DIY NPN Transistor Whitenoisegenerator from scratch
Page 1 of 1 [21 Posts]
2kohm
PostPosted: Mon Apr 01, 2013 10:06 am    Post subject:  DIY NPN Transistor Whitenoisegenerator from scratch
Subject description: npn reverse bias junction
NPN Whitenoise generator with opamp amplifier
NPN Whitenoise gen with opamp amplifier
 Filesize:  19.51 KB
 Viewed:  352 Time(s)
Shop
Videos
Stromakustik.de
Osal
PostPosted: Thu Apr 04, 2013 4:15 am    Post subject: Reply with quote  Mark this post and the followings unread
To make the video of the breadboard it is a very nice the idea! Very Happy
May I ask why you didn't connect the op-amp's non inverting input to ground?
electronic-sea.net
isak
PostPosted: Thu Apr 04, 2013 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool!
Is it 741 IC?
Can I use 15V to run it?
Cheers Smile
2kohm
PostPosted: Thu Apr 04, 2013 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you guys Smile
one blemishes Smile but it makes no audible difference.
yes! i used the UA741 veteran Smile tested also with lm324 tl072 tl07X.
I think every singel opamp works!
15 v not tested but i think it works also
Spectrum
 Filesize:  32.63 KB
 Viewed:  209 Time(s)
Ableton view
 Filesize:  18.68 KB
 Viewed:  199 Time(s)
Abelton view
 Filesize:  63.76 KB
 Viewed:  201 Time(s)
white_noise_sample.wav
Audio
 Filename:  white_noise_sample.wav
 Filesize:  1.09 MB
 Downloaded:  293 Time(s)
Shop
Videos
Stromakustik.de
isak
PostPosted: Thu Apr 04, 2013 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks man.
Looks and sound good Smile
2kohm
PostPosted: Thu Apr 04, 2013 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Smile
i try to convert it in a pink noise and some random noise modes.
Shop
Videos
Stromakustik.de
PostPosted: Thu Apr 04, 2013 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice! Thanks for posting the response charts.
JacobWatters.com
beesontoast
PostPosted: Mon Feb 03, 2014 9:33 am    Post subject: Darn it, I can't make it work! Reply with quote  Mark this post and the followings unread
I can make most things work, given time, but this - despite its elegant simplicity - has me stumped.
I have used all-new parts, tested them all (the 741 by substitution) and double-checked connections. I have tried it on a speaker, a 386 op-amp, a small but very sensitive amp I use for other projects, and earphones and I get nothing, nada.
If there was one component I should try varying a value for, which would you suggest?
2kohm
PostPosted: Tue Feb 04, 2014 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
hi,
try the Transistors 2N2222A and BC457
C2 = 47N
C3 = 27N
for different noises
noise schematic
 Filesize:  618.57 KB
 Viewed:  390 Time(s)
Shop
Videos
Stromakustik.de
beesontoast
PostPosted: Tue Feb 04, 2014 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks - I will play some more.
One thing though - you have + (pin 3 on a 741) on the op-amp going to ground on that diagram...
Your drawing of a PP3 also shows reversed polarity...
2kohm
PostPosted: Tue Feb 04, 2014 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
that makes no difference for me
Shop
Videos
Stromakustik.de
beesontoast
PostPosted: Tue Feb 04, 2014 5:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I can make some pretty weird noises by coupling it to a 386 op-amp and ignoring pin 3 as per the original circuit - something like a cow with bellyache attacking a duck...
But nothing remotely like white noise.
Oh - I also made a pretty fair EMF detector by putting a coil and a 100nf in series between pins 2 and 3.
2kohm
PostPosted: Tue Feb 04, 2014 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
which transistor did you use?
Shop
Videos
Stromakustik.de
beesontoast
PostPosted: Tue Feb 04, 2014 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried a PN2222, BC517 and currently BC547B.
beesontoast
PostPosted: Thu Feb 06, 2014 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have solved the problem I had with the first circuit by adding in a potentiometer, and it turns out with a resistance of about 240 ohms I get white noise in a single 16 ohm earpiece.
(added) It turns out that a small electrolytic in that position also does the job.
2kohm
PostPosted: Thu Apr 10, 2014 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
good that it works now
Shop
Videos
Stromakustik.de
beesontoast
PostPosted: Thu Apr 10, 2014 8:45 am    Post subject: White noise generator using LM386
Subject description: circuit diagram
Here's my LM386 version:
It will oscillate at lower voltages, but seems to require a full 12v to produce white noise.
https://www.dropbox.com/s/luvp9vtbp5nup5y/2014-05-02%2009.10.26.jpg
555
PostPosted: Thu May 01, 2014 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Where exactly did you connect the potenciometer? i have the same problem than you, i almost tried everything, but i can't fix the problem (i spend hours try to realize what is wrong )
thanks!
beesontoast
PostPosted: Fri May 02, 2014 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks!
In place of the 1M resistor. It does seem to be important to use a 12v supply - 9v does not work.
555
PostPosted: Fri May 02, 2014 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
beesontoast wrote:
thanks!
i was suspecting that does't work with a 9v battery, anyway i will try the potenciometer, thanks
narges_1992
PostPosted: Thu Sep 11, 2014 3:19 am    Post subject:
Subject description: hi can you tell me about the ampilifier of this circuit , i have problem to produce this sound
Sad Confused
