AniModule Voltage Controlled Scanner/Switch
JRock
PostPosted: Tue Feb 05, 2013 10:43 am    Post subject: AniModule Voltage Controlled Scanner/Switch Reply with quote  Mark this post and the followings unread
Hey guys. I just got this all uploaded on my site
Voltage Controlled Scanner/Switch at AniModule.com
I posted the:
schematics
TopPlace
BottomPlace (there's a few SMD Components. The caps and resistors are 1206 and the ICs are SOIC. I solder them by hand no problem.)
TonerTransferEtch
BOM
and the ZIP file with everything
*2/6/13[Correction]
On the TopPlace it shows 2N3906 PNP transistors. This is Wrong. They need to be 2N3904 NPN transistors and installed 180 degrees rotated from what is shown on the TopPlace.
I hope you take a peek at them and find them useful :tu:
It's based around a SSM2164 and an LM3914 (both of them are through hole, so make sure to SOCKET them!)
Here's a little demo of it in action:
