  Les Hall The Les Hall Show
preloading samples
Page 1 of 1 [2 Posts]
cheesymoo
PostPosted: Fri Mar 29, 2013 4:56 pm    Post subject: preloading samples Reply with quote  Mark this post and the followings unread
Greetings everyone.
I am using SndBuf to playback samples and would like to be able to read the samples in without having them playback immediately.
I have been unsuccessful in implementing this. This is problematic because the loading of the sample causes a noticeable stutter in the audio of other shreds while the sample loads.
It seems like it should be simple to load in all of the samples I want and be able to play them back on command without having this stutter/lag.
Does this make sense?
Any thoughts on solutions?
Thanks for your time.
pizzas
PostPosted: Sat Mar 30, 2013 6:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
what's up cheesymoo
to keep samples from playing upon loading, i have my sndbuf connected to an ADSR envelope. then, i tell the envelope keyOff.
Code:
SndBuf b;
ADSR e;
b => e => dac;
e.keyOff();
"provolone.wav" => b.read;
1::second => now;
e.keyOn() will trigger the sound.
i'm not sure what you mean about the stutter though -- let me know if the above helps with that too.
