Paradigm X
Joined: Feb 15, 2011 Posts: 363 Location: Null and void
Posted: Fri Feb 22, 2013 3:03 am Post subject:
papaver wrote: | Thanks!
I think that mountain switches are a good choice. a bit expensive but good quality. I have to check if there are avaliable in DPDT and 3PDT and go for them in Mouser.
I'm not sure about the pactec cases, I want to keep a compact format and metal cases. But I have to look at the dimensions of the PT8, maybe it feets perfectly, I don't know.
anyway tomorrow will be a nice day to keep working on thiS! |
Cool man, well let me know if I can help in any way.
Cheers, Ben |
papaver
Joined: Sep 18, 2009 Posts: 68 Location: Barcelona, Catalunya, Spain
papaver
Posted: Fri Feb 22, 2013 6:02 am Post subject:
RV141F-40E3 seems a good choice. Is 25mm long so the pot will be like 1cm long from the panel.
http://www.mouser.com/ds/2/13/RV141F-40E3-18BL-BXXK-185110.pdf
The only cont is that the body is different and I have to adapt all the PCB, but it will not be a big problem. |
papaver
Posted: Fri Feb 22, 2013 6:06 am Post subject:
And it uses washer and nut, so the whole machine will be more solid. |
Paradigm X
Posted: Fri Feb 22, 2013 9:42 am Post subject:
Cool man. Seems youre well on top of it.
Very much looking forward to it.
Cheers, Ben |
papaver
Posted: Sat Feb 23, 2013 5:01 am Post subject:
They don't have the 100k audio value. I've been searching for 25mm long pots and there is no option for 5k 50k 100k lin and log.
The only options I can see now are conitnue with the existing ones or going to something like this http://www.banzaimusic.com/Alpha-16-PC-ANG-100k-log.html. It's stronger and more solid but it means to adapt all the PCB and depending on Banzaieffects for now. |
papaver
elektrouwe
Posted: Tue Feb 26, 2013 3:55 pm Post subject:
hi Papaver,
I have send PM to you couple of days ago. Did you see ? |
papaver
Posted: Wed Feb 27, 2013 1:24 am Post subject:
Right now |
papaver
Paradigm X
Posted: Tue Mar 12, 2013 2:01 am Post subject:
Yay! awesome.
Those are really cool knobs too
Well looking forward to this.
Cheers |
papaver
Posted: Tue Mar 12, 2013 2:36 am Post subject:
I want to add a few trimmers per channel. Two of them will adjust the feedback limits at the 2 switch positions. It's difficult to set the same value for the two ch with a resistor so the trimmer will be very usefull here.
The other one or two will control the filter frecs. Now I have filtered lots of unwanted noises from the chip but also losts of hi freqs are filtered but maybe you want all the noises, so this trimm will adjust the cut freq.
All the trimmers will go at the rear side of the PCB so once it is mounted you can adjust them with no much pain.
I will make a second Jellyfish of one channel with a knob associated to the filter. And other things.
The knobs don't like me at all, but this is a question of taste, i will try with a few more.
this have to be perfect! |
papaver
Paradigm X
Posted: Wed Mar 13, 2013 6:10 am Post subject:
Cool cool cool
papaver
Posted: Tue Mar 26, 2013 4:03 am Post subject:
PCBs are comming
This is slower that I thought.
I have a setback with the cases. The thing is that I have designed the PCB taking the base of the Hammond 1590DD cases. BUT the case that I have bought from Dasmusikding was not a Hammond 1590DD, it was something similar without the 2 screws/holes in the middle of the 2 sides. And now there is no space for the PCB in a Hammond 1590DD, only in the "1590DD type". Any thoughts on wich case can be that? There is no logo in the case.
If guys from dasmusikding can not supply me lots of this cases maybe I will consider to design a plexiglass case like the ones of mutable instruments or this one http://www.midibox.org/dokuwiki/doku.php?id=sammichsid
Paradigm X
Posted: Tue Mar 26, 2013 4:49 am Post subject:
Hmm... thats a shame.
The guy who makes the shruthi cases is Frank Daniels, fcd72 on the shurthi forum, hes a nice guy, who makes some really good stuff.
Im sure you can contact him via the forum.
However, Im not a huge fan of plexi to be quite honest, its a bit easy to break.
i guess youve emailed musikding?
Cheers, Ben |
papaver
Posted: Tue Mar 26, 2013 4:59 am Post subject:
Yes, I'm waiting for an answer.
Plexiglass cases from Mutable Instruments are laser cutted at www.ponoko.com, but I prefer metal ones too. These are more solid and provide a better isolation. Anyway I will find a solution. I hope people from dasmusikding will tell me wich is the manufacturer from the cases. |
papaver
Posted: Thu Mar 28, 2013 11:25 am Post subject:
I have found a supplier for the cases. 4siteelectronics.
I will try to speed up everithing. PCB's are comming. |
Paradigm X
Posted: Fri Mar 29, 2013 4:45 am Post subject:
Great stuff. Take your time.
Nice one cheers ben |
elektromeister
Posted: Fri Mar 29, 2013 8:54 am Post subject:
Sorry is that design above mentioned for jellyfish a software gui or a front plate?
It looks a bit artificial! |
papaver
Posted: Mon Apr 01, 2013 1:55 pm Post subject:
The post with the black, yellow and black designs are photoshop designs. no intention to looks like reality. It's only an idea.
The other attachments are schematics or photos.
Anyway the final design will be the black one. |
papaver
papaver
Paradigm X
Posted: Thu Apr 18, 2013 4:06 am Post subject:
Awesome, the black knobs look great.
Cheers, Ben |
papaver
Posted: Thu Apr 18, 2013 10:15 am Post subject:
Thanks Ben.
I'm just waiting for the PCbs and the cases. Everything is done! |
