Need help with design.
Page 1 of 1 [10 Posts]
isak
PostPosted: Thu Jan 17, 2013 1:51 am    Post subject: Need help with design. Reply with quote  Mark this post and the followings unread
Hi guys.
i'm in the prosses of building a synth, not mdular, semi modular.
im having a truble finding a way to control the 3 vco's cv's simulteneusly.
i will want to use 1 pot cv for all 3 vco's, is there any way to do it properly?
i know i can use a dual pot but it will give me to control only 2 vco's not 3.
is there any triple pot out there or any other solution?
if there isnt a good way i will have to pass 1 vco and i really dont want to do that.
the panel design is attched.
Isak E.
try14.pdf
 Filename:  try14.pdf
 Filesize:  492.87 KB
 Downloaded:  133 Time(s)
isak
PostPosted: Thu Jan 17, 2013 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I found a triple pot but not the value i need.
I found a 50k linear.
The question is...
In the vco design The pot is 100k and in series with 100k resistor.
Can I make the triple 50k pot in series with 150k resistor?
BTW the vco is Andy's Ody vco.
http://www.ebay.com/itm/4-Panel-PCB-Mini-Triple-Deck-B-50k-Potentiometer-P004-/220516287227?pt=LH_DefaultDomain_0&hash=item3357cb82fb
Osal
PostPosted: Thu Jan 17, 2013 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
The oscillators are CV, so you can control the three oscillators with a single potentiometer.
electronic-sea.net
isak
PostPosted: Thu Jan 17, 2013 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Really?
The pot I'm talking about is the cv input amount of the vco.
Are you sure that 1 pot will be ok as cv input for all 3 vco's?
Can you explain a bit more please?
syntherjack
PostPosted: Thu Jan 17, 2013 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hallo,
i don't know how your VCO CV input circuit looks like, but there is some possibility, that with just one pot for 3 CV the VCO's will interfere with each other. But you can always add op-amp buffer before each CV input, then drive all op-amp input from one CV source. I think it should work.
isak
PostPosted: Thu Jan 17, 2013 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks.
did you mean something like the attached scheme?
BTW this is the VCO..
http://electro-music.com/forum/phpbb-files/arp_odyssey_vco_layout_287.pdf
 Filesize:  25.13 KB
 Viewed:  83 Time(s)
syntherjack
PostPosted: Thu Jan 17, 2013 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, this is exactly what i mean.
http://www.arpodyssey.com/schematics/ody_32.gif
There you have 2 VCOs with connected CV inputs. Some are have just resistors, some diodes. So op-amp in not nesessary.
isak
PostPosted: Thu Jan 17, 2013 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
Smile
syntherjack
PostPosted: Thu Jan 17, 2013 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
No problem!
BTW
Nice goa there Smile
isak
PostPosted: Thu Jan 17, 2013 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Smile
Didn't do music for a long time now.
after our debut album we didn't do much.
Hope to get back to music soon, I miss that.
Day job is killing me.
Cheers man,
Isak E.
