 Forum index » Clavia Nord Modular » G2 Performances - Experimental
Will this work?
Page 1 of 1 [2 Posts]
PostPosted: Mon Apr 01, 2013 9:51 am    Post subject: Will this work? Reply with quote  Mark this post and the followings unread
Hi, i've been messing around at work with a patch for a live set utilizing 4 pieces. I'm working at it at work, spent the last hour or so on it, but can't test it until I get home. I wonder if anyone has any suggestions, or sees anything wrong with it.
G2(the master brain)
MFB 522 for drums(controlled and effected via G2)
Roland RE201(sent from G2, unfortunately not enough inputs to have this return)
Eventide Space(sent from G2, but again not returned)
Performance wise :
A will be handling sequenced synth lines.
B will be handling drum machine sequencing duties.
C will be handling how the drums are effected.
D will be handling the keyboard pad/string once I get on that slot.
Slot A isn't really complete, I think B/C are more on the completedish side.
Please let me know your thoughts, and what else might work.
now that I'm thinking about it, I think the drum machine will need a swing knob so i can make things swingy...hmm
MFB522-Performance.prf2
 Filename:  MFB522-Performance.prf2
 Filesize:  12.56 KB
 Downloaded:  1101 Time(s)
3001
PostPosted: Mon Apr 01, 2013 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
started testing it out, doesn't work very well at all, and in fact it's not very useful if it's just acting like sends to effects and no chains of effects:/
Doh...
i'll make a new one shortly:.>
