JovianPyx
Audio files: 224
Posted: Mon Jan 07, 2013 12:27 pm Post subject:
dsPIC33F interrupt PDF files..... (argh)
I'm looking at these and it seems that one of them has a description that indicates it is appropriate for 4 different devices listed by part number. I now know to ignore that file and that's great, but there are 5 PDF files that I've found and they all contain similar information (though some of it can be a bit different from PDF to PDF):
Interrupts
Interrupts (Part II)
Interrupts (Part III)
Interrupts (Part VI)
Interrupts (Part V)
Only (part II) seems to say which devices it is for, the others have a rather vague description, like "small pin count". Part V seems to be for a device with only 4 DMA controllers, but it doesn't list the devices by part number
I'm assuming that there is no (Part I) PDF since I can't find it anywhere.
Anyone here have some superior knowledge on how to decode what I would need if I have just one device type? Like is there some special magic decoder web page on the Microchip website that helps in that regard? _________________ FPGA, dsPIC and Fatman Synth Stuff
Joined: Apr 03, 2004 Posts: 24075 Location: The Netherlands, Enschede
Audio files: 277
Posted: Mon Jan 07, 2013 12:46 pm Post subject:
Looks like you found family reference manuals for interrupts?
Does the device specific PDF mention what chapters from the family reference you need?
It seems to do this for PIC24 ... but it's all very messy IMO _________________ Jan
JovianPyx
Audio files: 224
Posted: Mon Jan 07, 2013 1:50 pm Post subject:
Blue Hell wrote: | Looks like you found family reference manuals for interrupts?
It seems to do this for PIC24 ... but it's all very messy IMO |
As for #1, yes, I did indeed.
As for #2, of course I didn't. That would be too much like right. And now that I did, it says Part III for my device.
As for #3, maybe Microchip should rename themselves MessyDocs...
And yes, I do remember you telling me to look in the device specific doc for other stuff. I claim "Old Timer's Disease" (as my Chinese wife says) which is not to be confused with Alzheimer's Disease.
Audio files: 277
Posted: Mon Jan 07, 2013 2:06 pm Post subject:
JovianPyx wrote: | which is not to be confused with Alzheimer's Disease. |
Ah no that'd be CRS
Glad you found it now .. oh .. I use µShit informally or was that for that other µ company grown too large .. CRS strikes _________________ Jan
JovianPyx
Audio files: 224
Posted: Tue Jan 08, 2013 9:04 am Post subject:
CRS ... what is that? Can't Remain Stupid?
oh wait Can't Remember Sh!t
heh, well, I do like the Micromess parts mostly. So far I haven't needed an option that they've notated as "doesn't work".
BTW, I had an experience with a crApple iPad yesterday that was wholly exasperating. My personal web server at home is password protected and the damned Safari wouldn't forget the password until I found the thingy where I could force deletion of all of the browser data. So crApple ain't much better than the Microjunk companies... _________________ FPGA, dsPIC and Fatman Synth Stuff
yogi
Posted: Tue Jan 08, 2013 10:31 am Post subject:
Wanted to ask a question, just recently ran across the RoninSynth Arduino shield. A dsPIC33fj128gp802 on a shield, so you can use the AVR as the front end/UI and feed note and patch data to the dsPIC firmware. They brought out all the dsPIC's pins to headers and have a separate ISP header.
I was thinking that this might be a decent development setup? It's geared more towards the Arduino user: pre-built synth firmware and Arduino lib (all open source). One down side for a dev board is the funky Arduino header spacing, doesn't play well with proto boards (not a biggie, planned to build it on a proto board anyway)
Another troubling thing is the 4MHz xtal, Can they be running at 40MIPS with that and the PLL? (haven't dug into their code yet)
After following Jovian Pyx's great thread on the Harpie build ( \o/ ), ordered some GP802s (Thanks! Microchip!) so I'm itching to build. |
JovianPyx
Audio files: 224
Posted: Tue Jan 08, 2013 11:32 am Post subject:
yogi wrote: | Wanted to ask a question, just recently ran across the RoninSynth Arduino shield. A dsPIC33fj128gp802 on a shield, so you can use the AVR as the front end/UI and feed note and patch data to the dsPIC firmware. They brought out all the dsPIC's pins to headers and have a separate ISP header.
