W.T.
Joined: Jul 11, 2004 Posts: 272 Location: The Netherlands
G2 patch files: 11
Posted: Mon May 26, 2008 2:10 pm Post subject:
where are al the vocoders, i am trying to make a battlestar/beastyboys vocoder so i good use some insperation i gues, |
W.T.
G2 patch files: 11
found them |
Tunkul
Posted: Wed Mar 02, 2011 5:22 pm Post subject:
hi to all
its not working on win 7 ... help gyus ... is it realy working on other win ???
cappy2112
Joined: Dec 24, 2004 Posts: 2465 Location: San Jose, California
Posted: Wed Mar 02, 2011 8:18 pm Post subject:
Tunkul wrote: | hi to all
WHat do you mean it's not working?
What kind of error do you get?
Take a screenshot & attatch it to your post.
Have you installed Python?
www.python.org
Python2.6.x should work, as should 2.7.1
You need to add C:\Pythonxx to your path variable in control panel after running the Python installer. (where xx is the same version number that you installed, but without the decimal point _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
Check Mate
Posted: Sat Aug 11, 2012 10:23 am Post subject:
Hi Guys,
I have a question concearning the DX2G2 converted Patches.
I converted several DX7 Patches I found on the net.
So far so good.
But now I'm wondering where the Portamento function in the G2 Patches is. Maybe someone could explain that to me. I imagined it to be like on any other Synth I know i.e. the old Rolands etc. but I cannot find where to set the glide time that the sound slides from one note to the next.
Cheers _________________ Welcome to the Future |
ian-s
Joined: Apr 01, 2004 Posts: 2669 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 626
Posted: Sat Aug 11, 2012 7:27 pm Post subject:
Check Mate wrote: | Hi Guys,
So far so good.
Cheers |
It is in the editor patch settings dialog, next to the arpeggio controls. |
Check Mate
Posted: Sun Aug 12, 2012 2:03 am Post subject:
Hi Ian,
I knew about the "on-board function" of the G2. I just thought there is an extra portamento function bulid with modules in the G2 DX- Patches.
ian-s
Audio files: 42
G2 patch files: 626
Posted: Sun Aug 12, 2012 2:38 pm Post subject:
There is a glide module in there but looks like it just adds a 9.3ms glide to the S+H waveform. You could add another but the base patch is at 50% Mem in the VA so your going to cut your max poly voice count. |
Check Mate
Posted: Sat Aug 18, 2012 11:31 am Post subject:
Thanks for your help Ian! I'll try this then.
Rokatansky
Posted: Wed Aug 22, 2012 8:40 pm Post subject:
I have installed Phyton and was using CMD console but only get "failed patches".
Any ideas?
Win 7 32
Thanks in advance |
cappy2112
Posted: Wed Aug 22, 2012 10:42 pm Post subject:
Rokatansky wrote: | I have installed Phyton and was using CMD console but only get "failed patches".
Any ideas?
Win 7 32
Thanks in advance |
What exactly do you mean by "failed patches"?
Are any error messages displayed?
Can you post some screenshots?
Which version of Python do you have installed?
Open a command prompt,
type python, press enter
Post the python version displayed _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
Rokatansky
Posted: Wed Aug 22, 2012 11:30 pm Post subject:
Command prompt says so:
"Failed patches:nm2g2*.pch" (all files inside the g2tools folder)
"failed patches:Juno.pch" (single patch insode g2tools folder)
Typing "python" or "Python" inside cmd give me this:
"python is not recognized as an internal or external command"
Running the IDLE Python GUI:
"Traceback (most recent call last):
File "<pyshell>", line 1, in <module>
nm2g2.exe
NameError: name 'nm2g2' is not defined
Python 2.7.3 |
cappy2112
Posted: Thu Aug 23, 2012 3:59 pm Post subject:
Rokatansky wrote: | Command prompt says so:
nm2g2.exe
Python 2.7.3 |
The stupid website didn't notify me of this reply, even though that option is checked. Sometimes it happens, sometimes it doesn't. Don't know why.
Ok, so it's not in your path.
Would you do me a favor?
We need to add the python path to your system path
Type
which python
at a command prompt, paste your results here _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
Rokatansky
Posted: Thu Aug 23, 2012 4:14 pm Post subject:
Got it working now.
Just downloaded the G2oolsGUI,re-installed and followed the detailed info there and everything is fine now.
I used this command :"nm2g2 -r Dirname"
Thanks for your support
Regards |
BlisargonDemogorgon
Posted: Sun Mar 10, 2013 2:55 pm Post subject:
Rokatansky wrote: | Got it working now.
Regards |
I have used the same command and out of 900 patches only 400 were converted any info how i can convert the others and why would i get that error? _________________ Facebook
Soundcloud
WebPage |
cappy2112
Posted: Sun Mar 10, 2013 3:24 pm Post subject:
blisargon demogorgon wrote: | Rokatansky wrote: | Got it working now.
Regards |
I have used the same command and out of 900 patches only 400 were converted any info how i can convert the others and why would i get that error? |
Try converting just one of the patches that failed the conversion.
