  PHOBoS Prayer Drone
  Les Hall The Les Hall Show Special - Neural Nets 101
Bringing the Vocoder to life
Page 7 of 7 [164 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7
The Bad Producer
PostPosted: Fri Mar 22, 2013 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Luka,
Been away for a few days - looks like it's just us! Very Happy I'll have a look at the thing today, go through all my print outs!
http://soundcloud.com/thebadproducer
Luka
PostPosted: Wed Mar 27, 2013 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah seems so charlie
im interested whether there will be a silence bridge pot as well as the level pot for each channel.
can anyone who has a complete build determine this?
in jurgen's example panel he had a addition / bridging pot and a channel level pot.
do you think the addition / bridging pot was the pause bus / silence bridge?
problemchild
melbourne australia
Luka
PostPosted: Thu Mar 28, 2013 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
any ideas for the slider / pot value for pause bus?
problemchild
melbourne australia
Omega
PostPosted: Thu Mar 28, 2013 11:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi everyone. I am new here and I have a question on the power supply, about Q2701 and R2713. What do I have to adjust here ? Any idea is welcome.
Thank you in advance !
Best regards
Bernhard
Luka
PostPosted: Fri Mar 29, 2013 12:36 am    Post subject: Reply with quote  Mark this post and the followings unread
that will adjust the led brightness for all leds using the led power bus
problemchild
melbourne australia
Omega
PostPosted: Fri Mar 29, 2013 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Whow ! Thank you for the quick reply !!
Bernhard
Bernhard
Luka
PostPosted: Fri Apr 05, 2013 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
having been doing some digging
the sennheiser vsm201 used 50k - hoping that will be ok
problemchild
melbourne australia
Omega
PostPosted: Tue Apr 16, 2013 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good morning everybody. Some more "silly" questions regarding the speech amp.
- which value are you using for the SP_LEVEL Pot ?
- looking at the schematics of the speech_input_amp I am asking me what's the difference between the Speech socket and the SPEECH_AMP ? Looking at other schematics I see that the SPEECH_AMP ist used. So what will you do with the Speech socket (that's SPEECH_AMP plus R2130)
- Switch to bypass Vactrol LED: So only the LED is bypassed. Is that correct ? The limiter function itself is not inhibited
Any ideas are welcome.
Thanks a lot in advance
Bernhard
Luka
PostPosted: Thu May 02, 2013 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
just got back from holidays Smile
the speech amp routes the signal to the silence bridging circuit, slew / freeze circuit, attack detector and v/uv. the speech connector is the bus sending speech to the speech analysis filters in each channel.
im not exactly sure how the limiter circuit works but my assumption is the switch turns the limiting on and off.
problemchild
melbourne australia
Luka
PostPosted: Sat May 25, 2013 5:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
fyi i found another mismatch from schematic to pcb
R0126/R0127 in LPF is 33k on the schematic and 39k on the pcb
im going to with 39k for now
problemchild
melbourne australia
Useemu
PostPosted: Sat Nov 23, 2013 7:45 am    Post subject: R0307 should be 1k5 Reply with quote  Mark this post and the followings unread
Just find a wrong R value on channel_3.as schematic while simulating. R0307 must be at 1k5 instead of 1k8. Otherwise you are about 3dB on the low side with channel 3.
Luka
PostPosted: Fri Jan 03, 2014 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok well im testing modules now
psu ok - i used the onboard psu
synth in seems okay but i guess ill need to verify once i have more modules and channels tested ( i used ssm2019 btw and not seeing any instability )
now im up to v/uv and i have a question
should the voiced led stay on with no signal?
problemchild
melbourne australia
Luka
PostPosted: Fri Jan 03, 2014 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
can someone let me know if this is a correct interpretation of the v/uv circuit
speech amp is sent to preamp (U2301)
output of speech amp is routed to 2 filters (high / low) with a pan pot to detect muffled and high pitch noise sounds
each filter passes through a precision rectifier
outputs of rectified filter channels are sent to a comparator which triggers the unvoiced state
comparator output routed to another comparator (determining the voiced state as the invert of the unvoiced) as well as feeding the hysteresis circuit (j2301)
problemchild
melbourne australia
Luka
PostPosted: Fri Jan 03, 2014 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
zthee wrote:
So I did the changes suggested by Sound. The things I had to change in the changes was the noise level. Cause even with the noise level trimmer turned down it was still 4x higher than the replacement signal. So I reverted back to the 18K / 100K setting, which brought it down to a better level..
fyi my noise level is really high as well when using the 10k / 1k8
problemchild
melbourne australia