My first thought here was to use the AVR for a MIDI controller (or other appropriate UI) to support a DSP synth in the dsPIC. I bet that's possible and offloading the MIDI controller that way leaves the power of the dsPIC to sound production. The dsPIC also has a stereo 16 bit DAC. You can at least use a UART connection between the two chips for communication, but I would suggest using SPI under DMA control.
As for the 4 MHz xtal, I've not used such a low xtal, but there are many options regarding the PLL. It will take careful reading of the oscillator docs (heh - make sure you look at the device specific PDF to find out which oscillator PDF to use ). In my little world, what I did was to ask a veteran dsPIC guy what he used - which was both hardware selection AND device bits. In my case, this is 20 mhz xtal. One option might be to replace the xtal if that's possible... One thing about the oscillator bits and xtal selection is that the exact xtal mhz used will force certain DAC sample rate selections. With 20 mhz, the top sample rate is 89.xxx khz which is just a tad lower than the spec'd max of 100 khz. Not a big deal. Bottom line: I suggest when you mess around with the PLL stuff, write yourself a simple hello world program that flashes a LED to test this. Set it up so that it should flash at once per second (or use a pin that you can test with an oscope) to measure the time. That way, you can be sure that the bits you used are correct.
I am going to drop the code here that I have for the 20 mhz xtal. With this information you might be able to figger out how to get the most out of your 4 mhz by looking at what bits are required (but will have different values for 4 mhz than my 20 mhz code).
Code: | ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
; *** IMPORTANT ***
; THE FOLLOWING INSTRUCTION SEQUENCE WORKS TO PLACE THE dsPIC INTO HSPLL MODE
; RUNNING AT 40 MIPS. HOWEVER, IT WILL NOT RUN AFTER A PROGRAM OPERATION BY
; JUST SETTING MCLR TO Vdd. YOU MUST POWER CYCLE TO START THE PROCESSOR.
; From Tom Wiltshire - to get dsPIC running at 40 MIPS with 20 MHz xtal
; Set up Oscillator, PLL, DAC and all Pre/Postscalers
; We use the HS osc with external 20MHz crystal
; Code required for 40 MIPS. If this is commented, it runs at 32 MIPS
MOV #0x0002, W0
MOV W0, CLKDIV
MOV #0x001E, W0
MOV W0, PLLFBD
; HS Osc with Xtal = 20MHz
; PLL Prescaler (N1) = /4 = 5MHz
; PLL Multiplier = x32 = 160MHz (Fvco)
; PLL Postscaler(N2) = /2 = 80MHz (Fosc, for an Fcy of 40MHz)
; Fvco is used as ACLK = 160MHz
; DAC Prescaler = /7 = 22.8MHz DAC Clock division /256 = 89.285 KHz sample output rate
; Clocks per DAC update = 448
; DAC Prescaler = /8 = 20.0MHz DAC Clock division /256 = 78.125 KHz sample output rate
; Clocks per DAC update = 512
; Disable auxillary oscillator and use primary osc instead
MOV #0x0780, W0
MOV W0, ACLKCON
; Aux Clk divide = /1
; Primary osc is aux clock source
; test oscillator LOCK bit
PLL_lock_test:
BTST OSCCON, #LOCK
BRA Z, PLL_lock_test
Note the last two instructions are VERY important, they force the processor to wait until it's at 40 MIPS before anything else happens. I do this stuff just before setting the stack limit. _________________ FPGA, dsPIC and Fatman Synth Stuff
yogi
Posted: Tue Jan 08, 2013 12:46 pm Post subject:
JovianPyx wrote: | My first thought here was to use the AVR for a MIDI controller to support a DSP synth in the dsPIC. |
Yes, very close to your setup with the Harpie. But then there are issues with developing on two IDEs; for both the dsPIC and the AVR/Arduino. Not huge. The developers' aim is/was towards Arduino users, so not sure how many 'new' DSP designs will come from them. What they have at the moment sounds interesting, but being able to have a selection of synths would be sweet.
