Schrödinger II: The Cats Strike Back
Page 2 of 2 [40 Posts]
Goto page: Previous 1, 2
Audio files: 254
PostPosted: Wed Jan 02, 2013 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
found some info on how to make a PUT with an NPN + PNP here (haven't tested it yet myself, since I have PUT's).
And I recorded a drone thingy which you can find here
http://www.acidtrash.com/
Audio files: 254
PostPosted: Wed Jan 02, 2013 3:38 pm    Post subject: Schrödinger's Guinea Pig Reply with quote  Mark this post and the followings unread
trying some modulations with another PUT oscillator, but what i got now sounds more like a guinea pig Shocked
PHOBoS - Schrödinger's Guinea Pig.mp3
cucumbers
 Filename:  PHOBoS - Schrödinger's Guinea Pig.mp3
 Filesize:  528.13 KB
 Downloaded:  56 Time(s)
analog_backlash
PostPosted: Wed Jan 02, 2013 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've been on that site before, but I hadn't noticed the PUT bit. I've seen a very similar arrangement of NPN + PNP to explain thyristor action (which is also a four layer device), in my ancient copy of "A Practical Introduction to Electronic Circuits", which looks like this one:
http://www.amazon.co.uk/Practical-Introduction-Electronic-Circuits/dp/0521313120/ref=la_B001IZV9RY_1_1?ie=UTF8&qid=1357168494&sr=1-1
I got it as a school prize Rolling Eyes , but it's only recently that I've actually started reading it (rather than blindly copying the schematics).
I really like the sound of Schrödinger's Drone, especially the filtery swoops and the added background melody.
Not so sure about Schrödinger's Guinea Pig, but it's early days! I will have a play with the circuit again tomorrow and see what I can get it to do.
Gary
Audio files: 254
PostPosted: Thu Jan 03, 2013 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Smile, nice thing is that I didn't add a melody, it's all just added EFX, and that one is caused by a flanger.
I might add some more layers to it,. maybe some low drones and piano sounds.
I think it needs some more training, I did get some weird sounds out it by adjusting the pots to the point where it
almost stops oscillating. I'll see if I can record some of that. I was thinking of making a siren out of it (release of poison ?)
Also got something that sounds a bit like a geiger counter (to keep in line with the theme). ticks getting faster when
the LDR's get less light.
As for modulating the original Schrödinger II circuit, a simple 555 envelope generator comes to mind,
so you can set rise and fall times. Or maybe just using a transistor and some caps. then trigger it with some random
generator, could be teacandle LED(s) through a divider. (more then one combined to make it less predictable)
PostPosted: Thu Jan 03, 2013 8:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't had much time to play with this circuit nor read up on the link about PUTs. I like the timbre of this thing, but haven't figured out quite how I'd want to use it.
In the meantime, FYI, here's a scope shot of the pulses of one of the PUT oscillators, which were indeed harder to capture. I had to "zoom in" a lot... 5mV/s. and 5ms/div., and then it was a bit problematic for the camera to focus.
James.
pulses from a single PUT oscillator
 Filesize:  73.27 KB
 Viewed:  25 Time(s)
analog_backlash
PostPosted: Fri Jan 04, 2013 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I was wondering about that, because the sound was so subtle (especially early on) but by the end, I convinced myself that it was an added melody.
I am really going to have a look it again today (I went off at a tangent yesterday) and I'll have a look at your latest suggestions. I was also thinking about using the 1 transistor VCA from your Enneatronic Spectralizer and amplitude modulating it with a simple LFO.
You've captured the PUT pulses better than I managed to - they are tricky! On the subject of reading, I also rediscovered a document about triggering SCRs, which has a section about PUT oscillators (starting on p43):
http://legacy.littelfuse.com/data/en/Application_Notes/01_trigg.pdf
This document is probably a little OTT for this forum, but it may be useful to somebody.
Gary
Audio files: 254
PostPosted: Sun Jan 06, 2013 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
here are 2 schematics, first one is the original Schrödinger II circuit with the modifications I mentioned before.
the 10K pots to adjust the sound (pulse-saw) and the extra resistor, but I used 68K instead of 100K to get the signal
a bit louder. (you can decrease it further if you want it louder, maybe add a pot). The LDR's are connected a bit different
too, so you can kinda fade between pot-control or LDR-control. I also added a pot for the filter.
the second schematic is the siren circuit, nothing really special,. but since I've drawn it I might aswell post it here. Cool
Don't have it breadboarded right now else I could record a short demo.
Right now I'm trying some ways to modulate the pitch. Instead of connecting the Anode with a resistor
directly to the positive supply rail I added another NPN transistor (2n3904). With the Collector connected to
the positive supply rail and the Emitter with a 100K resistor to the Anode of the PUT. This worked but the oscillator
only starts from a fairly high input voltage. So I did some more reading and noticed this:
In this circuit the base of the transistor is held at 5v (with a 10v supply) by the two 1K resistors. Equal values give a 'stand-off ratio' of 0.5. Obviously this UJT is programmable so this ratio can be changed at will, say between 1K:10K and 10K:1K.
So I replaced the 18K resistor with a 100K and the 33K resistor with a 10K and got a much wider range now.
I will do some more experimenting with that setup and post results.
Original Schrödinger II schematic with PHOBoS mods
 Filesize:  24.24 KB
 Viewed:  25 Time(s)
emergency, emergency
 Filesize:  18.99 KB
 Viewed:  24 Time(s)
analog_backlash
PostPosted: Mon Jan 07, 2013 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi PHOBoS,
I've just tried out your new version of the Schrödinger II and it does sound better than the original (apart from the fact that I'm sometimes getting a bit of distortion - it may just be dodgy breadboarding, as I rushed it a bit).
