Fantronic oscillators
Page 1 of 1 [4 Posts]
Audio files: 566
PostPosted: Sun Jan 13, 2013 2:45 pm    Post subject: Fantronic oscillators
Subject description: more LED's to listen to
The teacandle oscillators got me thinking what else I have to listen to.
I have a couple of battery powered fan's with LED's that create some nice patterns, similar to this:
[turn the volume down]
so I decided to see what those sounded like.
I replaced the LED's with optocouplers and buffered the signal with some 40106 inverters. The fantronix circuit itself runs
on 4.5 volts but I noticed that by varying the voltage I had a bit of control over the pitch/speed, so I used a variable regulator.
I also added another optocoupler to modulate the voltage. I could have just used a transistor but this was an easy way to
do it and I had a nice space for another optocoupler on the PCB Wink
I also used the spare inverter to create an LFO which can be used to modulate it.
I added a divider which can be used to turn one of the fan LED's into a range of frequencies, and I can select one of those
to modulate the power, so it can selfmodulate Laughing But I can also use an external signal.
Then there is the audio section. I used two summing amps and used some different resistors to spread the sound (yes they
make sound) of the 5 LED's over the L/R channels, I also added 2 flipflops (U3) to create a sub sound which can be turned
on/off with a switch or remotely. The switch actually just inverts the remote signal, so if I invert one and attach them both
to the LFO I get a panning effect. there are some other switches and extra inputs but you can probably make out from the
schematic what it all does.
I made a recording when it was still breadboarded, droning together with the Enneatronic Spectralizer, which you can
find here. Cool
 Filesize:  111.2 KB
 Viewed:  353 Time(s)
(fantronic oscillators with temporary knobs)
 Filesize:  37.78 KB
 Viewed:  200 Time(s)
 Filesize:  45.98 KB
 Viewed:  163 Time(s)
Draal
PostPosted: Sun Jan 13, 2013 4:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now that's a nice box Cool ! More samples with this in action when you get the time thumright
Zontar Prevails!
Audio files: 566
PostPosted: Sun Jan 13, 2013 7:21 pm    Post subject: Fantronic oscillators demo Reply with quote  Mark this post and the followings unread
ok here's a demo. It's not all too interesting on it's own, but a very usefull addition for my modular lunetta.
And it looks awesome with all the flashing LED's Cool (I might make a similar box for the PWM Wink)
anyway here's roughly what I did:
0:00-0:20 normal play
0:20-0:40 manual pitch control
0:40-1:15 LFO pitch modulation
1:15-1:50 self pitch modulation
1:50-2:00 normal play
2:00-2:20 sub added
2:20-2:40 sub with LFO modulation (panning)
2:40-3:40 all together now
(no efx where added)
I also added a photo of the inside and a close up of the actual 'fantronix' circuit, which I put on a piece of perf
with a resistor and zenerdiode. Mainly to protect it when I was still breadboarding. (just in case)
Fantronic Oscillators inside look
 Filesize:  59.98 KB
 Viewed:  256 Time(s)
Fantronix
 Filesize:  34.42 KB
 Viewed:  148 Time(s)
PHOBoS - Fantronic Oscillators Demo (Jan 13, 2013).mp3
 Filename:  PHOBoS - Fantronic Oscillators Demo (Jan 13, 2013).mp3
 Filesize:  3.36 MB
 Downloaded:  466 Time(s)
analog_backlash
Audio files: 21
PostPosted: Thu Jan 17, 2013 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Ditto!
I now find that I'm regularly looking round pound (or 99p) shops looking for things that might be cannibalised. They're very good source of LEDs, especially just after Christmas. I've got even more flickering candles now.
Gary
