PCB offer: Thomas Henry's Controller LFO
Page 2 of 3 [55 Posts]
stahlblau
PostPosted: Sun Nov 04, 2012 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would like to take two main pcbs please
thank you!
PostPosted: Mon Nov 05, 2012 12:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Danno Gee Ray wrote:
Fonik,
What kind of pots did you use on your prototype?
Thanks,
Dan
i used 9mm alpha.
you don't need threaded bushing. the sockets will hold the PCB in place.
fonitronik at
Danno Gee Ray
PostPosted: Mon Nov 05, 2012 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks.
ungleichklang
PostPosted: Tue Dec 04, 2012 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Boards arrived today ... thanks Matthias Smile
My new blogspot: http://ungleichklang.blogspot.com
My Youtube-Channel: http://www.youtube.com/user/ungleichklang
My old google-site: https://sites.google.com/site/ungleichklang/home/s-diy
Linux Musician
DES
Audio files: 6
PostPosted: Wed Dec 05, 2012 9:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Received my boards today! Look real good Very Happy
Quick question....what brand/model trim pots did you use?
www.davesneed.com
www.myspace.com/desneed
stahlblau
PostPosted: Fri Dec 07, 2012 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Boards arrived Very Happy
Thank You
donpachi
PostPosted: Sun Dec 09, 2012 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Boards are here Cool
As usual, thanks a bunch for outstanding projects, Matthias!
EDIT: I'm soldering components ATM in an attempt not to accumulate any more backlog. Is it correct that there is no D2 on the board? Obviously, function is not impaired, so should I piggyback it onto R44 or just leave it out of the circuit?
PostPosted: Sun Dec 09, 2012 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
D2 is not needed. trigger out works fine without it.
fonitronik at
PostPosted: Sun Jan 13, 2013 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
In case anyone's interested and not using Euro format Smile
This is my design for a MOTM-sized panel (2 wide) for this LFO
 Filesize:  377.08 KB
 Viewed:  30 Time(s)
PostPosted: Mon Jan 14, 2013 7:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Decided to experiment with inverse printing, to try for a more traditional look....
Made some mistakes to learn from on my first try, but still closer to what I would like to see than I've been able to do so far....
 Filesize:  222.11 KB
 Viewed:  20 Time(s)
roborobert
PostPosted: Tue Jan 15, 2013 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
stumbled across this yesterday, looking for components for a new proper synth - seems like the perfect lfo for me. thanks a lot for this brilliant work and offer!
so here's my first post Embarassed
i'd like two circuit pcb's Very Happy
grüße, robo
PostPosted: Tue Jan 15, 2013 10:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
To assuage my pain at not having the last 3 100k trimmers I need, nor being able to get them locally, here is the panel with components on it Smile
 Filesize:  250.99 KB
 Viewed:  19 Time(s)
LektroiD
PostPosted: Sat Jan 26, 2013 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
How did I miss this? If there is a slim chance of any main boards left, I'd be very interested in a couple...
My tunes available here
(check out the new Electro-Funk LP)
TheProf
PostPosted: Mon Jan 28, 2013 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd been away for a few days and found the boards waiting on my return. Really good looking boards; lovely work, (as always!).
Thanks again. Fonik.
Mike
PostPosted: Tue Jan 29, 2013 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
you did not miss anything, actually. for the current small re-run i ordered a few spares (as always).
so what do you need/want? i offer 3 aprts this time:
the actual circuit board,
an eurorack front panel components PCB, and
an eurorack front panel (printed).
fonitronik at
LektroiD
PostPosted: Tue Jan 29, 2013 2:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I would like 2 main PCBs. If it's not too much trouble, would it be possible to wait for the 555 VCOs and combine shipping?
Heavy Metal Kid
PostPosted: Wed Jan 30, 2013 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
If there still are spares, I would like:
1 actual circuit board
1 eurorack front panel components PCB
1 eurorack front panel (printed)
samuron
PostPosted: Fri Feb 01, 2013 9:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
After hearing about DecalPRO on this forum, I decided to try it to make a Frac panel. I took off too much with the tape, and I need to get the alignmnet right, but it didn't come out too terribly:
 Filesize:  58.08 KB
 Viewed:  28 Time(s)
PostPosted: Fri Feb 08, 2013 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow, that looks awesome! but it quite a lot of work, isn't it? how many panels had you to make until you got this nice result?
fonitronik at
PostPosted: Fri Feb 08, 2013 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
the new PCBs came in today! however, i am still waiting for the front panels.
so:
i will now start to contact all who placed pre-orders for PCBs only, providing payment info's.
i will combine shipping and packaging for all who placed orders for both the VCO and the LFO.
please be aware, i am currently selling 4 different PCBs + front panels. there are quite a few orders to fullfill. i hope you are patient with me. it might take a while until i contact you, and packaging and mailing will take a little bit longer than usual, i guess.
fonitronik at
samuron
PostPosted: Fri Feb 08, 2013 8:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, that was the first try; I lost some detail on the finer lines, and I'll try some wider ones.
It's really not too much work; it's kind of a decal version of Press 'n Peel Blue.
You print the design on the decal paper, laminate it to the white material, peel the white material off, clean off the excess (that's where I'm removing too much material), laminate a clear carrier material onto it, soak the paper off, spray on the glue, and then stick it to the panel. Start to finish, the first one took maybe 20 minutes.
If I can keep from losing bits of the design, it should be a good process.
lucid
PostPosted: Sat Mar 02, 2013 3:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi fonik
I can see on picture that also here you are using 50k trimmers instead of 25k (similar as you propose for VCO-555).
So I assume that it could work also on 15V.
I have also some spare 47k, can I use them also as replacement for these 25k?
PostPosted: Sat Mar 02, 2013 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
lucid wrote:
Hi fonik
of course you can. you could even use 100k. it is wired as a variable resistor, not as a voltage divider. the problem is that you will have less of usable range. when trimming (not a big issue with 25-turn precision trimmers).
fonitronik at
PostPosted: Tue Mar 05, 2013 2:19 pm    Post subject: payment details Reply with quote  Mark this post and the followings unread
i sent out PMs/emails to all who ordered PCBs/panels. please check your PM's, i am missing the response of quite a few people.
fonitronik at
LektroiD
PostPosted: Wed Mar 06, 2013 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't seem to source the 2n5461, anyone know of an equivalent (would J112 work?). If not, has someone got one I could buy?