Sounds like an interesting idea. I was modulating the PUT oscillators simply by passing a low frequency modulation source directly to the anodes of the PUTs. It works, but it's probably not the best way of doing it. I was using a 555 as the 'LFO' which was low-pass filtered by a resistor and a capacitor, to give charge/discharge curves rather than a rectangular wave. This was for test purposes only. It's not a good LFO, as you need to change the R and C values as you adjust the frequency!
Gary
Audio files: 254
PostPosted: Mon Jan 07, 2013 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gary
That's pretty much the same as I'm doing except for the transistor, which has a high input impedance and low output
impedance. However the circuit itself allready isn't really low impedance, so modulating it directly (especially with a 555)
should work, except that you might get a small range like I did before I adjusted it. I also added a capacitor for a glide
effect (this is where the transistor comes in handy), just labeled C since it's value is dependent on your own
preference. Maybe a rotary switch with a couple of caps and/or a potentiometer in series is useful here.
Anyway here's the circuit for one oscillator, (I left the filter out of the schematic). you could feed a modulation
signal to the 500K pot at the point where it's connected to the LDR/Switch. (Leave those out is you do or use a diode in series)
O and I left the 10K waveshape pot out of this one since it reduces the range quite a lot.
 Filesize:  8.82 KB
 Viewed:  1477 Time(s)
Audio files: 254
PostPosted: Wed Jan 09, 2013 4:42 am    Post subject: The cat is still alive Reply with quote  Mark this post and the followings unread
Did some minor changes and added a 1 transistor VCA, or maybe it should be called an LCA Cool
(resistor values depend on the used LDR and your own taste)
Schrödinger II circuit with buffered range control and 1 transistor VCA.
 Filesize:  13.89 KB
 Viewed:  23 Time(s)
analog_backlash
PostPosted: Wed Jan 09, 2013 4:06 pm    Post subject: Re: The cat is still alive Reply with quote  Mark this post and the followings unread
I'll probably have a go at this tomorrow. Haven't been feeling too great over the last few days (some kind of bug, but thankfully, not the winter puker bug) so I haven't felt up to doing much. I did try a single transistor VCA after the filter, but not much happened and feeling crap, I gave up. It usually is down to a stupid mistake I've made, when something doesn't work. Hopefully, my brain might be firing on a few more cylinders tomorrow.
Are you planning to use tea-light LEDs on all/any of the LDRs or are you using the waving hands approach?
Gary
Ralphperez
PostPosted: Thu Jan 10, 2013 12:46 am    Post subject: Re: Schrödinger II: The Cats Strike Back Reply with quote  Mark this post and the followings unread
This circuit came about while I was thinking about buzby's stripboard challenge:
http://electro-music.com/forum/topic-55837.html
I never did think of any great ideas (which would fit on 5 x 6 holes piece of stripboard), but it did start me playing with PUT oscillators, as you only need a single PUT to make one. What I did eventually produce (only on the breadboard at the moment) was the circuit below. Because the PUT oscillators produce very narrow spikes, the sound is a bit whiny and rather cat-like. To enhance the cattiness, I mixed the output of two PUT oscillators and passed the output into a twin T filter. The frequencies of all 3 parts are controlled by
led lighting, so by waving your hands over it, you can get quite annoyingly accurate cat-like sounds. The two pots (actually presets on the breadboard) are only there for fine tuning and are not strictly necessary. I built it for a 12V supply, but it does work on a 9V battery.
I've put it here just out of interest, as it may (or may not) inspire someone to come up with a more musical effect.
Gary
P.S. I know it's not strictly a lunetta, but you could use CMOS oscillators in place of the PUTs, if you wanted to (but would it be as catty?).
Hey thanks for sharing circuit. Very helpful in network analysis
Audio files: 254
PostPosted: Sun Jan 13, 2013 7:37 pm    Post subject: The cat is still alive Reply with quote  Mark this post and the followings unread
For now I think I will go for the waving hands welcome and probably some modulation inputs. I didn't find the teacandles
too interesting as a modulation source, probably because you can hear them very well in the signal. But I have plenty
of PUT's to play with so maybe I make a teacandle version, with a bunch of them it might get interesting.
But at the moment I'm distracted by a PWM circuit, so I'm not sure what I'll finish first Wink
analog_backlash
PostPosted: Thu Jan 17, 2013 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I've finally got round to to trying out the Schrödinger II - V circuit that you posted. I found that I had to make some minor changes, as I bought some more (cheap) LDRs and they have different characteristics to my older ones (lower resistance, basically). At the moment, I've got 2 of your circuits feeding into the LCF (if you can have an LCA, I can have an LCF). I'm also experimenting with my 555 LFO frequency modulating the 2 oscillators. I'm going to try replacing the 555 with a 4069UBE LFO, as I think this might give better results.
The problem is, that I now have 5 LDRs to "play" and on a breadboard, it's hard to modulate one without affecting the others to some extent. I might actually have to put it in a box eventually...
If I get any good results, I'll post them.
Sorry for the late reply and thanks Very Happy
Gary
Audio files: 254
PostPosted: Thu Jan 17, 2013 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
sure you can have your LCF Very Happy
It's indeed tricky to play without effecting the others, I allready had the same problems with only 3 LDR's on a breadboard.
And yes they can respond quite different, I think the ones I have have a minimal resistance of ±2K.
As for the oscillator, I'm currently playing around with a 4046 again, and it's surprisingly easy to use, just a cap and resistor/pot
and you got a VCO (modulate the modulator Wink) and you get some nice bonus features too.
Niio2
