Possible ground issue?
Page 1 of 1 [18 Posts]
SineHacker
PostPosted: Tue Mar 05, 2013 7:02 am    Post subject: Possible ground issue? Reply with quote  Mark this post and the followings unread
I am working on a basic drone instrument that is based around a CMOS 40106, I want to run it through a LM386 because I do some things to the gates/oscillators that makes them sound good but makes them quite quiet, and each oscillator has a separate volume pot
The problem is, if I power both chips from one battery everything sounds like battered shit, which I'm fairly sure is to do with the 40106 making the ground really noisey - If I use two batteries then it sounds fine
Another problem is that I am thinking of adding one of my crappy PT2399 based delay circuits to it as well which needs to run at 5v and 5v regulators eat 9v batteries for breakfast so I was hoping I could use a single power supply for everything from the wall.
Soooo, if I use a separate regulator for each part of the circuit would that by any chance give some separation of grounds? Actually even writing that down makes me think that will do nothing as I think the ground is linked up and unaffected by the regulator - any suggestions?
The current signal path is like this: 40106 oscillator to voltage divider (volume) x 6, so there are 6 oscillators that I sum to a 2n3819 and that goes into the lm386 - this currently goes straight to the output but I want to add the delay circuit here to try and add a crude chorus like quality to the sound. I would like to use a 7809 for the LM386 a 7805 for the PT2399 and a LM317 variable for the 40106 all powered from a 12v DC supply - I have never used multiple regulators so any tips on this would be good, I'm just going to run with it for now and experiment
Rather than trying to describe where the circuit is grounded at each point, I will draw a schematic tomorrow (at work till 9pm tonight!) and post it to help with the explanation if needed, but any thoughts on separating the ground or perhaps taming CMOS ground noise would be great!!
aidanrtaylor.co.uk
PostPosted: Tue Mar 05, 2013 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you put bypass caps on all your chips power supply pins?
SineHacker
PostPosted: Tue Mar 05, 2013 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah I always do - and definitely with the LM386!! the noisey beast it is... I'm using 1 micro-farad caps for it so maybe I will try something fatter next
aidanrtaylor.co.uk
bubzy
Audio files: 63
PostPosted: Tue Mar 05, 2013 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
how does it sound at the output of your summing transistor?
_Richard_ Smile
Just checking Smile
I've never seen 1uF or bigger caps used as bypasses though. Usually I see 1uF or 10uF on the main supply line in, and then .1uF or .01uF caps for bypasses.
Sorry I don't have anything more helpful to suggest....
SineHacker
PostPosted: Tue Mar 05, 2013 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
@ Elmegil: ok I will try it that way cheers (should have brought it with me to work!)
Not sure actually, I added it quite late in the game after I had been playing with the LM386 for a while - I can't quite remember why I added the 2n3819 but I do remember that I liked the result I got - but I have only listened to it post-LM386 so far - I will investigate
aidanrtaylor.co.uk
SineHacker
PostPosted: Tue Mar 05, 2013 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you guys got any experience with rail splitters/virtual ground/virtual dual-supply
I'm not sure if this only really applies to op-amps that require a dual-supply, but there is some interesting info here: http://tangentsoft.net/elec/vgrounds.html
aidanrtaylor.co.uk
SineHacker
PostPosted: Tue Mar 05, 2013 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey again, yeah it was to do with choice of bypassing capacitors - I used 10uf across the supply and 0.1uf at the +v pin of each chip as elmegil suggested and that properly stabilised the circuit. So thanks!
I also checked the signal at the transistor and it is clear there but the lm386 gives it a nice boost anyway, I might try without the transistor next
thanks again
aidanrtaylor.co.uk
bubzy
Audio files: 63
PostPosted: Tue Mar 05, 2013 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
virtual grounds are evil Very Happy
if you must use one, use the buffered type Smile
_Richard_ Smile
SineHacker
PostPosted: Wed Mar 06, 2013 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah... I was getting a bit ahead of myself Rolling Eyes
aidanrtaylor.co.uk
SineHacker
PostPosted: Tue Mar 12, 2013 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool, I finished it last night! Works really well. Thanks for the help - I tried adding a pic but not sure my phone wants to...
 Filesize:  1.78 MB
 Viewed:  52 Time(s)
aidanrtaylor.co.uk
bubzy
Audio files: 63
PostPosted: Tue Mar 12, 2013 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
what's it sound like?! Very Happy
_Richard_ Smile
SineHacker
PostPosted: Tue Mar 12, 2013 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Like dis
Headphone drone jam from Ginko (Aidan Taylor) on Vimeo.
aidanrtaylor.co.uk
bubzy
Audio files: 63
PostPosted: Tue Mar 12, 2013 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds good man!
needs more wubs
_Richard_ Smile
Audio files: 574
PostPosted: Tue Mar 12, 2013 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, that was nice! Very Happy
SoundCloud BandCamp Stickney Synthyards Captain Collider
SineHacker
PostPosted: Tue Mar 12, 2013 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I think I need to adjust the wub control... but really - I want the delay effect to be less subtle I think, you don't really hear it until the feedback is on the brink of self-oscilation, needs a mix control or some adjustment. I pretty much built the delay line from the PT2399 datasheet but switched out some of the capacitors to improve the sound quality (by trial and error!!). I am wondering if I can improve the volume by changing the resistor values between the lpf input and output - or what I presume is the main input but the pins are marked as LPF in and out. It's a great chip by any means!
aidanrtaylor.co.uk
Audio files: 574
PostPosted: Tue Mar 12, 2013 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I did some experiments with this chip myself a while back, and one of the things I did was draw a block diagram of the chip
(I think it's in the datasheet) with the filter components in place so you can actually make some sense of what they are for.
I'm not sure if the component values came from the datasheet or the echobase delay, which is what I initially started with,
but it might be helpfull.
One thing you can see is that the LPF pin is not actually an LPF unless it's being use as such. The filtering is done to reduce
the clocking noise of the chip itself, but I personally think it filters too much out this way. So instead I didn't do much filtering
in the delay line itself but after it. I stll need to post that schematic, but I first want to make a panel for it and finish it.
(it's a voltage controlled version for my modular synth)
PT2399 block diagram with filter components
 Filesize:  48.3 KB
 Viewed:  68 Time(s)
SineHacker
PostPosted: Tue Mar 26, 2013 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Neat, that's very helpful - I have a new project on the go now where I am going to revisit the pt2399 so I think I will start again from scratch
I am going to use a basic 4017 based 4 step sequencer to blink LED's and these will be used to opto-couple a single audio signal across 4 delays, the idea is to chop a signal in a sequence to each delay input. If it sounds as good as my brain is making out then it will be FUN
gonna put it in a vintage cornflakes tin Smile
aidanrtaylor.co.uk
