2-digit LED display for memories?
Page 1 of 1 [13 Posts]
gmeredith
PostPosted: Thu Apr 18, 2013 9:19 pm    Post subject: 2-digit LED display for memories? Reply with quote  Mark this post and the followings unread
Hi, haven't posted here for ages but still lurk occasionally.
I've done a sample memory expansion on my Casio DM100 keyboard. I've expanded it to 16x the sample memory, so that it has 16 banks of 4 samples:
http://www.warningwillrobinson.com.au/index_files/Professor.htm
I've also done it to my Casio SK8.
I'm trying to make up an improved LED display to select and show the memory bank number it's on. At present I'm using a single digit LED display. I'd like to go to a two-digit display.
The 16 memory banks are presently selected using a 4029 up/down counter chip going to the expansion chip's 4 extra memory address lines. These 4 lines also input to a 4511 display encoder driver and 7-segment LED digit as the display.
In this instance, memories 0 to 7 (ie the first 8 memories) are displayed as 0 to 7 on the display. but because the 4511 display chip won't decode and display binary numbers past 9, I'm stuck with only accessing 0-9 memory banks. How would I make a 2-digit display to show the numbers 11-15? I'd rather not go down processor/PIC/Arduino solutions for this because I'm not into programming nor have the gear.
I notice that the 4029 chip has a "carry" feature. Is this what this is for? Access a 2nd 4511 chip for a cascading 2 digit display?
Cheers, Graham
 Filesize:  159.28 KB
 Viewed:  339 Time(s)
Audio files: 574
PostPosted: Fri Apr 19, 2013 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
interesting,. I have an SK1 myself that still needs to be modified, and memory expension would be great Shocked
As for the displays, I wanted to drive a couple of displays a while back and if I remember correctly this either needed some special cmos/TTL chips
(which are no longer available) or a lot of extra logic which wasn't worth it in my opinion. So eventually I did use a PIC (not what you want).
So I'll keep my eye on this thread in case someone offers a solution.
you could do something else, that is use the dot on the display to indicate higher numbers. So use 3 bits to control the display from 0-7 and use the
4th bit for the dot which indicates 8-15.
SoundCloud BandCamp AcidTrasH Stickney Synthyards
gmeredith
PostPosted: Fri Apr 19, 2013 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, yes, that's what I had been doing before I went with the 4029 counter - I had the 4511 hooked up to the lowest 3 address lines and the 4th to the dot. It's okay, and simple, but I just wanted something more aesthetic and user-friendly. If I can't find anything simple I'll go back to that.
Is there anyone out there that sells pre-programmed PIC chips to do this?
I'm amazed to find out how difficult it seems to be to do such a simple job. Surely there's some driver counter chip that simply overflows any number over 9 to another digit?
Cheers, Graham
-minus-
PostPosted: Fri Apr 19, 2013 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I recently built a two digit counter using the same IC's. there is an incorrect schematic somewhere on the web where the cascading will not work correctly. I'm away from home for a couple more days but I will check and see how I did this. I think you replicate your counter and decoder for the second display and take the carry out pin (pin 7) of the single digit/units, to the carry in pin (pin 5) of the double digit/tens. The reset pins of the two counters are tied to set the count to 00.
Audio files: 574
PostPosted: Sat Apr 20, 2013 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
ah, a double counter yeah that would work in this case Very Happy
gmeredith
PostPosted: Sun Apr 21, 2013 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, thanks, minus! I'll give it a try soon and see how it works out. Thanks for your help!
Cheers, Graham
-minus-
PostPosted: Mon Apr 22, 2013 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
There is the CD40110 too. This is an up down counter and LED driver all in one chip. Using them would reduce the IC count.
http://www.ti.com/lit/ds/schs100/schs100.pdf
gmeredith
PostPosted: Mon Apr 22, 2013 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Seems good - but where do you output the 4 address lines for a RAM chip?
analog_backlash
Audio files: 21
PostPosted: Mon Apr 22, 2013 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
interesting,. I have an SK1 myself that still needs to be modified, and memory expension would be great Shocked ...
I've got an SK-5 which I would love to do a memory expansion on, but I'm not currently up to that standard Crying or Very sad . I'd be very interested in any postings on this subject as it may eventually give me the required knowledge to bite the bullet on that one! The 2-digit display should useful as well.
I'll watch this space...
Gary
P.S. I also have a PT-1 is pieces, which I'm planning to do some bending on. I've so far sprayed the (white) case black, so that usefully, you can't read what any of the buttons are for (didn't think that one through). I did this, because I was only going to use the keyboard for a tiny synth. I still might do this.
gmeredith
PostPosted: Mon Apr 22, 2013 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
The memory expansion for SK5/SK8 is well established and documented - I wrote up a guide for it:
http://www.warningwillrobinson.com.au/index_files/SKexpansion.htm
The chip that is specified is no longer available for it (32x chip) but there is still a smaller one of the same kind that gives 16x expansion, and is used exactly the same way.
Cheers, Graham
-minus-
PostPosted: Mon Apr 22, 2013 11:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah yes. Sorry about that. I now see what you are trying to do.
analog_backlash
Audio files: 21
PostPosted: Tue Apr 23, 2013 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the excellent guide Graham! When I'm feeling brave one day, I will have a go at this Very Happy .
Gary
gmeredith
PostPosted: Tue Apr 23, 2013 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I forgot! Here's an even better guide, with photos, taking you through every step of the process - it's for my DM100 keyboard - which has an sk5 as the upper keyboard:
It's down the bottom of the page, under the DM100 info.
So it will be exactly the same for your keyboard, except for a couple of hookup places on the board, which I could walk you through when you want to do it.
