wahoah
Posted: Wed Jan 30, 2013 5:53 pm Post subject:
Any simple bass drum schematic? or snare? |
Hi!
Ive been serching for a simple bass drum schematic and havent find anything, a snare could be great too or a hi hat
anyone have one? |
-minus-
wahoah
-minus-
-minus-
Tony Deff
Posted: Sun Feb 03, 2013 10:34 am Post subject:
Re: Any simple bass drum schematic? or snare? |
| wahoah wrote: | Hi!
I've been searching for a simple bass drum schematic and haven't found anything; a snare could be great too, or a hi hat.
Anyone have one? |
Aloha, Wahoah,
I built a very passable set of 8, way-back in the previous millenium, from a design published in Practical Electronics here in the 51st State.
I may still have it, but don't fancy re-drawing the schematics from the original stone-tablet carvings.
Whilst quickly looking to see if was archived on-line, I came across this set of Carillon (The bells! The bells!)
Everyday Practical Electronics 2008 PDF (scroll down to page 35).
Hells bells. |
-minus-
Posted: Mon Feb 04, 2013 2:14 am Post subject:
Thers some reasonabell chimes to be had from Ken Stone's Chime Simulator...
http://www.cgs.synth.net/modules/cgs19_chime.html
I built this and the bells are quite convincing although not easily retuned.
Or for a kick sound you could try Eric Archers Mini Space Rockers...
http://ericarcher.net/devices/mini-space-rockers/
I built this too. There are three caps you can experiment with to get a variety of tones. This is a simple circuit and easy to breadboard and play around with. There are some sound files on Eric's site with various cap sizes and the sounds they create. I couldn't make my mind up on the caps so I used three twelve position rotary switches... giving me... 12 X 12 X 12 variations  |
Joined: Jul 11, 2005 Posts: 4737 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Mon Feb 04, 2013 5:16 am Post subject:
Don't forget Thomas Henry's MPS. It is a lot of kit for 1 drum, but it definitely allows for everything. 3partials/RM/Noise filter.
It's a very small board too, laid out by yours truly!  _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
wahoah
Posted: Thu Feb 07, 2013 9:01 pm Post subject:
ive just breadboarded the Bass Drum from the monotribe korg, i like it but i need a little more bass and deeeper sound
any recomendations? |
-minus-
Posted: Thu Feb 07, 2013 10:54 pm Post subject:
| wahoah wrote: | ive just breadboarded the Bass Drum from the monotribe korg, i like it but i need a little more bass and deeeper sound
Try a few different transistors, even of the same type. I replaced the quite a bit until I found one I liked. Have you used a decay pot? That will give it more boom. The other option is to try a more complex circuit like the 808. You'll need a bipolar power supply to run it though. |
wahoah
-minus-
Posted: Thu Feb 14, 2013 1:45 pm Post subject:
| Yes, that is correct. Is it having no effect for you? |
KRS1972
EATyourGuitar
Joined: Oct 28, 2010 Posts: 44 Location: Providence, RI
Posted: Wed Mar 06, 2013 6:58 pm Post subject:
| what you want is a simple sine VCO and a monostable source like a 555 RC lowpass'd to get a decay envelope. your envelope controls the pitch of the sine wave. you can skip the VCA if you just high pass the bass drum sound right around 100hz. that should give you a nice fade out from a single envelope. |
