MFOS VCO PWM problem
Page 1 of 1 [3 Posts]
The Bad Producer
PostPosted: Sun Feb 17, 2013 6:05 am    Post subject: MFOS VCO PWM problem Reply with quote  Mark this post and the followings unread
Hello people,
Hoping someone can chime in and help!
I've just built the MFOS VCO, with recommended part changes for 15v operation, and all is working as it should, apart from one important thing!
The PWM seems to be buggered, if the PWM pot is turned all the way CCW then I can hear all waveforms apart from PULSE output, when I turn the pot CW the PWM seems to affect the timbre/frequency of all the waveforms until at a certain point the VCO stops oscillating (dies basically) until I turn the pot back CCW... It's like the PWM stops the core working above about 60%?
The PULSE out works when pot is just off CCW and again, PWM affects the output until it dies (around 3 'o'cock)
I've double checked parts/wiring/reheated solder etc.. I'll keep probing today with the scope, but it does seem odd to me!
Any ideas?
Shall I just dump the PWM feature?! hahaha
Charlie
http://soundcloud.com/thebadproducer
PostPosted: Sun Feb 17, 2013 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
You're checking the right stuff...you might look at component values too. I've had some really silly mistakes in some boards that I looked at repeatedly until I realized what was wrong.
The Bad Producer
PostPosted: Sun Feb 17, 2013 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi elmegil, thanks, but yeah - I printed out the component overlay and went through with a magnifying glass double checking and ticking off!
Slightly confusing with the different revisions of the PCB's too, but I think I'm on the right track... Just built the CGS VCO too, and no problems with that, even though it is a slightly more complex build!
