting rusty at all...
The keyboard was kept inside a closet, but there were two other keyboards in the closet next to it, a Korg MicroKorg and a Korg MS20ic, and nothing has happened to them...
I also have a Nord Modular G2X and a DK Synergy in the same room, out in a stand, and nothing happened to those either...
Is this normal???
I live by the sea so I know this kind of things are more likely to happen here, but it just seems pretty weird that nothing is happening my other equipment and only to this Korg...
Thanks in advance,
Best
Paulo
Akai EWI3020/3030m / Alesis Fusion / Cheetah MS6 / Clavia Nord Modular G1/G2X / Creamware Noah, Scope / EMU E6400U, P2000, XL7 / Ensoniq Fizmo / Hartmann Neuron / Ibanez AD202, DM2000 / Kawai SX-240 / Korg 05R/W, A1, DSS1, EMX1, Legacy Collection, Oasys PCI, P6, P800II, SDD3000, Trident, Triton Pro, Zero 8 / Novation SBS, AS / Pearl DRUM-X / Roland D550, MKS80, R880, SRE555, VariOS, V-Synth / Soundart Chameleon / Symetrix 606 / Teisco S110F / Waldorf Blofeld kbd, mQ / Yamaha A5000, AN1x, CS5/15, FS1r
tazer
PostPosted: Sat Dec 29, 2012 4:36 am    Post subject: Reply with quote  Mark this post and the followings unread
hey
sounds like it could be corrosion caused by sea air as u suggest, maybe try sealing them in thick plastic bags when they are sitting in the cupboard or something to make them more airtight. My old teisco synth was the same (but that is 26 years old) rust creeping in across the faceplate but i think it had been neglected before it reached me, I never think rust is a good sign near components.
cheers
ian
Muied Lumens
Audio files: 209
PostPosted: Sat Dec 29, 2012 6:08 am    Post subject: Reply with quote  Mark this post and the followings unread
If you seal up the synth, the moisture trapped inside won't have a chance to eascape. The best way to get rid of humidity is to keep the synth warm for a while before sealing it up, ie warmer than its environment. Not much heat is required for this normally, but it depends on a few factors. You should be ok just keeping a 40W lamp on inside the cupboard if possible, to keep it dry. Also get some of those little bags that say "Don't Eat" that come with new equipment - it helps draw the humidity out of things. Can't remember what they are called now...
Muied Lumens Base Star
EdisonRex
Audio files: 168
PostPosted: Sat Dec 29, 2012 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
re: "do not eat"
Silica gel bags. Believe it or not, a small bag of (uncooked) rice will do that too.
I suspect some instruments are more susceptible to that kind of corrosion because of the steel (and kind of paint).
Garret: It's so retro.
paugui
PostPosted: Fri Jan 04, 2013 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
But what shall I do with the silica gel or rice bags?
I'm not too experienced with this...
About the lamp suggestion, if I put a lamp eating the synth up, it should stop the rust to spread?
I have some old Teiscos here and they aren't getting rusty... :S
But the strangest part to me is that the MS2000 has some scratches that are not getting rusty either, just some areas of the painting...
DES
Audio files: 6
PostPosted: Sat Jan 05, 2013 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you sure it's rust and not some type of mold? Could also just be the paint discoloring?
www.davesneed.com
www.myspace.com/desneed
EdisonRex
Audio files: 168
PostPosted: Sat Jan 05, 2013 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pack the thing in a plastic bag, and put the silica gel or rice bags in with it.
That stops it getting much worse. As for repairing it, well that's another story.
tazer
PostPosted: Fri Jan 11, 2013 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
why don't you take some photo's of the damage before you stick them in the plastic bag with the silica gel bags, and certainly for the first while maybe check it regularly to make sure it isn't getting any worse, and at least if you have some photo's you will have something to compare. Do you know what sort of timescale the rust has appeared over? i.e. is it getting worse quickly....
Audio files: 51
PostPosted: Fri Jan 11, 2013 4:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree with all the other suggestions to reduce the chances of more rust appearing. For the spots which are there already, I'd recommend fish oil. I'm not sure where to get it, (possibly the chemist?) but a small amount painted directly onto the rust spots, will stop it in it's tracks. It penetrates right through the rust, and goes harder over time.
We would lose our friends.
So,.........
mps board
