Noise Cornucopia problem (Solved)
Page 1 of 1 [4 Posts]
otcx
PostPosted: Thu Mar 14, 2013 7:11 am    Post subject: Noise Cornucopia problem (Solved)
Subject description: grainy noise
I just build another Noise Cornucopia rev-0 board. Everything else is working, but Grainy noise is just dead. I have confirm that all parts are right, and check that there is no tin bridges. I have also change all OP amps.
So any sugestions / what parts are involved. I am a bit lost in a moment.
otcx
PostPosted: Fri Mar 15, 2013 2:58 am    Post subject: More info Reply with quote  Mark this post and the followings unread
So problem must be somewhere near U3. So i will change OP amp again to be sure also 100K pot (even it looks like working). In this case i have to go hard way and test all connections again and measure all components near U3. Sill grateful of any ideas.
otcx
PostPosted: Fri Mar 15, 2013 4:17 am    Post subject: Reply with quote  Mark this post and the followings unread
So i mistkaly make new topic. But there was 2 faulty brand new OP amps, so first change did not help anything after cheking ewerything again, and cahnging third OP amp ewerything start to work OK.
Audio files: 218
G2 patch files: 319
PostPosted: Fri Mar 15, 2013 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, took care of that problem - glad you solved yours - too bad there were two bad ICs Confused
