  bingsatellites Mostly Ambient
Stereo delay / Vibrato
Page 2 of 3 [57 Posts]
Paradigm X
PostPosted: Fri Feb 22, 2013 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
papaver wrote:
I think that mountain switches are a good choice. a bit expensive but good quality. I have to check if there are avaliable in DPDT and 3PDT and go for them in Mouser.
I'm not sure about the pactec cases, I want to keep a compact format and metal cases. But I have to look at the dimensions of the PT8, maybe it feets perfectly, I don't know.
anyway tomorrow will be a nice day to keep working on thiS!
Cool man, well let me know if I can help in any way.
Cheers, Ben
papaver
PostPosted: Fri Feb 22, 2013 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
The thing is that I'm using the same pots and switches of the sympleseq... there is enough room for open jacks but I don't like the small presence of the pots in the panel. Too little space for the knobs and ugly movement.
I just need to change the knobs for taller ones. Smile
 Filesize:  3.09 MB
 Viewed:  24 Time(s)
papaver
PostPosted: Fri Feb 22, 2013 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
RV141F-40E3 seems a good choice. Is 25mm long so the pot will be like 1cm long from the panel.
http://www.mouser.com/ds/2/13/RV141F-40E3-18BL-BXXK-185110.pdf
The only cont is that the body is different and I have to adapt all the PCB, but it will not be a big problem.
papaver
PostPosted: Fri Feb 22, 2013 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
And it uses washer and nut, so the whole machine will be more solid.
Paradigm X
PostPosted: Fri Feb 22, 2013 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool man. Seems youre well on top of it.
Very much looking forward to it.
Cheers, Ben
papaver
PostPosted: Sat Feb 23, 2013 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
They don't have the 100k audio value. I've been searching for 25mm long pots and there is no option for 5k 50k 100k lin and log. Mad
The only options I can see now are conitnue with the existing ones or going to something like this http://www.banzaimusic.com/Alpha-16-PC-ANG-100k-log.html. It's stronger and more solid but it means to adapt all the PCB and depending on Banzaieffects for now.
papaver
PostPosted: Tue Feb 26, 2013 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Solved with the tapering method from geofex masters. http://www.geofex.com/article_folders/potsecrets/potscret.htm
Definetly I will go for the RV141
Rolling Eyes
elektrouwe
PostPosted: Tue Feb 26, 2013 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi Papaver,
I have send PM to you couple of days ago. Did you see ?
papaver
PostPosted: Wed Feb 27, 2013 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
hi Papaver,
Right now Smile
papaver
PostPosted: Tue Mar 12, 2013 1:35 am    Post subject: Reply with quote  Mark this post and the followings unread
A few minor improvments and silkscreen to do but this is close to the final version. I smell a rat
 Filesize:  3.06 MB
 Viewed:  13 Time(s)
Paradigm X
PostPosted: Tue Mar 12, 2013 2:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Yay! awesome.
Those are really cool knobs too
Well looking forward to this.
papaver
PostPosted: Tue Mar 12, 2013 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I want to add a few trimmers per channel. Two of them will adjust the feedback limits at the 2 switch positions. It's difficult to set the same value for the two ch with a resistor so the trimmer will be very usefull here.
The other one or two will control the filter frecs. Now I have filtered lots of unwanted noises from the chip but also losts of hi freqs are filtered but maybe you want all the noises, so this trimm will adjust the cut freq.
All the trimmers will go at the rear side of the PCB so once it is mounted you can adjust them with no much pain.
I will make a second Jellyfish of one channel with a knob associated to the filter. And other things.
The knobs don't like me at all, but this is a question of taste, i will try with a few more.
this have to be perfect! dwarf
papaver
PostPosted: Wed Mar 13, 2013 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Inside with the new pots.
 Filesize:  3.65 MB
 Viewed:  13 Time(s)
Paradigm X
PostPosted: Wed Mar 13, 2013 6:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool cool cool
party time!
papaver
PostPosted: Tue Mar 26, 2013 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
PCBs are comming Exclamation
This is slower that I thought.
I have a setback with the cases. The thing is that I have designed the PCB taking the base of the Hammond 1590DD cases. BUT the case that I have bought from Dasmusikding was not a Hammond 1590DD, it was something similar without the 2 screws/holes in the middle of the 2 sides. And now there is no space for the PCB in a Hammond 1590DD, only in the "1590DD type". Any thoughts on wich case can be that? There is no logo in the case.
If guys from dasmusikding can not supply me lots of this cases maybe I will consider to design a plexiglass case like the ones of mutable instruments or this one http://www.midibox.org/dokuwiki/doku.php?id=sammichsid
Confused Confused Confused
Paradigm X
PostPosted: Tue Mar 26, 2013 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm... thats a shame.
The guy who makes the shruthi cases is Frank Daniels, fcd72 on the shurthi forum, hes a nice guy, who makes some really good stuff.
Im sure you can contact him via the forum.
However, Im not a huge fan of plexi to be quite honest, its a bit easy to break.
i guess youve emailed musikding?
Cheers, Ben
papaver
PostPosted: Tue Mar 26, 2013 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I'm waiting for an answer.
Plexiglass cases from Mutable Instruments are laser cutted at www.ponoko.com, but I prefer metal ones too. These are more solid and provide a better isolation. Anyway I will find a solution. I hope people from dasmusikding will tell me wich is the manufacturer from the cases.
papaver
PostPosted: Thu Mar 28, 2013 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I have found a supplier for the cases. 4siteelectronics. Smile
I will try to speed up everithing. PCB's are comming.
Paradigm X
PostPosted: Fri Mar 29, 2013 4:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Great stuff. Take your time.
Nice one cheers ben
elektromeister
PostPosted: Fri Mar 29, 2013 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry is that design above mentioned for jellyfish a software gui or a front plate?
It looks a bit artificial!
papaver
PostPosted: Mon Apr 01, 2013 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
The post with the black, yellow and black designs are photoshop designs. no intention to looks like reality. Wink It's only an idea.
The other attachments are schematics or photos.
Anyway the final design will be the black one.
papaver
PostPosted: Tue Apr 16, 2013 5:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Red knobs prototype.
 Filesize:  3.98 MB
 Viewed:  8 Time(s)
papaver
PostPosted: Tue Apr 16, 2013 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Black Knobs prototype. I love this one.
Note that I have made the silkscreening / painting myself so there are some errors here. But that's not the point now.
 Filesize:  2.81 MB
 Viewed:  12 Time(s)
Paradigm X
PostPosted: Thu Apr 18, 2013 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome, the black knobs look great.
Cheers, Ben
papaver
PostPosted: Thu Apr 18, 2013 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ben.
I'm just waiting for the PCbs and the cases. Everything is done!
AmbiphonicDSP
