teevee
egw
Joined: Feb 01, 2003 Posts: 1506 Location: Asheville NC
G2 patch files: 8
Posted: Sun Feb 17, 2013 11:35 am Post subject:
If I recall correctly the traveler actually controlled something like filter cutoff. _________________ www.gregwaltzer.com |
Joined: Apr 01, 2004 Posts: 2519 Location: Auckland, New Zealand
G2 patch files: 584
Posted: Sun Feb 17, 2013 12:13 pm Post subject:
| egw wrote: | | If I recall correctly the traveler actually controlled something like filter cutoff. |
Yes. More expensive Korg synths had two sliders with semi-interlocking knobs. One for the lowpass, one for the highpass. The interlock ensured you couldn't set the HP frequency higher than the lowpass frequency.
I'm pretty the M500 had a pitch eg on the voice preset. Each note would glide up from a half tone below (sort of Tomita-ish) |
teevee
Posted: Sun Feb 17, 2013 1:02 pm Post subject:
Hello egw and ian-s – Thanks for your answers. I will start saying that this is my first trying to make a emulation from “zero square” so this is something new but hopefully also very learn full for me.
I have build it up only by looking at the circuit (Block diagram) and the front panel, then trying as good as I can – but it’s not possible to avoid that Nord Modular would offer some extra options with its modules and yes Korg M-500 was a cheaper synth by Korg in the late 70s compared to Korg ms-10, Korg ms-20 and other.
Looking at the block diagram is “traveler” placed over the preset selection and beside the “fixed tone” – how can I make my idea more realistic to the real deal from what I have made until now?
All ideas and suggestions would be gold for me – You’re also very welcome to open this patch in your editor and show some corrections
TeeVee |
egw
G2 patch files: 8
Posted: Mon Feb 18, 2013 3:50 am Post subject:
My interpretation of the block diagram is that the traveler applies to synth1, synth2, and brass. Similarly, the envelope controls apply only to the synth settings, not the other sounds. But you don't necessarily need to keep these restrictions in the emulation. _________________ www.gregwaltzer.com |
teevee
Posted: Mon Feb 18, 2013 10:05 am Post subject:
Okay this traveler function doesn’t seems important at the moment and I can always make a implementation later.
What about:
1. Modulation (with rate and depth)?
2. Repeat/random repeat – should be with 2 functions:
- One that repeats the note, you hold down
- One that makes a random note trigger when you hold a key.
Note: The modulation rate should also set the tempo of repeating the note.
3. How did I use the portamento module in this`?
egw
G2 patch files: 8
Posted: Tue Feb 19, 2013 7:26 am Post subject:
You really need to find someone who has one to give you sound samples. An emulation that captures the routing architecture but not the sound characteristics wouldn't be very interesting. It's been a long time, but I don't think the random repeat plays random notes (like a sample & hold). Rather, it played notes with a rhythm that had some variation to it (but not truly random). Also, the traveler was really the one function that made this feel like a "synthesizer" rather than a keyboard with fixed presets. I wouldn't have bothered with it without that feature.
Modulation rate and depth controls the speed and amount of the two types of vibrato - pitch and traveler (filter).
Portamento is applied to the pitch e.g. a "glide" from the previous note to a new note when it is played. There are different types of portamento (fixed rate or fixed time, linear or exponential). I don't recall which the micro-preset used. _________________ www.gregwaltzer.com |
teevee
Posted: Thu Feb 28, 2013 12:40 pm Post subject:
Korg SB-100 had also this "traveler" function.