In their design the dsPIC is connected via spi, which allows multi shields to run off the Arduino, till you run out of pins to use as SSelects. (Not sure how a 10 shield Arduino stack would work out, though)
JovianPyx wrote: | write yourself a simple hello world program that flashes a LED to test this. Set it up so that it should flash at once per second (or use a pin that you can test with an oscope) to measure the time. That way, you can be sure that the bits you used are correct. |
Thanks, very good idea. Also thinking about maybe a socket-ed xtal but not sure how that would effect the osc circuit; would like to be able to run their firmware stock, but be able to upgrade too.
Thanks x2 for the code snippet, I'm very new to the dsPICs ; been mucking around with 16Fs & 18Fs for the longest time, dragging my feet with the newer lines. But after your FPGA and dsPIC projects, I'm very inspired to push my comfort zone. |
JovianPyx
Audio files: 224
Posted: Tue Jan 08, 2013 1:11 pm Post subject:
yeah, regarding multiple IDEs - not fun... That's why I decided to "waste" a dsPIC for the Harpie MIDI controller - while that's not a different IDE situation, to use a "cheaper" or less powerful device, it would be another instruction set I would have to learn because I do everything in assembly language.
Also, the code I posted is actually code I got from Tom Wiltshire. I added some additional comments to the comments he already had written.
Whatever you do - it is important to HAVE FUN _________________ FPGA, dsPIC and Fatman Synth Stuff
yogi
Posted: Wed Jan 09, 2013 2:55 pm Post subject:
So been poking around the Ronin dsPIC firmware;
Here is the PLL setup:
#ifdef OSC_INTRC
CLKDIVbits.DOZE = 0;
CLKDIVbits.DOZEN = 0;
CLKDIVbits.FRCDIV = 0;
CLKDIVbits.PLLPOST = 0;
CLKDIVbits.PLLPRE = 1;
PLLFBDbits.PLLDIV = 63;
ACLKCONbits.APSTSCLR = 0b011;
#endif
#ifdef OSC_4MHZ
CLKDIVbits.PLLPRE = 0;
PLLFBDbits.PLLDIV = 78;
#endif
#ifdef OSC_25MHZ
CLKDIVbits.PLLPRE = 8;
PLLFBDbits.PLLDIV = 62; //62;
All 3 ifdef for the clock sources work out to Fvco=160MHz, ( Fvco= Fin*(PLLDIV+2/PLLPRE+2)).
But DAC setup does not seem to work!?!? Fs=(Fvco/DACDIV)*256, working backwards from Fvco
Here we see DACFDIV set to x3
DAC1CONbits.DACEN = 1; // Enable DAC
DAC1CONbits.FORM = 1; // 16 bit signed
DAC1CONbits.DACFDIV = 0b0000010; // No clock division
DAC1STATbits.LOEN = 1; // Enable left output
DAC1STATbits.ROEN = 1; // Enable right output
DAC1DFLT = 0; // Default to 0 output
So either the source is outdated or I'm not getting it, could be a setup bit (?) for the DAC in addition to DACFDIV or are they running the DAC from the AltClock? Went thru the uChip Family Ref for the Clock and the DAC, but will have to go through again (mak'in my brain hurt!! )
JovianPyx, the code was very helpful, Thanks to Tom are also in order! It took me a while to recall the name; Electric Druid.com is one of my fav Bookmarks!
