CV > MIDI Clock > CV
Page 1 of 1 [3 Posts]
MoltenVoltage
PostPosted: Sat Jan 12, 2013 12:17 pm    Post subject: CV > MIDI Clock > CV Reply with quote  Mark this post and the followings unread
Hi everyone,
I've been talking with some modular synth folks about what is needed as far as component parts and have been told that a CV to MIDI Clock and/or MIDI Clock to CV interface would be useful.
I make a module that can do that, called the PedalSync Master Control. Here's a link to the datasheet:
http://www.pedalsync.com/documentation/PedalSync_Master_Control_Development_Board_Datasheet.pdf
A CV can be used to switch a 4066 that grounds the Tap input. A continuous stream of pulses can then vary the tempo. The module also has synchronized pulse and reset outputs for 4017 decade counters which are used in some sequencer designs.
In addition, the module stores and recalls the tempo for 128 programs and sends MIDI Program Change, MIDI Start, and Stop messages.
I'd be happy to answer any questions and help you all turn it into a modular synth module.
- William
diablojoy
PostPosted: Sat Jan 12, 2013 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
sounds very interesting
A stand alone midi clock source , pretty sure i will want one. Smile
ask where the hell am I
as good an answer as any
MoltenVoltage
PostPosted: Sun Jan 13, 2013 9:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure what width typical modular synth modules are, but the Dev. Board is 100 mm wide by 73 mm tall.
It seems like it would be straightforward to mount it to a faceplate.
This is a photo of it with the optional Dev. Board components attached:
Niio2
