  Muied Lumens Frequencies
My Alesis Andromeda A6 Editor & VST
Page 1 of 4 [79 Posts]
Goto page: 1, 2, 3, 4 Next
Pollux
PostPosted: Wed May 08, 2013 9:10 am    Post subject:  My Alesis Andromeda A6 Editor & VST
Subject description: EXE Editor & VST, Windows & macOS
Alesis Andromeda A6 VST
Thank you to everyone who showed an interest in this project and kept posting here over the years!
You can locate more information about my Andromeda A6 Editor @ https://analogdessert.com/downloads/alesis-andromeda-a6-vst-editor/
- Standalone .EXE Editor or VST Editor
- 32-Bit, or 64-Bit Windows XP, 7, 8, or 10
- macOS supported via WineBottler
I know, the GUI is pretty basic at the moment, but as time allows, it will be beautified !
Feature List :
Save Patches on the Computer (as .FXP Files, Loadable & Saveable with DAW Projects)
Save Patches on the Andromeda
Fine Tuning of Parameters (Min Value, Max Value, Step Size, Curve (Linear, Exponential Values)
Auto Tune
Program Change
Filter Bypass
Transpose
Velocity Curve
Velocity Sensitivity
Aftertouch Sensitivity
Midi Channel
Keyboard Transmit Mode
Backgroung Tuning Toggle
Temperature Tuning Toggle
Master Tune Adjustment
Voice Level
Voice Modulation Level, Offset, Destination, Source
Voice Pan
Voice Pan Modulation Level, Offset, Destination, Source
Unison Voices
Unison De-tune
Engine Optimizer Osc
Engine Optimizer Filter
Oscillator (1/2) Level
Sub Oscillator (1/2) Level
Oscillator (1/2) Frequency
Oscillator (1/2) Fine Tune
Oscillator (1/2) Cent Tune
Oscillator (1/2) Sine/Tri/Saw/Sqr Waveform Toggle
Oscillator (1/2) Square Width
Oscillator (1/2) Modulation 1/2/3 Enabled, Level, Offset
Oscillator (1/2) Modulation 1/2/3 Source
Oscillator (1/2) Modulation 1/2/3 Destination
Oscillator 1/2 Linear FM Level
Oscillator 1/2 Exponential FM Level
Oscillator 1 Exponential FM 2 Level
Oscillator 1/2 PWM FM Level
Oscillator 1 PWM 2 FM Level
Oscillator 1 Noise Source
Oscillator 1 FM Assign
Pre-Filter Filter 1 Mix Level
Pre-Filter Filter 1 Low-Pass Level
Pre-Filter Filter 1 High-Pass Level
Pre-Filter Filter 1 Band-Pass Level
Pre-Filter Filter 2 Low-Pass Level
Pre-Filter Level
Ring Modulation Level
Ext. Noise Level
Noise Level
Noise Type
Filter 1/2 Cutoff
Filter 1/2 Resonance
Filter 1/2 Envelope 2 Level, Offset
Filter 1/2 Key Track
Filter 1/2 Modulation 1/2/3 Enabled, Level, Offset
Filter 1/2 Modulation 1/2/3 Offset
Filter 1/2 Modulation 1/2/3 Source
Filter 1/2 Modulation 1/2/3 Destination
Analog Distortion Level
Analog Distorion Send Level
Analog Distortion Type
Distortion To Main / FX 1 / FX 2
Digital FX Toggle
Digital FX Input Level
Digital FX 1/2/3 Output Level
Envelope 1/2/3 Delay,
Envelope 1/2/3 Attack
Envelope 1/2/3 Decay, Decay 2, Decay 2 Level
Envelope 1/2/3 Sustain
Envelope 1/2/3 Release, Release 2, Release 2 Level
Envelope 1/2/3 Shape
Envelope 1/2/3 Offset
Envelope 1/2/3 Level
Envelope 1/2/3 Polarity
Envelope 1/2/3 Dyn Key Track
Envelope 1/2/3 Dyn Lvl Track
Envelope 1/2/3 Dyn Rel Mod
Envelope 1/2/3 Dyn Velocity Mod
Envelope 1/2/3 Modulation 1/2/3 Trig Enabled, Level
Envelope 1/2/3 Modulation 1/2/3 Trig Source
Envelope 1/2/3 Modulation 1/2/3 Trig Mode
Envelope 1/2/3 Modulation 1/2/3 Trig Polarity
Envelope 1/2/3 Modulation 1/2/3 Enabled, Level, Offset
Envelope 1/2/3 Modulation 1/2/3 Source
Envelope 1/2/3 Modulation 1/2/3 Destination
Sequencer STOP / START Switch
Sequencer Sync Source
Sequencer Step Resolution
Sequencer Step Size
Sequencer Length
Sequencer Loop Type
Sequencer Loop Count
Sequencer Progressor Min, Max
Sequencer Key Trigger
Sequencer Mono Legato
Sequencer Trig Enabled, Level
Sequencer Trig Source
Sequencer Trig Polarity
Sequencer Trig Retrig
Sequencer Tempo Modulation Enabled, Level, Offset
Sequencer Tempo Modulation Source
Portamento Time
Portamento Speed
Portamento Curve
Portamento Mode
Portamento Osc / Filter Options
Portamento Start Mode
Portamento Offset
Portamento Modulation Level, Source, Offset
Coming Soon :
Mix Mode / Mix Channel Support
More Digital FX Parameters[list=][/list]
Helge Kautz
PostPosted: Fri May 10, 2013 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Suggestion: Have you looked at this free project here?
