Question about vco capacitor
Page 1 of 1 [9 Posts]
capicoso
PostPosted: Wed Jan 09, 2013 1:14 pm    Post subject: Question about vco capacitor
Subject description: mica
Hello. I'm building the vco. And here i have problems finding the silver mica capacitor 1%. So far i found silver mica 270pf BUT +-10% not 1%. NP0 ceramics 220 or 270, or polypropylene. The silver mica one is still the best even with 10% tolerance?
thanks
isak
PostPosted: Sat Jan 12, 2013 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can use styroflex as well Wink
http://www.ebay.com/itm/Polystyrene-Styroflex-Capacitor-Made-by-Philips-listing-is-for-2-pieces-/271128402472?pt=UK_BOI_Electrical_Components_Supplies_ET&var=&hash=item3f20831a28
Q...
What you will be using, the OPA2137P or OPA2137PA?
I want to build the vco as well and I'm not sure about this IC.
The OPA2137P is more expensive then the OPA2137PA, don't know why tho...
Any help will be thankful.
Isak E.
capicoso
PostPosted: Sat Jan 12, 2013 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Q...
Isak E.
Hello, thanks for your time.
Yes i can, but at my local stores i couldn't find either. So my options are 10% mica, np0 or polypropylene.
I'm going to use LF442. I couldn't find 2137 here and someone that built like 3 or 4 vco told me that CA3240 is cheaper and it works the same. Or Lf442 also works.
isak
PostPosted: Sun Jan 13, 2013 12:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Really?
I have some 442's, I wander what will be the deference using 442's or tl072 like Yves recomands.
EDIT:
Yves, what will be preferred instead OPA2137, TL072 or LF442?
Cheers.
PostPosted: Sun Jan 13, 2013 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
The question of film vs NP0/C0G caps comes up pretty regularly, and I have never seen any convincing reason why film would be preferrable. I still use them because I have a stock, but the long term plan is to get more stock of the C0G's....
capicoso
PostPosted: Sun Jan 13, 2013 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, i searched and that's why i ask about the NP0 caps ( i didn't know about their existence)I guess i'm going to use NP0. They're way cheaper and in the datasheets they look goood
but my main question now is if it has to be 1%
yusynth
PostPosted: Sun Jan 13, 2013 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any precision dual AOP will do. The important is that it has a low bias.
Concerning the cap, the important is the temperature coefficient which must be kept low (500ppm maximum), in general silver mica and styroflex are offering that. The 1% tolerance is not really important unless you want to built plenty of VCOs and you want them to behave the same.
Yves
capicoso
PostPosted: Sun Jan 13, 2013 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well my idea would be having various VCOs. If i use NP0 then i think i'll have to match them to 1%. When you say they'll behave different, you mean they'll be tuned differently? Or...?
thanks
yusynth
PostPosted: Mon Jan 14, 2013 12:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, "tune differently"
Yves
