stahlblau
Joined: Jan 24, 2008 Posts: 14 Location: Herford / Germany
Posted: Sun Nov 04, 2012 10:03 pm Post subject:
I would like to take two main pcbs please
thank you! Last edited by stahlblau on Wed Nov 07, 2012 8:51 am; edited 1 time in total |
Posted: Mon Nov 05, 2012 12:02 am Post subject:
| Danno Gee Ray wrote: | Fonik,
What kind of pots did you use on your prototype?
Thanks,
Dan |
i used 9mm alpha.
you don't need threaded bushing. the sockets will hold the PCB in place. _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1332 Location: Telford, PA USA
Posted: Mon Nov 05, 2012 7:45 am Post subject:
| thanks. |
ungleichklang
Joined: Dec 03, 2011 Posts: 63 Location: East-Belgium
DES
Audio files: 6
Posted: Wed Dec 05, 2012 9:24 pm Post subject:
Received my boards today! Look real good
Quick question....what brand/model trim pots did you use? _________________ Dave
www.davesneed.com
www.myspace.com/desneed |
stahlblau
Posted: Fri Dec 07, 2012 2:48 pm Post subject:
Boards arrived
Thank You |
donpachi
Posted: Sun Dec 09, 2012 1:44 am Post subject:
Boards are here
As usual, thanks a bunch for outstanding projects, Matthias!
EDIT: I'm soldering components ATM in an attempt not to accumulate any more backlog. Is it correct that there is no D2 on the board? Obviously, function is not impaired, so should I piggyback it onto R44 or just leave it out of the circuit? |
Posted: Sun Dec 09, 2012 1:29 pm Post subject:
| donpachi wrote: | | EDIT: I'm soldering components ATM in an attempt not to accumulate any more backlog. Is it correct that there is no D2 on the board? Obviously, function is not impaired, so should I piggyback it onto R44 or just leave it out of the circuit? |
D2 is not needed. trigger out works fine without it. _________________
fonitronik at
roborobert
Posted: Tue Jan 15, 2013 1:52 pm Post subject:
stumbled across this yesterday, looking for components for a new proper synth - seems like the perfect lfo for me. thanks a lot for this brilliant work and offer!
so here's my first post
i'd like two circuit pcb's
grüße, robo |
LektroiD
Joined: Aug 23, 2008 Posts: 960 Location: Scottish Borders
Posted: Sat Jan 26, 2013 1:57 am Post subject:
How did I miss this? If there is a slim chance of any main boards left, I'd be very interested in a couple... _________________ My tunes available here
(check out the new Electro-Funk LP) |
TheProf
Joined: Dec 26, 2006 Posts: 146 Location: United Kingdom
Posted: Mon Jan 28, 2013 1:37 pm Post subject:
I'd been away for a few days and found the boards waiting on my return. Really good looking boards; lovely work, (as always!).
Thanks again. Fonik. _________________ Mike |
Posted: Tue Jan 29, 2013 1:32 am Post subject:
| LektroiD wrote: | | How did I miss this? If there is a slim chance of any main boards left, I'd be very interested in a couple... |
you did not miss anything, actually. for the current small re-run i ordered a few spares (as always).
so what do you need/want? i offer 3 aprts this time:
the actual circuit board,
an eurorack front panel components PCB, and
an eurorack front panel (printed). _________________
fonitronik at
LektroiD
Posted: Tue Jan 29, 2013 2:47 am Post subject:
| fonik wrote: | | LektroiD wrote: | | How did I miss this? If there is a slim chance of any main boards left, I'd be very interested in a couple... |
an eurorack front panel (printed). |
I would like 2 main PCBs. If it's not too much trouble, would it be possible to wait for the 555 VCOs and combine shipping? _________________ My tunes available here
Heavy Metal Kid
Posted: Wed Jan 30, 2013 10:49 am Post subject:
If there still are spares, I would like:
1 actual circuit board
1 eurorack front panel components PCB
1 eurorack front panel (printed) |
samuron
Posted: Fri Feb 08, 2013 3:27 pm Post subject:
the new PCBs came in today! however, i am still waiting for the front panels.
so:
i will now start to contact all who placed pre-orders for PCBs only, providing payment info's.
i will combine shipping and packaging for all who placed orders for both the VCO and the LFO.
please be aware, i am currently selling 4 different PCBs + front panels. there are quite a few orders to fullfill. i hope you are patient with me. it might take a while until i contact you, and packaging and mailing will take a little bit longer than usual, i guess. _________________
fonitronik at
samuron
Posted: Fri Feb 08, 2013 8:38 pm Post subject:
| fonik wrote: | | wow, that looks awesome! but it quite a lot of work, isn't it? how many panels had you to make until you got this nice result? |
Actually, that was the first try; I lost some detail on the finer lines, and I'll try some wider ones.
It's really not too much work; it's kind of a decal version of Press 'n Peel Blue.
You print the design on the decal paper, laminate it to the white material, peel the white material off, clean off the excess (that's where I'm removing too much material), laminate a clear carrier material onto it, soak the paper off, spray on the glue, and then stick it to the panel. Start to finish, the first one took maybe 20 minutes.
If I can keep from losing bits of the design, it should be a good process. |
lucid
Joined: Dec 03, 2012 Posts: 16 Location: Slovakia, EU
Posted: Sat Mar 02, 2013 3:40 am Post subject:
Hi fonik
I can see on picture that also here you are using 50k trimmers instead of 25k (similar as you propose for VCO-555).
So I assume that it could work also on 15V.
I have also some spare 47k, can I use them also as replacement for these 25k? |
Posted: Sat Mar 02, 2013 5:09 am Post subject:
| lucid wrote: | Hi fonik
of course you can. you could even use 100k. it is wired as a variable resistor, not as a voltage divider. the problem is that you will have less of usable range. when trimming (not a big issue with 25-turn precision trimmers). _________________
fonitronik at
LektroiD
Posted: Wed Mar 06, 2013 6:02 am Post subject:
I can't seem to source the 2n5461, anyone know of an equivalent (would J112 work?). If not, has someone got one I could buy? _________________ My tunes available here
