  Muied Lumens Frequencies
lunetta sound samples
Page 13 of 13 [311 Posts]
Goto page: Previous 1, 2, 3, ..., 11, 12, 13
tjookum
Audio files: 26
PostPosted: Fri Dec 21, 2012 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
easily one of the most musical cmos tracks I've ever heard. Can you please explain how you used the 4046? A simple schematic goes a long way Very Happy .
Hunter S. Thompson
movies
noise
jcintheus
PostPosted: Fri Dec 21, 2012 6:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the 4046 shcematic:http://electro-music.com/forum/topic-51275.html
I used a divider on pins 3 and 4. (4017-51 melody gen.)
Audio files: 574
PostPosted: Tue Jan 15, 2013 6:56 pm    Post subject: R2RVCO4PWM16022013 Reply with quote  Mark this post and the followings unread
Testing a R2R-VCO combo. VCO is similar to what i got in my modular lunetta (4046) but with less opamps.
The R2R is inventor's tunable RnR (there is no adjusting during the recording though), and I used XOR's as buffers for it
with the 2nd pin of all the gates tied together and they can be controlled remotely (inverts everything). I mixed both
square and saw outputs together added a filter and some reverb. The RnR is controlled by a modular lunetta patch
I need moooore croc-cables! Shocked
PHOBoS - R2RVCO4PWM16022013.mp3
 Filename:  PHOBoS - R2RVCO4PWM16022013.mp3
 Filesize:  2.49 MB
 Downloaded:  561 Time(s)
SoundCloud BandCamp Stickney Synthyards Captain Collider
Audio files: 574
PostPosted: Wed Jan 16, 2013 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
o and jcintheus, that 21st Century Schizoid Mess track is awesome! Shocked
I happen to be working on Tim Escobedo's PWM circuit at the moment
which also uses a LM386 and it's what I'm making the R2R-VCO for.
Guess I should do some tests with a divider between pins 3/4 too.
(why do these circuits always keep growing ?! Laughing )
jcintheus
PostPosted: Wed Jan 16, 2013 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, It's certainly a mess!
I'm not quite sure but I believe I used Tim's circuit as well.
Also I used the ubiquitous 4017/51 melody generator as the divider on pins 3&4 of the 4046,
with 3/4 of 1/2 of a 4015 on the ABC inputs of the 4051.(data on the 4015 fed by a 4006, a 74HC273, and a three XORs) Surprised
Plus clocks!
So yeah, they definitely keep growing!
ufokult
PostPosted: Sat May 25, 2013 4:42 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Hi! This is my first Lunetta build. Its very simple, with two 40106 oscillators and a 555 lfo/osc. In this SoundCloud link Lunetta is recorded with Monotribe, tube preamp, fuzz, delay and reverb.
https://soundcloud.com/automatonmusic/lunetta-diy-synth-through
jcintheus
PostPosted: Wed Jun 12, 2013 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
This is a very large piece with lots of Lunetta and other more conventional instruments.
I'm not sure this is the most appropriate spot for this but,
there's a resonable amount of DIY logic-type circuitry involved so...
 Filesize:  488.41 KB
 Viewed:  331 Time(s)
rumblin_cynth_rampo
PostPosted: Thu Jun 13, 2013 4:30 am    Post subject: Unlurk and a sample Reply with quote  Mark this post and the followings unread
Ive been lurking around here for a while and thought it about time I gave some thing back for all the stuff I have learned here.
So here is one of my pieces of cacophony. It was made using 4 40106 oscillators 2 of which get feed into a XOR gate which feeds a 4040. 8 random out puts of the 4040 feed into a 4051 multiplex inputs. The 4051's A B & C controller are fed by 2 of the 40106 oscillators with the 3 control coming from one of the oscillators feeding the XOR gate. The common in/out providing the output. A single track was recorded and then duplicated with a little bit of delay and reverb.
SO here is my Space Invaders' Boogie
Ian "Lemmy" Kilmister on Hawkwind;
"Like Brahms but violent."
https://soundcloud.com/rumblin_cynth_rampo
Draal
PostPosted: Sat Jul 06, 2013 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool sounds on that track rampo! Ahhh, Space Invaders; takes me back Cool
Zontar Prevails!
Audio files: 574
PostPosted: Fri Oct 25, 2013 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice looking stuff there jcintheus Shocked
will have a listen later.
Here's a section of something I recorded yesterday, while having some fun with my RGB Shrooms, some effects and a bit of PWM lunetta.
PHOBoS - RGB Shrooms and more Lunetta fun (Oct 24, 2013) - part 1.mp3
RGB Shrooms, effects and a bit of PWM lunetta
 Filename:  PHOBoS - RGB Shrooms and more Lunetta fun (Oct 24, 2013) - part 1.mp3
 Filesize:  6.72 MB
 Downloaded:  579 Time(s)
Audio files: 574
PostPosted: Sat Aug 02, 2014 6:35 am    Post subject: PHOBoS - ShiftSequence (Aug 02, 2014) Reply with quote  Mark this post and the followings unread
I wanted to make some sounds using the output from an R2R instead of a VCO which I mostly do, so I patched something up.
It has a shiftregister with the last bit fed back through an XNOR controlled by a tea candle LED (similar to the turing machine),
which in turn controls a mini melody generator (slacker). Cool
Could be expanded with the tea candle LED turned on/off by the divider (did that manually now). And another R2R to control the VCO
connected to outputs of the divider and or shiftregister. But I ran out of patch cables Rolling Eyes (have to fix some)
ShiftSequence Patch
 Filesize:  61.14 KB
 Viewed:  229 Time(s)
PHOBoS - lunetta ShiftSequence (Aug 02, 2014).mp3
 Filename:  PHOBoS - lunetta ShiftSequence (Aug 02, 2014).mp3
 Filesize:  6.05 MB
 Downloaded:  470 Time(s)
