Stiff knobs
Page 1 of 1 [5 Posts]
Vader77
PostPosted: Thu Apr 18, 2013 10:16 am    Post subject: Stiff knobs
Subject description: (ooh er)
I wanted to loosen the knobs a little on my NM k so I sprayed a little deoxit and now they are too loose Sad
Whats the best way to return them back to the stiffer smooth action like when new?
Do Clavia use some thick grease inside or are the knobs normally like this when cleaned out inside without any lube as such?
adnauseam
PostPosted: Mon Apr 22, 2013 3:52 pm    Post subject: Not sure Reply with quote  Mark this post and the followings unread
I'm not sure Sad
Most of mine are too stiff except ONE that must have been overused by the previous user.
I guess I now know not to spray them with Deoxit Laughing
X-Electric
PostPosted: Thu Apr 25, 2013 4:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe this thread with the same problem will give you some pointers:
http://audiokarma.org/forums/showthread.php?p=6706104
dude163
PostPosted: Thu May 23, 2013 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
where can you get replacement knobs?
X-Electric
PostPosted: Fri May 24, 2013 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I've noticed people seem to be getting more lazy as years go by. This is an exemplary first google result for 'nord keyboard replacement knob' phrase Wink
http://www.syntaur.com/4660.html
IIRC Clavia used some regular (as in opposite to custom made) knobs, which I could swear I've seen some time ago even in one of our local Polish electronics shops.
