Atari punk console + Baby sequencer 4017 IC
Page 6 of 7 [165 Posts]
-minus-
PostPosted: Wed Aug 22, 2012 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Good to hear it's working for you. If you are looking for an amp, you could make a little gem or a ruby amp found here:
http://www.runoffgroove.com/littlegem.html
Oh, and those diagrams I did were done with Adobe Illustrator...
stealthop
PostPosted: Fri Aug 31, 2012 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
hi there , i was wondering about the 1n4148 diode. are you using the glass switching type or the rectifier type? any help would be greatly appreciated
thanks
-minus-
PostPosted: Fri Aug 31, 2012 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, and welcome! The little glass ones you see on the Wiki page are the ones.
http://en.wikipedia.org/wiki/1N4148
stealthop
PostPosted: Fri Aug 31, 2012 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
ahh , thank you . that means i have everything i need to start building this.
Denis_Veselov
PostPosted: Thu Nov 22, 2012 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
-minus- wrote:
I still have the two thirds of the eight 100K pot unusable problem...
I think you need to try this:
 Filesize:  318.35 KB
 Viewed:  74 Time(s)
Sorry my english
Denis_Veselov
PostPosted: Fri Nov 23, 2012 4:31 am    Post subject: Reply with quote  Mark this post and the followings unread
or so maybe:
 Filesize:  319.85 KB
 Viewed:  82 Time(s)
Sorry my english
Denis_Veselov
PostPosted: Wed Nov 28, 2012 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Denis_Veselov wrote:
or so maybe:
I'll build this circuit on my breadboard, but it isn't working. Sad
Sorry my english
-minus-
PostPosted: Wed Nov 28, 2012 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok. So are you getting any part of it to work? Is there any sound?
First thing to check is the power supply. If you are using a battery has it got power in it? Then you need to check the power is getting to the I.C's. Make sure all the grounded components are connected.
If you are getting power to the board correctly, you should check that the clock is working and then move on to the 4017 counter.
Denis_Veselov
PostPosted: Wed Nov 28, 2012 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
So i think, if to break all left wires (see circuit) of 8 pots, it will start give the sound in all its range.
But it make new problems:
1) Impossible to make a silence in anyone channel.
2) If all pots stay in left position, 8 tones have a some difference of tones.
Sorry my english
Denis_Veselov
PostPosted: Wed Nov 28, 2012 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I just said about my changed circuit. It have a sound, but in second half range of pots.
Sorry my english
-minus-
PostPosted: Wed Nov 28, 2012 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry I was unsure what you meant. So you have sound but the changes you suggested haven't worked.
To silence a channel you could use switches maybe. But that won't help the difference in tones problem.
What about reducing the 50K resistors you suggested using on the 8 steps. Perhaps you could try that?
Denis_Veselov
PostPosted: Wed Nov 28, 2012 10:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
This changes haven't worked too.
Sorry my english
-minus-
PostPosted: Wed Nov 28, 2012 11:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Im just wondering what pots you are using. Linear (B) or Logarithmic (A). Log pots would tend to bunch up the usable range towards one end and would appear worse than linear in this application. Maybe check that.
Denis_Veselov
PostPosted: Thu Nov 29, 2012 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Pots have a mark: "B100K" (or "B50K" for changed circuit).
Sorry my english
Denis_Veselov
PostPosted: Mon Dec 17, 2012 9:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
I want to add any interresting and simple filter to my apc+seq. Anybody have a circuit? Thanks.
Sorry my english
Denis_Veselov
PostPosted: Sat Dec 22, 2012 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I finished my apc&seq8!
http://www.youtube.com/watch?v=4oKyFTpd4E4
Sorry my english
-minus-
PostPosted: Sat Dec 22, 2012 7:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent! Glad you got it working. Looks like the whole family is enjoying it. Laughing
Denis_Veselov
PostPosted: Sun Dec 23, 2012 12:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! Your stripboard is very cool.
Sorry my english
RotomotioN
PostPosted: Sat Mar 02, 2013 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, first post, great thread. Will be building soon Smile .
Denis: Pots marked "B" are logarythmic, marked "A" are linear. You need A
Ow, and someone wanted a filter, look at this, not very simple but very cool:
http://www.musicfromouterspace.com/forums.html?MAINTAB=SYNTHDIY&PROJARG=OLDIESBUTGOODIES/VCF/vcf24dbperoct.html&VPW=1024&VPH=500
Denis_Veselov
PostPosted: Sun Mar 03, 2013 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tried to go on this link, but I saw "Page not found".
Sorry my english
bubzy
Audio files: 48
PostPosted: Mon Mar 04, 2013 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
you can look up a simple "RC" filter. its 2 components Smile or you can make it a bit nicer with an op amp as well. depends really on how much you want to do with it.
or you can look here :
http://electro-music.com/wiki/pmwiki.php?n=Schematics.Listbytype
and scroll to the filters section Smile
_Richard_ Smile
Audio files: 261
PostPosted: Mon Mar 04, 2013 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
It actually depends on the manufacturer. Most pots I use (Piher & Omeg) do indeed have an 'A' marking for linear, and a 'B' for logarithmic. However
alpha pots. and probably some other brands too, have this the other way around. (this can also be somewhat confusing in schematics when
they only use an 'A' or 'B')
welcome btw.
as for a filter, I recently used a simple sallenkey filter in a bend keyboard, which sounds pretty good.
Downside is that you need a stereopot. for the cutoff frequency, but it also has resonance control which is nice.
http://www.acidtrash.com/
analog_backlash
Audio files: 19
PostPosted: Mon Mar 04, 2013 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
It actually depends on the manufacturer. Most pots I use (Piher & Omeg) do indeed have an 'A' marking for linear, and a 'B' for logarithmic. However alpha pots. and probably some other brands too, have this the other way around. (this can also be somewhat confusing in circuits when they only use an 'A' or 'B')
You frightened me for a moment there PHOBoS, but then I read it again. I assumed that A was LOG and B was LIN, but it turns out this is true for Alpha pots AND TruOhm pots (which account for most of the ones I have). I'll be a bit more careful in future not to assume that A and B mean anything!
Gary
RotomotioN
PostPosted: Tue Mar 05, 2013 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ha! Didn't know that. It makes it all the more confusing. Just get your meter and be sure!
@denis: link works fine here
analog_backlash
Audio files: 19
PostPosted: Wed Mar 06, 2013 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I have the same problem as Denis with some links (including the one above). I think it's a "feature" of my browser. Try this link for the same VCF:
http://www.musicfromouterspace.com/analogsynth_new/OLDIESBUTGOODIES/VCF/vcf24dbperoct.html
By the way, I've built this and it's a great sounding VCF Very Happy
Gary
JuneSolstice2013