I believe a log file may be generated, but I don't remember where it is or what the name would be.
Look for files with .log extension and report your findings.
It's been a long time since I've used these tools. _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
BlisargonDemogorgon
Posted: Sun Mar 10, 2013 3:35 pm Post subject:
cappy2112 wrote: | blisargon demogorgon wrote: | Rokatansky wrote: | Got it working now.
Regards |
It's been a long time since I've used these tools. |
Just tried and i do it trough CMD.EXE
It gives me message Failed patches: FM Lead.pch
Where can i see the detailed error? _________________ Facebook
Soundcloud
WebPage |
cappy2112
Posted: Sun Mar 10, 2013 4:05 pm Post subject:
Where can i see the detailed error? |
We do know the converter has some limitations, although
I don't know exactly what they are. It won't work with every patch.
Are these patches you've created? _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
seanwayland
Posted: Sat Jul 16, 2016 2:09 pm Post subject:
dx7 conversion Subject description: reverse? |
Hi there,
I know a bit of python but don't understand much about the G2X patches.
I have a few FM patches on my G2X.
I was thinking of trying to convert them back to sysex
It would be a big job to try and figure out all the code in reverse.
Anyone else looking for the same thing?
Sean |
Melien
Posted: Sun Dec 02, 2018 4:40 am Post subject:
Guys hi, I'm also trying to convert some dx banks and i'm getting the same error as above (index out of range) in some of them. Anyone knows how to fix this or how this was fixed in the first message (...11 years ago!)?
if the error happens on the first patch (for example) of the sysex file, I can manually replace that with another patch from the same sysex file and it will convert. Therefore...alternatively, is there a way to split/extract the 32 patches per sysex file so that they can be converted one by one and reduce the number of errors? |
cappy2112
Posted: Sun Dec 02, 2018 2:19 pm Post subject:
Melien wrote: | Guys hi, I'm also trying to convert some dx banks and i'm getting the same error as above (index out of range) in some of them. Anyone knows how to fix this or how this was fixed in the first message (...11 years ago!)?
I’ve found why two of the errors are happening, but since I don’t know the dx7 patch architecture, I can’t fix the program.
One of the two IndexErrors I’ve found is caused by this code, which doesn’t make sense to me.
lfop.Rate.variations[i] = dxtable.lfo[dxpatch.lfo.Rate][1]
Each entry into the lfo table is defined as [lforang, lforate, lfomod,lfoattack]
So using the lforate to index into the table doesn’t make sense.
Dxtable.lfo is a table that is 100 elements long.
dxpatch.lfo.Rate at the point of failure is 127. _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
John_W_Thompson
G2 patch files: 5
Posted: Sat Jan 21, 2023 6:46 pm Post subject:
Does not work for me. Win 11. Tried both the exe and the Python (after installing Python). I have zero clue where to place files so I tried every possibility. All ever get is a possibly DOS looking screen that appears and dissappears within 1 one hundredth of a second.
Looking for a clue. |
cappy2112
Posted: Sat Jan 21, 2023 8:15 pm Post subject:
John_W_Thompson wrote: | Does not work for me. Win 11. Tried both the exe and the Python (after installing Python). I have zero clue where to place files so I tried every possibility. All ever get is a possibly DOS looking screen that appears and dissappears within 1 one hundredth of a second.
G200ls was written with python 2, which is now obsolete and not supported.
Python 3 is what is en vogue and these tools will need to be modified to run with Python 3 _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
Octave-Shift
Posted: Wed Jan 25, 2023 7:17 am Post subject:
cappy2112 wrote: | j wrote: | I have windows xp(sp2) and can not figure out how to use this.
Do i need python installed for it to work? Could you please tell me exactly how to install the converter and use it? I do not know anything about python or programming.
Do the files have to be placed into the windows folder or something?
I double clicked the exe file and a black box(command line?) temporarily pops up and disapears , but nothing else seems to happen.
Joerg?
Currently, you need to open a cmd prompt (aka DOS BOX) in the directory where the project is installed.
You don't need python installed nor have to know about any programming issues to use it.
The patches you want to convert need to be in the directory where you installed the converter.
In the cmd prompt window, type nm2g2 patchname.pch2
Substitute patchname.pch2 with the name of the patch you want to convert, or if you have a directory full of patches type,
nm2g2 *.pch2
A GUI version is in the works to simplify this, so you will be able to double click on a icon. This will be coming in the future. |
It works if you remove the 2 after the nm2g2 *.pch2 so it says nm2g2 *.pch. Hope you know how to open a command prompt? |
John_W_Thompson
G2 patch files: 5
Posted: Thu Jan 26, 2023 2:40 pm Post subject:
cappy2112 wrote: | John_W_Thompson wrote: | Does not work for me. Win 11. Tried both the exe and the Python (after installing Python). I have zero clue where to place files so I tried every possibility. All ever get is a possibly DOS looking screen that appears and dissappears within 1 one hundredth of a second.
Python 3 is what is en vogue and these tools will need to be modified to run with Python 3 |
Thank you for the information. |