EDIT-The math works out better with: Fs=(((Fvco/2)/DACDIV)/256), but I don't know if I have this right. Using this, DAC sample rate=104KHz, which is still too high, but closer. Could be, just me mangling the equations :0
EDITx2- So just to keep my nonsense in one place:
I think, given the above code, this might be correct:
Fs=((Fosc/APSTSCLR)/ DACFDIV)/256.
This is based on the datasheet's fig. 9.1 showing 'Fosc' going into the SELCLK mux and the assumption that SELACK defaults to 0b0, selecting Fosc (Fvco/2, reguardless of PLLPOST setting?WRONG) as the SELCLK mux output (haven't found the SELCLK bit set/reset anywhere in the source code).
This assumption is in conflict with FRM Sec 33.4.2 which uses Fvco, so does DS Fig.9.1 mean Fosc=Fvco, or Fosc=Fvco/2WRONG, or am I reading too much into a typoYES I AM.
'APSTSCLR = 0b011' sets Aux Clk Divisor to 16
'DACFDIV = 0b0000010' divides ACLK by 3 (I.E. 2+1 as per FRM),
So Fs=1.6MHz/256=6.5KHz using the aboveFORGET THIS, or Fs=3.3MHz/256=13KHz using Fvco instead of Fosc THIS IS THE CORRECT WAY .
USE AT YOUR OWN RISK! Not sure whether to use Fvco THIS IS IT AS PER CE154 LOOPBACK TEST CODE or Fosc=(Fvco/2) or Fosc=Fvco, both/all are in range for the DAC, but without knowing the Ronin's target Fs. I wish that this was detailed better in the Datasheet and the FRM.
I THINK I'M DONE BEATING THIS DEAD HORSE Last edited by yogi on Thu Jan 10, 2013 6:37 pm; edited 2 times in total |
YoSynthi
Posted: Thu Jan 10, 2013 4:13 am Post subject:
@JovianPyx
You've already been very generous in making code available for your FPGA synths, but this thread seems to imply that you've also made code available for your dsPIC synth too. I can't see it on your site, or am I looking in the wrong place?
I've got some dsPIC chips that I'm itching to start using, and your work would be an excellent springboard, or kick up the backside, or whichever metaphor you prefer.
The 'Sometimes I Repeat Myself' tune that you did with the Harpie keeps going round and round in my head. It's a real "ear-worm"! (In a good way).
Thanks for the inspiring results so far,
YoSynthi. |
JovianPyx
Audio files: 224
Posted: Thu Jan 10, 2013 7:39 am Post subject:
At this time, I can't release the code for the Harpie, I hope (probably desperately) to make some sort of commercial thing out of it and other designs. The job market has dried up and taken a leap sideways and I need to have some kind of income, even a small one.
In another thread, I had intended to create a monosynth with MIDI controller built into it using a single dsPIC and post the code for that. I got side-tracked by the Harpie project and still have not completed it. Harpie became a sort of monster with 3 dsPICs that talk to each other. For now, I have to concentrate on moving the Harpie from a prototype to a viable marketable item. It may not pan out and if it turns out that it's just not going to sell, I will likely then release it or perhaps sell boards for the internals. I have several ideas regarding that.
I have tried to post about my trials and tribulations because I have to believe I'm not the only one playing Blind Man's Bluff with this stuff. All too often on other forums I see questions asked and either no answer or insufficient answers. In terms of DIY, my own opinion and experience says "never give up" and "RTFM". RTFM can sometimes be the hardest thing, especially when the documentation is confusing. I don't fault Microchip really, they put everything in the manuals that is needed, but it can often be an adventure to get all of the information I need together to write some code. Much/most of this is due to the fact that Microchip did a good job of cramming so many useful and well integrated peripherals into a single CPU. This means that there are just going to be a truckload of option bits and device registers to deal with.
At some point in time, I do want to put together and post details of a small project to act as a "hello world" synth which could be examined for at least one person's approaches. The problem I have with this is my own desire for high performance, so I will have to be careful not to expect so much and remain confined to a single dsPIC IC.
