Opinions needed - Arturia Minibrute vs MFB Kraftzwerg
Page 1 of 1 [5 Posts]
patrickvf1976
PostPosted: Tue Jan 08, 2013 1:43 pm    Post subject: Opinions needed - Arturia Minibrute vs MFB Kraftzwerg Reply with quote  Mark this post and the followings unread
Both are in the same or similar price class, both are analogue, both are very flexible and programmable. What is your opinion if you had to decide between the two?
Audio files: 29
PostPosted: Tue Jan 08, 2013 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
It think it depends on what you need/want.
The MFB Kraftzwerg is semi-modular and patchable.
The Minibrute has a keyboard (with aftertouch I think) and an arpeggiator.
Plus they both sound different. Listen to demos online and try to figure out which one will fill a void in your current selection of gear.
jacobwatters.com
patrickvf1976
PostPosted: Tue Jan 08, 2013 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can the Microzwerg also function as a controller and Midi 2 CV converter? I know the Minibrute doesn't send midi messages other than note on/off. I always wanted a (semi) modular synth but the Minibrute also seems to be a pretty cool synth although it has only one OSC, but it has features that most other synths don't have plus it has the Steiner-Parker filter. I would be tempted to get both, but I would have to dip into my college funds and I'd rather avoid that. Hmmm decisions, decisions..
PS: is the Microzwerg now a fully analog or virtual analog/analog modeling synth? I know I said they were both analog but I didn't find any mentioning about it, so I assumed that it has a fully analog signal path
anigbrowl
G2 patch files: 5
PostPosted: Wed Jan 23, 2013 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Now you need to consider the new MS-20 as well Cool
patrickvf1976
PostPosted: Wed Jan 23, 2013 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Welll... I got the Microzwerg, mainly because I like to experiment and it's a (semi) modular synth for a relatively low price, however I'm still looking into getting the Minibrute, but now I'm conflicted between that, a Realistic MG1 and a Yamaha CS15. However $800 for the Yamaha seems a bit high. Hmmmm...
Niio1
