Linn Drum Slide pots
Page 1 of 1 [4 Posts]
pdman1
PostPosted: Fri Jan 25, 2013 8:18 am    Post subject: Linn Drum Slide pots
Subject description: Linn Drum Slide pots
Does anyone know of any replacement slide pots for the LinnDrum? Both the smaller balance pots and the larger Volume pots.
Thanks
pdman1
PostPosted: Mon Feb 04, 2013 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Bump...
analog_backlash
PostPosted: Wed Feb 06, 2013 2:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi pdman1,
Just did a bit of searching and found the Forat website:
http://www.forat.com/drummachines/
This says that they supply replacement parts, but I couldn't see how much they charge for them. It might be worth contacting them and then saying "HOW MUCH!!" Laughing
Gary
pdman1
PostPosted: Wed Feb 06, 2013 10:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks AB
Should have remembered them . I'm calling on Thursday.
Has anyone had the issue where the sliders don't make good contact internally when they are at either end of travel?
I have a LD in for repair and about 1/3 of the pots exhibit this issue.
