  electro-music.com June Sostice Concert Various Artists
NM1 Editor On Win8?
Page 1 of 1 [7 Posts]
MR-808
PostPosted: Sun Feb 10, 2013 1:37 am    Post subject: NM1 Editor On Win8? Reply with quote  Mark this post and the followings unread
Has anyone tried it yet? A friend runs it on an old XP-based Fujitsu laptop with a built-in Wacom touchscreen, and he says the NM1 editor works great on it. I'm wondering if it would be worthwhile to buy a new Win8 tablet or ultrabook or not.
Vader77
PostPosted: Sun Feb 10, 2013 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
You have to run it in Win98 mode but it works fine Smile
I found you have to lower the screen resolution to make the UI more touchscreen friendly but it does work on my Acer z5600.
I also use an old iTronix Gobook2 (on XPlite) with a military spec resistive touch screen that's very responsive as long as you don't chew your nails.
secretkillerofnames
PostPosted: Mon Apr 29, 2013 8:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
So that is a yes for Windows 8?
I'm contemplating getting a tablet to use the editor with NM1 Rack.
Any other reports / issues?
Vader77
PostPosted: Tue May 14, 2013 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use mine with an Acer z5600 touch screen with win8, its a bit clunky with sliders but buttons work ok.
The trick is lowering the resolution so the parameters are easier touch as such.
I still think the Itronix gobook works better tho you need a good fingernail to press on the resistive screen.
secretkillerofnames
PostPosted: Tue May 14, 2013 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think those GoBooks are a stateside phenomenon only. Haven't seen any evidence of them down here in Australialand. Very Happy
I plan to get a cheap Win8 tablet - so long as it has the USB to run my MIDI interface I figure it would be useful to integrate with my NM 1 rack.
Good news!
secretkillerofnames
PostPosted: Tue May 14, 2013 9:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thinking either the Asus EEE Pad ME400C or the Acer Iconia W510 might do the job.
secretkillerofnames
PostPosted: Fri May 17, 2013 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
A question for those of you using touch-screens...
I'm having issues connecting the red square outputs to red circular inputs. Using a stylus with the Iconia tablet it is possible to connect other types of connection (though magnification helps) but seems it wont connect the OSC outputs whatever I do. I've managed to get a cable coming from the square outs but it never creates a connection.
Anyone have any work-arounds?
Seems the same problem exists with the G2 demo. If i plug a mouse in it works and I also get to see the little plug icon.