EDIT ADD: I may just post some of my own hello-world code. It was from this kind of code that I developed useful musical things. These code bits will show pretty much the absolute minimum stuff that has to be done to get a peripheral device to do it's job. _________________ FPGA, dsPIC and Fatman Synth Stuff
YoSynthi
Posted: Thu Jan 10, 2013 9:34 am Post subject:
I perfectly understand your considerations, and it seems entirely reasonable to look for some return on all the work you've clearly put in. Good luck with whatever you decide to do with your projects.
Whatever happens, you've certainly encouraged me to start exploring some more. I can already testify to the thrill of getting sounds out of a PIC, and I'd forgotten how enjoyable assembler coding can be (am I weird?) I'm now keen to turn my attention to the more capable dsPICs, but like most people, I just wanted to hit the ground running, and make the best of what others have already done.
If I end up getting anything like the results you've obtained so far, I'll be very pleased indeed.
YoSynthi. |
JovianPyx
Audio files: 224
Posted: Thu Jan 10, 2013 10:15 am Post subject:
Of the things I found nice about the dsPIC:
- Stereo 16 bit DAC (basically, good enough for most stuff)
- 40 MIPS possible
- useful built in peripherals, such as UART and SPI
What I don't like is that the ADC systems (both 12 and 10 bit) are inappropriate for audio. They are great for pot reading and some kinds of CV inputs.
Synthesizers seem possible to me. One thing I hate is playing the multi-tasking game. That's why I copped out and designed the Harpie with 3 dsPICs. I could use 2 dsPICs for as high a performance level as I could get reliably. One dsPIC was dedicated to MIDI controller and voice assignment. I managed this over an SPI channel that sends from the MIDI controller to 2 "voice engine" dsPICs. Because DMA is very efficient the way it is implemented on a dsPIC, it is wise to learn how to use it. I will admit (like I have to? ) that I've always explored by doing the simplest things first and building my application on that working code. Yes, I write a lot of code that isn't always useful later on (in total), other than it works and it's simple and I comment the hell out of everything.
Eventually, I see how to make things more efficient, but in my little experience, it seems to be trying a lot of things ...
It keeps me off the streets. _________________ FPGA, dsPIC and Fatman Synth Stuff
Posted: Thu Jan 10, 2013 11:08 am Post subject:
JovianPyx wrote: |
It keeps me off the streets. |
And a good thing, too. |
yogi
Posted: Thu Jan 10, 2013 11:34 am Post subject:
YoSynthi wrote: | I perfectly understand your considerations, ....Whatever happens, you've certainly encouraged me to start exploring some more.
YoSynthi. |
DITTO and DITTO!
Scott, all you've done is very appreciated! |
JovianPyx
Audio files: 224
Posted: Fri Jan 11, 2013 12:36 pm Post subject:
I have been flogging this stupid SPI SRAM thing for quite some time now. So far, I have created a program that can read and write to a 23K256 SPI SRAM. But it uses no DMA and transfers data to and from the RAM using programmed I/O. The program can do transfers to and the from the RAM on a "on-demand" basis, that is, when I need to read, I issue a read request and I get the data. Likewise when I want to write.
All well and good, but I would like to get the highest performance possible - so DMA would seem to be the answer. I would like the DMA to work also on an "on-demand" basis, that is, not continuous, just one write transfer or one read transfer and only when the program requests it.
After much banging and swearing, I've put together about the simplest test program I can. For the moment, all I want to see is a single byte get transferred out the SPI port and into the air for all I care. I have a scope probe on the SCK pin and if I see 8 clock pulses, I know it worked.
First I tried to use the simplest method to get the SPI peripheral to transmit, that is, I stuffed the buffer register (SPI1BUF) with a zero. Then the program waits in a waste-time loop and does this repeatedly forever. This gives a repeated nice little burst of 8 clocks that I can see on my scope. Kinda shows that SPI is working...
My DMA channel is set this way:
Code: |
MOV #0x6001, W0
MOV W0, DMA0CON ; Note that CHEN is off here, we turn that on later
MOV #0x000A, W0 ; SPI1 requestor
MOV W0, DMA0REQ ; write the interrupt req select bits
MOV #SPI1_WRITE_BUF, W0
MOV W0, DMA0STA ; set the buffer address where write data is stored (command and address for SPI SRAM)
MOV W0, DMA0STB ; for the hell of it, put the same address in the B register (even tho we don't use ping-pong)
MOV #SPI1BUF, W0
MOV W0, DMA0PAD ; Peripheral device Address
;MOV #3, W0 ; set transfer count to 4 (yes, the register value is N-1 where N is the transfer count)
MOV #0, W0 ; TEST SINGLE BYTE TRANSFER
MOV W0, DMA0CNT ; set DMA count register
BCLR IFS0, #DMA0IF
BSET IEC0, #DMA0IE
BSET DMA0CON, #CHEN ; enable DMA channel 0
From what I am reading, I can use one of 2 methods to start a DMA transfer, one is to stuff the buffer register (which I've done and it appears to work) and the other is to use what is called "DMA manual transfer mode". As I understand it, this is to be done by setting the FORCE bit in the DMA interrupt request register.
Here is the main loop portion of my test loop code:
Code: |
test_loop:
BCLR SPI1STAT, #SPIROV ; be nice to the overflow bit
BSET DMA0REQ, #FORCE ; force a single cycle of write
; MOV W0, SPI1BUF ; another way to force an SPI transfer and DMA request
dma_1:
CALL tim
GOTO test_loop
tim:
MOV #0x03FF, W0
tim1:
DEC W0, W0
BRA NZ, tim1
RETURN
__DMA0Interrupt: ; interrupt vector for DMA read transfer from SPI SRAM
BCLR IFS0, #DMA0IF
BTG PORTA, #LED ; toggle the LED at each interrupt
RETFIE
The above code causes no clocks to spew from SCK.
If the BSET DMA0REQ, #FORCE is commented and the MOV W0, SPI1BUF below it is uncommented, I get bursts.
Ideally, I want to set up an outgoing 4 byte data transfer in a buffer, point the DMA controller to that and then hit the FORCE bit. After that, it's a matter of either setting up an interrupt or polling the interrupt flag to know when the transfer is done. This would reduce the CPU I/O tending work to minumum. Except that when I hit the FORCE bit, nothing happens.
I've looked at errata, I know my device is revision code 0x3003 (which is revision A4). No mention of this SPI problem exists in errata.
I've also looked at the example code for an SPI loopback, but it operates in continuous mode, not one-shot. I require one-shot to facilitate the "on-demand" nature of what I need to do. However, in the example code, they use the FORCE bit to start the process (after which the DMA requests are initiated because the DMA channel has it's request set to SPI. In continuous mode, this works, but I see no examples of on-demand SPI transmission as I would like to do).
Soooo.... any help out there ??
EDIT ADD:
Just for grins, here is the SPI1 set up I'm using:
Code: | BSET TRISB, #RB7 ; pin is input (SDI)
BCLR TRISB, #RB8 ; pin is output (SPI clock)
BCLR TRISB, #RB9 ; pin is output (SDO)
MOV #0x001F, W0
MOV W0, RPINR21 ; tie SS high
MOV #0x0007, W0
MOV W0, RPINR20 ; SDI is input on RP7 pin 16
MOV #0x0708, W0 ; set both RP9 (high byte) and RP8 (low byte)
MOV W0, RPOR4 ; SDO is output on RP9 pin 18, SCK is output on RP8 pin 17
; SPI clock
MOV #0x001E, W0 ; 1:1, 4:1 timer 0x0010 10.00 MHz
MOV W0, SPI1CON1
BCLR SPI1CON1, #CKP ; 0 = Idle state for clock is a low level; active state is a high level
BCLR SPI1CON1, #CKE ; 0 = Serial output data changes on transition from Idle clock state to
BCLR SPI1CON1, #MODE16 ; 8 BIT MODE :: 16 bit mode not set.
