<on air> Various Artists June Solstice live streaming concert
Need help with YU-Synth Arp 4072 VCF
Page 4 of 4 [87 Posts]
yusynth
PostPosted: Mon May 13, 2013 4:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Check earlier in this thread, I gave some clues to debug problems (measurement points and so on). Have you tried to change the LM3900 ?
Yves
sylvainmoreau
PostPosted: Mon May 13, 2013 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
no i haven't changed the LM3900 i didn't do any test for now, i need a voltage generator :p do you recommand some nice tool to do that ?
like something like this would be ok ? :
http://www.selectronic.fr/calibrateur-de-tension-et-de-courant.html
i have an oscilloscope and multimeter .. guess that should be enough to test all the basic audio DIY i'm doing.
arp vcf 4072 in progress
yusynth
PostPosted: Mon May 13, 2013 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
An oscilloscope and a good multimeter are all that is required.
Yves
sylvainmoreau
PostPosted: Mon May 13, 2013 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
ok but for calibration procedure .. you need to generate 1V right ?
yusynth
PostPosted: Tue May 14, 2013 12:03 am    Post subject: Reply with quote  Mark this post and the followings unread
It's easy a simple potentiometric circuit does it: it's a matter of connecting a 12K resistor and a 2.5K 15 turns trimmer in series between +15V and 0V (trimmer connected to 0V, resistor to the +15V) and adjusting the trimmer until 1V is measured on the taper of the trimmer.
If you wnat to be perfect you may add an OpAmp mounted as buffer (volatge roller) betwen the taper of the trimmer and the output.
Yves
sylvainmoreau
PostPosted: Sat Jun 08, 2013 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
ok finally i calibrated my filter and it works.
but i have a strange sound happening like if i had a little envelope doing some gate at attack release.
so here is a demo first sound is ARP filter up and down then the MOTM440 up/down.
settings are :
square sent to ARP
FREQ 0->full->0
RESO 0%
in1 70%
in2 0% (not connected)
cv1 0% (not connected)
cv2 0% (not connected)
i found strange that "clip" sound on the arp that stays even if the filter is 0. any idea on what does this sound ?
here is a picture of the waveforms
sylvainmoreau
PostPosted: Wed Jun 12, 2013 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
no ideas ? Posted Image, might have been reduced in size. Click Image to view fullscreen.
Benjamin AM
PostPosted: Wed Jun 12, 2013 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I believe what you are experiencing is filter bleed through. There is a way to fix this by installing a dual gang pot. I know that there is information on this subject somewhere in the forum.
sylvainmoreau
PostPosted: Wed Jun 12, 2013 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
dam .. thx for info i'll search for that but the problem on the forum is that when you enter a keyword in search it opens the topic from page 1 (!) and most of them have lots of them :S
Benjamin AM
PostPosted: Wed Jun 12, 2013 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/viewtopic.php?highlight=bleedthrough&t=47802
I would suggest to read the entire link
sylvainmoreau
PostPosted: Thu Jun 13, 2013 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
how thx Benjamin i missed that one Laughing
kx
PostPosted: Tue Dec 30, 2014 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi All,
I've been trying to get my Yusynth ARP-VCF running properly for quite a while now and I've hit a bit of a wall, so I was wondering if any of you might be able to help.
It's a PCB that I've toner-transfered, and it's the 2n3906 version. My problem is that the signal that enters the board just passes through and is not filtered. I've tried replacing the LM3900N with a new one, and I've replaced all of the transistors with matched 2n3906s (in the correct orientation).
Referring to the tests from the first page of this thread, the voltage measurement at the Q6 junction ranges from -6.4v to -6.7v which isn't the same but not too far off from what Yves and Luka had. When inputting a +/-4v square wave with the resonance pot at 0 and frequency pot at 12, I read a -5v to -10v square wave at all four of the filter poles with no sign of filtering.
Does anyone have any idea what could possibly be at fault?
Thanks a lot.
