Multifaceted response curve from linear CV
Page 1 of 1 [10 Posts]
tysseng
PostPosted: Sun Apr 14, 2013 1:07 pm    Post subject: Multifaceted response curve from linear CV
Subject description: I am having trouble creating a circuit that generates a CV voltage with different components
Hi!
First of all let me say that I'm an amateur when it comes to analog design, so don't be too hard on me Smile
I am trying to create a circuit that transform a linear CV into a curve with several components. E.g, from 0 to 2V the input should be attenuated by a factor of 2, from 2 to 5 it should be attenuated by a factor of 1.5 or similar. The actual numbers are not important but the principle is.
See my attachments for a drawing of the response I want.
My approach to this is to make two separate amplifier parts. One that generates the first part (from 0 to 2v) and one that generates the second part, and thus is 0v untill the input voltage reaches 2V. I will then sum up the result to get the intended response
The first part is easy. For the second part, my idea is to create a circuit that attenuates the signal by the factor I want, then to add a negative voltage to offset the 0v crossing point so that V-out is 0v when V-in is 2v. Finally I add a diode to reject the negative part so that the response is 0 in the range 0 to 2v. (in my circuit diagram this diode does the oposite, it rejects positive voltages, since I am using an inverting summer).
The circuit I have drawn up works as intended (at fairly low frequencies, but that's ok, the input voltage is controlled using either an LFO or a pot, so high frequencies are not a problem.
What IS a problem however, is that when i try connecting this circuit to an additional summer, or even to a voltage buffer, it does not act very well.
How would I go about connecting this circuit to a summer - or if that is not possible, are there other ways of rejecting the negative/positive part of a signal without using a diode?
Joakim
Wanted response curve, with my suggested approach of adding two separate curves.
 Filesize:  742.25 KB
 Viewed:  65 Time(s)
My attempt at making a circuit that generates the second part of the response curve
 Filesize:  266.27 KB
 Viewed:  70 Time(s)
gdavis
PostPosted: Sun Apr 14, 2013 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your desired response looks like a linear approximation of an exponential. Does it really need to be two linear segments or could you use an exponential converter? Designs for the latter are pretty easy to find.
Scott Stites
Audio files: 96
PostPosted: Sun Apr 14, 2013 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
This should get you where you want to be:
http://www.oldcrows.net/~patchell/archives/idealdiode.html
My Site
Scott Stites
Audio files: 96
PostPosted: Sun Apr 14, 2013 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
For example, I was able to get this response out of a triangle wave (the triangle wave is bottom, the piecewise-linear derivation of the triangle wave is on top).
You can manipulate any CV to go either direction, at whatever gain or attenuation that you want, at any point you want by finagling these building blocks.
 Filesize:  678.17 KB
 Viewed:  70 Time(s)
My Site
PostPosted: Sun Apr 14, 2013 11:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
You didn't make a batman logo, Scott! Very Happy
Scott Stites
Audio files: 96
PostPosted: Mon Apr 15, 2013 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm Batman!
My Site
tysseng
PostPosted: Mon Apr 15, 2013 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, thanks for the quick replies, I am stunned Smile Scott: That was exactly what I was looking for. I tried it out, it works perfectly.
gdavis: It looks quite like an exponential function, and I did think about approximating part of it using an exponential function. The real curve goes much further to the right before it suddenly bends upwards. I did read up on antilogarithmic amplifiers using transistors, but was a bit set off by the thermal compensation problem. However, since you called it an exponential converter (I hadn't heard that term before, just antilog or exponential amplifier), I struck gold (for me) right after googling it, with MiK-Music's article https://plus.google.com/107231411209962227230/posts/C8iVtXKzvet Smile
Thanks for all your help. Here is my first try:
 Filesize:  2.37 MB
 Viewed:  71 Time(s)
gdavis
PostPosted: Mon Apr 15, 2013 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I'd never seen the ideal diode circuit before, so I learned something too. That things pretty cool, I spiced it up and it really works great!
Scott Stites
Audio files: 96
PostPosted: Mon Apr 15, 2013 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Copyright that waveform ASAP. Then you can sell to AAA as a new, improved logo. Laughing
Bruce Wayne sent me a cease and desist. Crying or Very sad
Laughing
My Site
corex
PostPosted: Wed Apr 17, 2013 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is a very cool circuit... I should try it out. The possibilities are interesting.