BSET SPI1CON1, #MSTEN ; set Master Mode Enable
BCLR SPI1CON1, #DISSCK ; disable clock pin not set
BCLR SPI1CON1, #DISSDO ; disable output pin not set
BCLR SPI1CON1, #SMP ; 0 = Input data sampled at middle of data output time (for master mode)
; active clock state (refer to bit 6)
BCLR SPI1CON1, #SSEN ; 0 = SSx pin not used by module. Pin controlled by port function
BCLR SPI1STAT, #SPIROV ; clr Receive Overflow Flag
BSET SPI1STAT, #SPIEN ; set SPI Enable
JovianPyx
Audio files: 224
Posted: Fri Jan 11, 2013 2:56 pm Post subject:
For those interested ... I've posted a very basic question about this on the Microchip forum. Hopefully, that will shed some light on why this is not working. I shall convey such information back to here. _________________ FPGA, dsPIC and Fatman Synth Stuff
yogi
Posted: Fri Jan 11, 2013 9:07 pm Post subject:
You know, I was reading FRM sec 38 most of today. So I have just enough knowledge to spell DMA
Going through your code, I'm not seeing DMA0IE being set. just a thought
EDIT- For one byte, not sure if the IRq is needed, but the FORCE bit is simulating a IRq request to the DMA. All example setup code shows it enabled, which makes sense; if you'r using DMA, you need IRqs to service the buf. A one byte DMA transfer is probably not too common.
Another idea: setup for 4 bytes, manual start the SPI Tx and see if the other 3 bytes are sent via DMA. Let you know if the prob is with the DMA setup. |
JovianPyx
Audio files: 224
Posted: Sat Jan 12, 2013 7:42 am Post subject:
Well the missing interrupt enable is now in the code and I've edited the post above to include it as well. Still doesn't work. I added that later so that I could toggle an LED in the ISR.
I also edited in the ISR code.
I also want to try the 4 byte thing with manual stuffing of first byte, but I really hate to do that.
EDIT ADD: The documentation would seem to indicate that the 4 byte thing won't work. The interrupt request comes from the SPI module to the DMA channel. This technique can be used for continuous operation as I've seen in example code. The interrupt will occur only after all of the bytes are transferred - and it should startup using the FORCE bit technique. I will test continuous mode this way and leave the DM0CNT register set to zero (for one byte transfer) just to see if that works. I don't see a reason for it not to work with one-shot, but so far, I've been without luck... _________________ FPGA, dsPIC and Fatman Synth Stuff
yogi
Posted: Sat Jan 12, 2013 1:52 pm Post subject:
JovianPyx wrote: | Well the missing interrupt enable is now in the code and I've edited the post above to include it as well. Still doesn't work. I added that later so that I could toggle an LED in the ISR. |
Yea, the IRq from the DMA is not much use here, not using an ISR. was just a shot in the dark.
OK, you can manual start the SPI for one byte, so the SPI basic start up works. The DMA setup seems correct also,
MOV #0x6001, W0 ;0110 0000 0000 0001- DMA0CON
;BYTE md , RAM->Peri, RegI++, one-shot-noPP
MOV #0x000A, W0 ; SPI1 requestor ; SPI1 TxDone 000 1010
MOV #SPI1BUF, W0 ;SPI1BUF 0x0248
But I'm not sure of the impact of one-shot mode. As I understand, once the block transfer completes, CHEN is reset. So in this context, you would only get one SPI tx using FORCE on the first pass thru Main; without re-enabling the channel before the next bitset of the FORCE bit. You might try adding:
to the end of the tim loop before return.
But If you'r not even seeing ONE SPI Tx with FORCE bit, makes me think the issue is between the SPI and DMA. Enabling the SPI IRQ, could that be required for the FORCE bit? not sure how that would make a dif here?
