  Various Artists electro-music September Equinox streaming concert
Jez or Rob's Adventures in Sound
Page 27 of 46 [1133 Posts]
Goto page: Previous 1, 2, 3, ..., 25, 26, 27, 28, 29, ..., 44, 45, 46 Next
Audio files: 263
PostPosted: Thu Apr 18, 2013 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording and a pic of me just prior to playing Smile
For this episode I used 2 iPads (running Animoog, AddictiveSynth, Samplewiz and Waveshaper), ER-1, blofeld, nanokey, OP-1, Kaossilator, Resonator, Wedge and dd-20, with iConnectMidi connecting everything via midi, so everything is be clocked to the ER-1 and the nanokey plays the blofeld
Adventures_In_Sound_158_170413.mp3
Adventures In Sound - Episode 158 - Sequential Transition Experiments
 Filename:  Adventures_In_Sound_158_170413.mp3
 Filesize:  54.94 MB
 Downloaded:  842 Time(s)
Audio files: 263
PostPosted: Thu Apr 18, 2013 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Audio files: 263
PostPosted: Wed May 01, 2013 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tonight's Adventure In Sound will be Abstract Noise Transition Experiments using my OP-1 through a monotron and looped by a dd-20 and boardweevil 2012 through ER-1 drum machine for gating and percussive noises Wink
Audio files: 263
PostPosted: Thu May 02, 2013 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording for Episode 159, which was technically my 100th show (including the 3 Xmas specials with Rob in 2010) party!
For this show I decided to use a different approach to normal, with just the OP-1 through monotron filter being looped, the boardweevil was run through my ER-1 drum machine which I used to gate the boardweevil, add delay and also for percussive noises.
Adventures_In_Sound_159_010513.mp3
Adventures In Sound - Episode 159 - Abstract Noise Transition Experiments
 Filename:  Adventures_In_Sound_159_010513.mp3
 Filesize:  55.65 MB
 Downloaded:  840 Time(s)
Audio files: 219
G2 patch files: 319
PostPosted: Thu May 02, 2013 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
100th!
party!
Thought it to be a very nice episode too!
Audio files: 263
PostPosted: Thu May 02, 2013 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
100th!
party!
Thanks Jan
Won't be around for my next show so might need you to broadcast an episode for me, if I get chance to record one Smile
Audio files: 219
G2 patch files: 319
PostPosted: Fri May 03, 2013 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd play it then Smile
Audio files: 263
PostPosted: Fri May 03, 2013 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers Very Happy
Audio files: 263
PostPosted: Wed May 15, 2013 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Tonight's show will be a pre-recorded episode called iPad Adventures as I'm on tour. I only used my iPads, effects and looper. Apps used were samplewiz and addictive synth.
Thanks to Jan for streaming it for me Smile
Audio files: 219
G2 patch files: 319
PostPosted: Wed May 15, 2013 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
That was a lovely set, glad you recorded something for us!
Audio files: 263
PostPosted: Fri May 17, 2013 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Smile
Audio files: 263
PostPosted: Wed May 29, 2013 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Tonight's episode of Adventures In Sound is called 'as little as possible, an ambient loop drone experiment'
It will feature op-1 into resonator, then into wedge doing a 5 second delay and slow pan, with left and right outs of wedge fed to two dd-20s with loop lengths of 19 and 23 seconds, then mixed Smile
Audio files: 263
PostPosted: Thu May 30, 2013 5:19 am    Post subject: Reply with quote  Mark this post and the followings unread
and here are the recordings for the last 2 episodes...
