KRS1972
Posted: Wed Mar 06, 2013 1:56 pm Post subject:
My Monotron Modification Subject description: Korg Monotron |
Hello !!
Just started to mod my Monotron so i can use it with my modular synth when its finished.
I use a 9 pin sub'd connector that fits just fine in the Monotron.
With a flat cable i connected the sub'd with the points i need.
(Pitch, Gate, Cutoff, VCO out, LFO out, VA, GND, Vbias)
One wire spare.
Some pictures of the result so far.
Now check some schematics and test on breadboard.
Grt,
Chris
Description: |
Monotron PCB with connection points |
Filesize: |
1.23 MB |
Viewed: |
1048 Time(s) |
Description: |
Monotron case with subd cutout |
Filesize: |
1.17 MB |
Viewed: |
798 Time(s) |
Description: |
Filesize: |
1.18 MB |
Viewed: |
814 Time(s) |
Description: |
Monotron with PCB and connected subd |
Filesize: |
1.31 MB |
Viewed: |
887 Time(s) |
Description: |
Monotron works the same as before with mods |
Filesize: |
1.19 MB |
Viewed: |
813 Time(s) |
KRS1972
Posted: Wed Mar 06, 2013 2:06 pm Post subject:
UPDATE !!!
Here is the schematic and pcb layout that i want to test.
VCO out and LFO out works fine. (through my mixer, mono)
Spare wire i want to use for audio out. (not on the schema)
Grt,
Chris
Description: |
Filesize: |
100.98 KB |
Viewed: |
39764 Time(s) |
Description: |
Filesize: |
558.42 KB |
Viewed: |
1954 Time(s) |
KRS1972
Posted: Thu Mar 07, 2013 11:35 am Post subject:
Hello !!
I finished the artwork for the aluminium front and is in eurorack format.
Two layouts i designed, one with the sub'd connector and one complete
with the Monotron. (no ribbon controller)
THESE ARE THE RAW VERSIONS !!
When i have all the parts, a final check.
Grt.
Chris
Description: |
Filesize: |
109.65 KB |
Viewed: |
854 Time(s) |
Description: |
Filesize: |
164.9 KB |
Viewed: |
1070 Time(s) |
KRS1972
Posted: Sun Mar 10, 2013 8:16 am Post subject:
Today i finished the front panels.
Art layouts are ok, sub'd connector a little bit higher so it fits better in the eurorack.
My second Monotron arrived for the other front panel.
The ribbon controller i will use later.
Here some pictures.
Grt,
Chris
Description: |
Filesize: |
1.02 MB |
Viewed: |
764 Time(s) |
Description: |
Filesize: |
1.03 MB |
Viewed: |
824 Time(s) |
Description: |
Filesize: |
1.25 MB |
Viewed: |
830 Time(s) |
Description: |
Filesize: |
1009.66 KB |
Viewed: |
886 Time(s) |
Joined: Dec 11, 2010 Posts: 966 Location: Toronto, Ontario - Canada
Posted: Sun Mar 10, 2013 8:46 am Post subject:
The panels look great. Nice work
Do we get to hear a sound demo after they are both complete? _________________ JacobWatters.com |
the19thbear
Posted: Mon Mar 11, 2013 7:05 am Post subject:
How did you make that good looking panel? |
KRS1972
Posted: Mon Mar 11, 2013 1:40 pm Post subject:
For my eurorack front plates i always use anodized aluminum.
The artwork on the panel is done with "waterslide decal paper", you can get it for laser and inktjet printers.
After that i spray a thin layer of vernish to finish it.
Grt.
Chris |
KRS1972
Posted: Wed Mar 13, 2013 2:05 pm Post subject:
Here some pictures of the second panel with pcb from the Monotron, pots and jacks.
Grt,
Chris
Description: |
Filesize: |
1.21 MB |
Viewed: |
1191 Time(s) |
Description: |
Filesize: |
1.17 MB |
Viewed: |
950 Time(s) |
bunker
Joined: Mar 19, 2009 Posts: 58 Location: Manchester, UK
Posted: Tue Apr 16, 2013 4:11 pm Post subject:
Wow! Looks amazing! A couple of questions if I may... What is the function of VA? I checked the schematics and it doesnt seem to be Vbias? I can see from your schematic that you're applying 3v via a voltage reg. Is that voltage normally derived on the main board? What are you bringing it out for? Keep up the good work!! |
Bloxelectric
Posted: Mon Sep 23, 2013 2:22 pm Post subject:
Just found this thread & at the time i am contemplating modding a monotribe or two.
Great work here, really organized looking. I'm an electrical novice but even i can make some sense of your work here. Thanks for all the effort posting here & i would be interested to know how the project is fairing up under the duress of use . Nice one indeed. |
Infrablue
Posted: Mon Sep 30, 2013 12:57 am Post subject:
This is GREAT work! |
5c4r7
Posted: Tue Nov 12, 2013 7:51 pm Post subject:
Faceplate? |
Hi There! First off, amazing work! I have to ask, where did you get your faceplate cut and how much did it cost? I sent your design to a company here in Toronto and they wanted $260 to make one for me. I think your mod is awesome and I would really like to make one for myself but, keeping costs down is somewhat imperative for me at the moment. Thanks and keep up the great work! |
new voodoo
Posted: Thu Nov 14, 2013 6:26 pm Post subject:
I am SO doing this. Like THIS WEEKEND..well, probably mid-week next week actually (have 37 other devices in the pipeline but I keep about 4 in circulation being made at same time)
PSYCHED!!
Ive kinda been waiting for a reason to use etchant & copper clads, etc Ive got all the stuff and just havent gtten to it yet. AND i have the monotron for it cause I bught one on a whim and its just been sitting aruond in the living room and to be honest-im tired of hearing "WHeeeUUUmmmmWHEEEEuuuOOOmmmp" whenever a friend decides to pick it up.
Since im in the middle of building a modular and need about 10u more of modules (want to end up filling a 100u case), its perfect!!
fantastic.
Cant say enough good about this.
so cool. |
Zodiak
Joined: May 20, 2007 Posts: 249 Location: Gillingham, Kent UK
Posted: Sun May 10, 2015 1:19 pm Post subject:
I was thinking of doing something similar with my three but couldn't work out how to get the connector on the back of the case, but I never thought of putting it on the side _________________ Stephen
www.Rainsbury.Net |