JovianPyx wrote: | I also want to try the 4 byte thing with manual stuffing of first byte, but I really hate to do that. |
My thought was to verify transactions between the SPI and DMA. By using the 'conventional' way of starting the SPI (which works), you could see that the SPI-DMA automatic side of the block transfer is working. This would demonstrate that the DMA setup is functional.
If I got this right: SPI should set an IRQ after each byte transfer, this is captured by the DMA. So for a 4 byte block, the SPI will gen 3 IRQs and then the DMA will gen a system IRQ. Setting FORCE simulates the first IRQ to the DMA, which only respond to requests.
With one shot, the SPI should send 4 bytes then quite; with Cont, should see a stream of clock transitions, the same 4 bytes from the buf.
Seems simple, but the devil's in the details |
JovianPyx
Audio files: 224
Posted: Sat Jan 12, 2013 2:09 pm Post subject:
Thank you yogi profusely.
Dammit. I had my doubts about CHEN being turned off by one-shot operations, but I thought to myself - just try it... so I did and it worked. Then I seached the DMA PDF for CHEN and here is what I found:
38.6.7 One-Shot Mode
One-Shot mode is used by the application program when repetitive data transfer is not required. One-Shot mode is selected by programming the Operating Mode Select bits (MODE<1>) to ‘x1’ in the DMA Channel Control (DMAxCON) register. In this mode, when the entire data block is moved (block length as defined by DMAxCNT), the data block end is detected and the channel is automatically disabled (i.e., the CHEN bit in the DMA Channel Control (DMAxCON) register is cleared by the hardware).
I know I read that. It just didn't stick.
Basically, I simply added an instruction to set CHEN to 1 just before setting FORCE to 1 and now I get exactly what I should get on the scope.
I'll now mess with it to get what I really want, but this is a start.
EDIT ADD: It works without using an ISR (Which is what I need anyway). I took the ISR away and don't enable the interrupt and it still spews clocks like it should. _________________ FPGA, dsPIC and Fatman Synth Stuff
yogi
Posted: Sat Jan 12, 2013 4:17 pm Post subject:
OH, Very Cool! So Very glad I could help!!
I know what you'r talking about; just to go through this issue I had the DataSheet, The DMA section and the SPI section of the FRM all open, and jumping back an fourth between them!?!?! There are so many details with these devices, it's maddening trying to pick out only what you need know. |
JovianPyx
Audio files: 224
Posted: Sat Jan 12, 2013 4:31 pm Post subject:
I will at least post the complete SRAM diagnostic. It will be designed to write random data to all 32768 bytes, then re-seed the random generator and read it all back to check that it is stored accurately. This program should then be useful as a template for other on-demand requirements using SPI (or any periph).
I know what you mean - when I do stuff with dsPIC, I open a separate browser window just for that stuff and often have 5 tabs open with different PDF files that are related. Interrupts in one PDF, DMA in another, the peripheral in a third, errata in a 4th, etc. I do hate it, but honestly, I don't know if I could do a better job than they did. dsPIC is a great chip because it will do so many things, but for each thing it does there has to be a document... _________________ FPGA, dsPIC and Fatman Synth Stuff
yogi
Posted: Sat Jan 12, 2013 5:28 pm Post subject:
JovianPyx wrote: | I will at least post the complete SRAM diagnostic. It will be designed to write random data to all 32768 bytes, then re-seed the random generator and read it all back to check that it is stored accurately. This program should then be useful as a template for other on-demand requirements using SPI (or any periph).... |
That would be great! I need to get off my butt, and breadboard a test board now.
I have a question, what are the effects on the audio output if you have the DAC set for say Fs of 50KHz and the updates are at a slower rate? I assume the DAC will fill in with the val stored in DACxDFLT reg when it's FIFO empties. That will amount to 'noise' in the audio? I ran across several posts on the uChip forum about noise with the DAC, and was thinking this could be a problem with high sample rates if it's not handled right. |
