ElectroNotes 129 TZVCO PCB Layout
Page 3 of 3 [60 Posts]
Goto page: Previous 1, 2, 3
PostPosted: Sat May 15, 2010 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I should add, it would be great if Oakley sound also sold Ian's kits, here in the UK. But that's between Mr Fritz and Mr Oakley Very Happy
ACHTUNG!
andrewF
PostPosted: Sat May 15, 2010 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Some people had a problem with Elby, as they also had with Doepfer, but I don't know if that has been cleared up by now?
this thread
Rykhaard
PostPosted: Sat May 15, 2010 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
andrewF wrote:
this thread
Wow. TY for posting the link to that thread. That were quite the drag (bummer /etc.) to read, especially for Thomas. Sad
Luka
PostPosted: Sat May 15, 2010 8:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah ok
fair enough
problemchild
melbourne australia
2thick4uni
PostPosted: Sun May 16, 2010 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info, a sad tale indeed.
2thick4uni
PostPosted: Sun May 16, 2010 2:09 am    Post subject: Reply with quote  Mark this post and the followings unread
+1 to that.
Sebo
PostPosted: Sat Sep 08, 2012 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi:
I recently finished building the TZ VCO. Thank you Forbin for the PCB layout!!!
I did a really nice MOD to it. I posted the details at this post:
http://electro-music.com/forum/post-369187.html#369187
Sebo
My Music:
www.cosaquitosenglobo.com.ar
ryktnk
PostPosted: Tue Mar 05, 2013 3:04 am    Post subject: E129 Through Zero VCO HELP ! Reply with quote  Mark this post and the followings unread
Hello
I hope somebody can help.
I have built this wonderful VCO 3 times [2 x breadboard, 1 x PCB]
But I always get some problems with instability when I
use a modulation freq obout 1khz and above, with a lower carrier VCO freq.
Seems to get really unstable and produces some
unpleasant and unpredictable glitches.
With modulation freq below 1khz it is great.
Anybody have any ideas what could be causng the problem ?
-ryk
Sebo
PostPosted: Tue Mar 05, 2013 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, mine works well, I didn't experiment what you say, but in mine, when the modulation freq is higher than the carrier freq, the modulation index decreases, I'm no sure if that correct.
Also I feel that the modulation index in general isn't as high as I was expecting (compared to other VCOs I have), but I think that's could be a low output of the VCA, I have to check.
Sebo
My Music:
ryktnk
PostPosted: Tue Mar 05, 2013 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Thanks Sebo.
I have the modulation cranked up high.
It is ok at very low modulation, but of course
that is before "through zero" so not so much fun !
-ryk
Niio2