Adventures_In_Sound_160_150513.mp3
Adventures In Sound - Episode 160 - iPad Adventures
 Filename:  Adventures_In_Sound_160_150513.mp3
 Filesize:  59.12 MB
 Downloaded:  763 Time(s)
Adventures_In_Sound_161_290513.mp3
Adventures In Sound - Episode 161 - As little as possible, an ambient loop drone experiment
 Filename:  Adventures_In_Sound_161_290513.mp3
 Filesize:  55.17 MB
 Downloaded:  787 Time(s)
Audio files: 263
PostPosted: Wed Jun 12, 2013 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tonight's episode of Adventures In Sound will be OP-1 and blofeld through Resonator, Wedge reverb and DD-20 and is called 'Space-Wave-Generator'
Audio files: 263
PostPosted: Thu Jun 13, 2013 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording and a pic of the setup for Episode 162 'Space Wave Generator'
Adventures_In_Sound_162_120613.mp3
Adventures In Sound - Episode 162 - Space Wave Generator
 Filename:  Adventures_In_Sound_162_120613.mp3
 Filesize:  55.39 MB
 Downloaded:  825 Time(s)
Audio files: 263
PostPosted: Wed Jun 26, 2013 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tonight's Adventures In Sound will be some experimental dark ambient using VCS3, OP-1 and iPad
Audio files: 263
PostPosted: Thu Jun 27, 2013 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording for Episode 163 'Unfamiliar Star Patterns', recorded using VCS3, OP-1 and iPad running Thor, through Resonator and Wedge and looped by DD-20
Adventures_In_Sound_163_260613.mp3
Adventures In Sound - Episode 163 - Unfamiliar Star patterns
 Filename:  Adventures_In_Sound_163_260613.mp3
 Filesize:  55.89 MB
 Downloaded:  829 Time(s)
Audio files: 263
PostPosted: Wed Jul 10, 2013 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
For tonight's Adventures In Sound I'm just going to use the OP-1 and a DD-20 for looping, expect ambience, noise and lots of random modulations Smile
PostPosted: Wed Jul 10, 2013 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent set Jez!
Darkvortex, you're sounding great too! Very Happy
ACHTUNG!
Audio files: 263
PostPosted: Wed Jul 10, 2013 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Excellent set Jez!
Cheers Tom Smile
Audio files: 263
PostPosted: Thu Jul 11, 2013 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
and here's the recording, a very minimal setup this week, just op-1 and dd-20, with minirig speakers used for monitoring
Adventures_In_Sound_164_100713.mp3
Adventures In Sound - Episode 164 - Random Modulations with the OP-1
 Filename:  Adventures_In_Sound_164_100713.mp3
 Filesize:  56.36 MB
 Downloaded:  726 Time(s)
Audio files: 263
PostPosted: Wed Jul 24, 2013 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tonight's Adventures In Sound will be deep space drones courtesy of op-1 and ipad (probably using addictive, animoog & ipolysix)
Audio files: 263
PostPosted: Thu Jul 25, 2013 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording for Episode 165 - Deep Space Drone Explorer
In the end it was just op-1, and ipad using addictive mostly, with a bit of ipolysix for the analog squiggly bits and arpeggiations near the end Smile
Adventures_In_Sound_165_240713.mp3
Adventures In Sound - Episode 165 - Deep Space Drone Explorer
 Filename:  Adventures_In_Sound_165_240713.mp3
 Filesize:  54.94 MB
 Downloaded:  717 Time(s)
Audio files: 263
PostPosted: Thu Aug 08, 2013 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording for Episode 166 - Frozen Time Streams, the setup was much the same as last time, but I used some different apps, including addictive, alchemy, dxi and ipolysix
Apparently it was classic Modulator ESP but with new elements Wink
Adventures_In_Sound_166_070813.mp3
Adventures In Sound - Episode 166 - Frozen Time Streams
 Filename:  Adventures_In_Sound_166_070813.mp3
 Filesize:  54.94 MB
 Downloaded:  802 Time(s)
Audio files: 263
PostPosted: Wed Aug 21, 2013 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tonight's episode of Adventures In Sound is entitled 'Internal Sleepwalk' and will feature various iOS synths, OP-1 and mini kaoss pad Smile
