I want to disable a slot on my engine with a midi CC . help!
Page 1 of 1 [4 Posts]
seanwayland
PostPosted: Mon Feb 25, 2013 10:55 pm    Post subject: I want to disable a slot on my engine with a midi CC . help!
Subject description: I want to disable a slot on my engine with a midi CC . help!
I have a G2 engine and an alesisQX49 midi controller. I want to find a way to disable a slot on the G2 with a midi message . Can anyone shed some light on this ? Thanks Sean
Audio files: 116
G2 patch files: 317
PostPosted: Tue Feb 26, 2013 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Easiest thing I can think of is to set the volume to zero using CC7 on that slot. As far as I know it is not possible to actually disable the slot from MIDI.
An alternative would be to have two performances, one where the slot is eanbled and one where it is disabled, and then select the performance you need with MIDI.
seanwayland
PostPosted: Tue Feb 26, 2013 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks very much for your help Blue hell.. That was all I could think of myself. Fixing that is on the list that I want for the new G3 Wink
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Mar 10, 2013 1:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I recall that volume is saved with a variation. If so, use a cc receive connected to a couple of amps to ensure the volume remains off in all variations.
http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/
Niio2
