Akai AX-60 problem with noise generator
Page 1 of 1 [4 Posts]
patrickvf1976
PostPosted: Tue Jan 15, 2013 11:54 pm    Post subject: Akai AX-60 problem with noise generator Reply with quote  Mark this post and the followings unread
My Akai AX-60 has a problem with the noise generator - the noise generator's output has become extremely low all of a sudden and I can't figure out what happened. It was working just fine yesterday and I was able to make some nice thunder and swoosh kind of sounds. Now it struggles to get to a reasonable volume. Everything else works just fine. Any ideas what could cause this problem?
patrickvf1976
PostPosted: Sat Jan 19, 2013 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
So.. any suggestions, advice, anything? Anyone? Help??
patrickvf1976
PostPosted: Tue Jan 29, 2013 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Still could use some help here. Any hints what to look for or even some schematics would do.
sneakthief
PostPosted: Tue Jan 29, 2013 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://manuals.fdiskc.com/flat/Akai%20AX-60%20Service%20Manual.pdf
first hit on google Razz
Either 1) the noise generator isn't working or 2) the circuit that turns off both noise generators for Noise A and B. 1 seems more likely.
page 40 says that TR4, TR5 and IC21 are responsible for the noise
On page 37, you'll find the noise schematic. It uses these parts:
IC21: BA715STD
TR4: 2SC 3330
TR5: 2SC 3383
Check along the signal path to see if you're getting noise. The schematic lists voltages next to the ECB's of the transistors - that's a good and easy place to start to see if either are blown.
Sneak-Thief - raw electrofunk
Niio2
