  PHOBoS presents: Deep Journey 3 {Going Deeperer}
Nord G2 editor not working while using a JazzMutant Lemur?
Page 1 of 1 [4 Posts]
paugui
G2 patch files: 37
PostPosted: Fri Feb 01, 2013 4:21 am    Post subject: Nord G2 editor not working while using a JazzMutant Lemur?
Subject description: Previously called "Nord Modular G2 Engine USB Problem"
I had never had a single problem with my Nord Modular G2 Engine, but today I wanted to use it to test my new JazzMutant Lemur.
Unfortunately, when I connected it to USB to the computer, I can't get the USB light to turn on and there is no response from the Editor either.
I tried to turn it on and off a couple of times, and no change...
I also tested the cables and the USB ports in the computer with other gear, and they work just fine.
I know I used it the last time a month or so ago and couldn't find any signs of the USB failing.
I think I remember seeing posts about that, but couldn't find them here...
Can it be just some soldering problem, or something more serious, since there were no signs of a problem before?
If it's more serious, what can be done to solve it?
Thanks in advance and
All the best
Paulo
paugui
G2 patch files: 37
PostPosted: Fri Feb 01, 2013 4:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Upon further tests, it seems it's working well...
I think the problem might be some incompatibility with my Lemur?
I noticed that my G2X wasn't working either and that would have to be too much bad luck...
I restarted the computer and it seems it's working well now...
Anybody else here tried to use the G2 together with a Lemur and found the same problems?
Audio files: 218
G2 patch files: 319
PostPosted: Fri Feb 01, 2013 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
It may not be related to the Lemur ... occasionally the G2 USB driver will just crash ... I just reboot the computer when that happens.
paugui
G2 patch files: 37
PostPosted: Fri Feb 01, 2013 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe it's that then...
I thought it could be the Lemur cause with the Wifi on, it sometimes has troubles connecting...
And since it never happened to me before, I thought it could be related...
But fortunately everything is working well now Smile
