<on air> Various Artists March Equinox 2017 streaming concert
[Order] Continuum Phase Shifter - Fabbed PCBs and Panels
Page 1 of 1 [10 Posts]
frequencycentral
PostPosted: Wed Apr 24, 2013 6:16 pm    Post subject: [Order] Continuum Phase Shifter - Fabbed PCBs and Panels Reply with quote  Mark this post and the followings unread
This one has been a long time coming! Brand spanking new fabbed PCBs are now in stock. Panels are on order and should arrive within 4 weeks. The panels are 10HP and are basically the same as shown below, with the exception that the 'Frequency Central' logo will be in mirror image.
If you want just a PCB or two you can order now they'll be shipped right out.
If you want PCB + panel you can order now but please allow about 5 weeks for delivery.
Continuum PCB: £15 GBP
Continuum Panel: £15 GBP
Shipping:
Please add £3 GBP if you're outside Europe.
Paypal to:
payments(AT)frequencycentral.co.uk
....don't forget to replace the (AT) with @
Soundclips? First, let's phase some pink noise:
http://www.frequencycentral.co.uk/wp-content/uploads/2012/07/Continuum-Noise.mp3
So now, with a couple of VCOs as audio, let's send S/H into one CV input then an ADSR into the other, while slowly turning up the resonance:
http://www.frequencycentral.co.uk/wp-content/uploads/2012/07/Continuum-SH-Env.mp3
Now, a single VCO as audio, with ADSR to one CV input of Continuum, and slowly introducing a -1oct sub osc to the other CV input:
http://www.frequencycentral.co.uk/wp-content/uploads/2012/07/Continuum-FM1.mp3
Some Continuum ping action! Using a Roland ADSR to ping it, and a couple of tap tempo LFOs synced with a clock divider to modulate it. There's some serious bottom end going on there, better hook up your playback device to your nearfields...:
http://www.frequencycentral.co.uk/wp-content/uploads/2013/02/Continuum-Pings.mp3
Finally, here's how it sounds phasing my RS-09:
http://www.frequencycentral.co.uk/wp-content/uploads/2012/07/Continuum-RS09.mp3
StephenGiles
PostPosted: Thu Apr 25, 2013 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Can it do Through Zero Phasing?
Mongo1
PostPosted: Fri Apr 26, 2013 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool project - before I order it, I had four small questions.
[note - I feel like the Spanish Inquisition sketch - I started out with 2 questions, but I keep adding more. ]
[note 2- I looked around your website and found the answer to most of my questions - here is the link to the document: ]
http://www.frequencycentral.co.uk/wp-content/uploads/2013/02/Continuum-Build-Doc.pdf
1) I see LM13700s, but are the other ICs anything difficult, or just common op-amp stuff?
Answer - Nope - just plain vanilla components
2) Can this run on +/- 15v?
3) What does the "Even/Odd" switch do?
Answer Regenerates even or odd stages - This would be a nice thing for an audio demo...
4) How many stages does the phase shifter have?
Answer - 4 Stages
Thanks
Gary
frequencycentral
PostPosted: Sat Apr 27, 2013 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
1. Other ICs are TL084 and TL072, somehow the screenprint was missed.
2. Runs fine on +/-15V
3. Odd/Even refers to the number of stages in the resonance path, Odd is more pronounced, but Even has it's charms too. Example, first riff Odd, second riff Even:
http://www.frequencycentral.co.uk/wp-content/uploads/2012/07/Continuum-Odd-Even.mp3
4. Technically 6 stages, 4 swept, 2 fixed.
StephenGiles
PostPosted: Sat Apr 27, 2013 6:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you still thinking about my humble question?
frequencycentral
PostPosted: Sat Apr 27, 2013 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry Stephen, not TZ.
Mongo1
PostPosted: Sat Apr 27, 2013 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi again,
I noticed in the documentation that you said R46 was related to regeneration, and should not be stuffed.
If I wanted to have a regen control, would it make sense to have a 10K pot in that position?
Thanks
Gary
frequencycentral
PostPosted: Sat Apr 27, 2013 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Mongo1 wrote:
Hi again,
Thanks
Gary
Already has a regen control, 'Res' on my panel = regen
The 10K resistor tames the regen in a somewhat musical way, however if you want wild self oscillation you can reduce the resistor, say 4K7.
StephenGiles
PostPosted: Sat Apr 27, 2013 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wouldn't it just need a few static all pass filters configured to give a few usec delay?
StephenGiles
PostPosted: Sat Apr 27, 2013 11:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.diystompboxes.com/smfforum/forums.html?topic=25168.0
This old thread includes a circuit for a 0.5msec analog delay, intended for TZF using only one BBD. However there could be some mileage in trying this with a phaser.....a la Eventide!
