Logic gate/switch
Page 1 of 1 [8 Posts]
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Mon Apr 11, 2005 7:42 pm    Post subject: Logic gate/switch Reply with quote  Mark this post and the followings unread
I was wondering if there are any logic boffins that can help me out with this...
I want to build some kind of struture that lets a signal pass only while you're moving a knob. So lets say you have a constant value knob. If you leave it alone no audio will pass. As soon as you start moving it, the logic structure maybe sends out a gate to let the envelope let audio/signal through.
I thought maybe getting the difference between the current knob position and the one 10ms ago using logic and delay modules could work... So I mucked around with some compare modules, but they're all >= and not just > so I can't get the difference between the current knob position and the knob position 10ms ago. I know I'm missing something here...
edit: I abandoned the compare modules idea, and went for the sum of the original signal, plus the original signal inverted and delayed. This works if I move the knob anti-clockwise, but not clockwise... why?? Mad
Gate.pch2
experimental gate
 Filename:  Gate.pch2
 Filesize:  925 Bytes
 Downloaded:  1768 Time(s)
Audio files: 277
PostPosted: Mon Apr 11, 2005 7:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
The basic idea is good.
I's more convenient to subtract the signal and it's delayed version in a mixer/mix2-1b module with one input set to invert. When you then route this through a shaper/rect with the 3rd button pressed it will work for both knob directiions and then you're nearly there.
Jan.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Mon Apr 11, 2005 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I edited my post then saw yours. I added in the rectifier module on double positive and it works for negative values but not positive ones. I'm happy with this, but is there any way I could make it work with positive ones as well?
Gate2.pch2
gate2
 Filename:  Gate2.pch2
 Filesize:  969 Bytes
 Downloaded:  1648 Time(s)
Audio files: 277
PostPosted: Mon Apr 11, 2005 8:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
There seems to be some audio rate racing going on, don't understand it but using a s&h to slow things down seems to do the trick.
Sorry hadn't tried it, just used some old NM knowledge.
Jan.
gate2-1-1.pch2
knob movement detection
 Filename:  gate2-1-1.pch2
 Filesize:  966 Bytes
 Downloaded:  2410 Time(s)
davep
Audio files: 10
G2 patch files: 73
PostPosted: Mon Apr 11, 2005 9:45 pm    Post subject: Re: Logic gate/switch Reply with quote  Mark this post and the followings unread
I want to build some kind of struture that lets a signal pass only while you're moving a knob.Mad
Aaahh, you're sooo close Smile
This puzzle came up a while ago in the old NM list. Try this:
Assign the knob to a "Level" module knob ("Constant" module in NM1 speak).
Now patch this knob signal to one input of a mixer, and also patch it to the input of a portamento or lag module.
Now patch the lag output to another input of the same mixer, and invert this input. This will result in a momentary "bump" of DC signal when the knob is moving, because the two signals won't exactly cancel out while the knob is moving.
Now, connect the mixer output to a rectifier, set to "full pos" (two positive humps). This will make the DC bump go positive, regardless if the knob is moving up or down.
Now patch the output of the rectifier to the input of a "Compare to Level" module, set so that it generates a pulse whenever this input is greater than zero.
Tadaa ! Now you can use this pulse to trigger or switch stuff automatically whenever the knob is moving!
Dave Peck
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Tue Apr 12, 2005 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Fantastic, thankyou very much guys Very Happy. Both solutions work! I'm gonna go post this into the building blocks...
Audio files: 277
PostPosted: Tue Apr 12, 2005 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for doing so.
Jan.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Apr 12, 2005 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have been using davep’s solution for a long time (thanks Dave), not for knob movement, but other applications like triggering on a random value change etc.
This thread made me think what the circuit did to audio rate changes so I looked and it is just a differentiator or high pass filter, so I tried using the simple 6dB highpass set to max frequency and it supplies a neat, 1 module solution to the problem. Although it uses only one module, the other two solutions offer better efficiency dsp & zero page memory wise.
knobgate3.pch2
more cat skinning
 Filename:  knobgate3.pch2
 Filesize:  869 Bytes
 Downloaded:  1849 Time(s)