http://ctrlr.org/
If you are going to make a GUI, this project may alleviate lots of groundwork for you. All the MIDI communication routines and graphical stuff should already be in it.
And as an added bonus, the resulting GUI will be multi-platform (Win, Mac, VST, AU)
Helge
Pollux
PostPosted: Fri May 10, 2013 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I am coding my own GUI from Scratch, but this looks way cleaner, and full of fancy GUI Controls. Thanks for the resource! Very Happy Seems easy to implement, which is no problem, because I know all languages Very Happy
Steinklopfer
PostPosted: Sun May 26, 2013 4:07 pm    Post subject: go for it Reply with quote  Mark this post and the followings unread
"which is no biggie because I know them all" wave go on...you're the nerd we're looking for Smile
Pollux
PostPosted: Fri Jul 12, 2013 11:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lol Razz Okay, maybe a bit of an overstatement Wink
Pollux
PostPosted: Sat Jul 13, 2013 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Edit:
Here's a quick, gritty sound I dialed in with my VST. Nothing special -- but you can hear me editing some stuff in real-time. Very very valuable asset to have for producing.
http://puu.sh/3CtUh.mp3
Steinklopfer
PostPosted: Thu Jul 18, 2013 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, I'm just one person, but I definitely got interest in it. You got some new screenshots of the gui? Greets
Pollux
PostPosted: Thu Jul 18, 2013 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Slowly, but surely, a shitty looking GUI is coming along. Hehe.
EDIT: The currently released version does not look like this -- the screen shot here was of the version I lost when I reinstalled Windows Embarassed
goldphinga
PostPosted: Mon Jul 22, 2013 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Any quick ways to set up modulations and easily setup say and aftertouch routing would be amazing....
Pollux
PostPosted: Mon Jul 22, 2013 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Stay tuned, coming soon Smile
RETRIVOX
PostPosted: Sat Dec 14, 2013 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is this thread dead? Hope it's not!..
junosound
PostPosted: Sun Dec 15, 2013 8:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am very interested in this as well and would be willing to pay for it.
To me personally the GUI wouldn't need to be fancy. It'd sure be very nice but having an editor in the first place is more important to me Wink
If all parameter even in the submenues and Andromeda's settings could be edited (if this is even possible) this would be an absolute power tool and I'd stretch my wallet even further Wink
untinyunity
PostPosted: Wed Jan 01, 2014 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hope this thread is not dead!
Would love an editor for the old andy. Im still to be considered a beginner on the a6, but if this means to be able to recall and control 16 channels in my DAW, its good news.
Then I would love to see control over the fx section and routings as well Smile
Synthwall
PostPosted: Sat Jan 04, 2014 6:42 pm    Post subject: vst andromeda routings to lfo filter and osc
Subject description: wouold be nice to have the routings available on vst controls
the andromeda can be very sensitive with the jumping knobs, it makes it terrible to tweak the value of the functions in the routings
lfo to filter controls would be nce to have as vst control
not specificly for automation but for building patches
also the sequencer is time consuming to program with the sensitive jumping softpods
great work allready
grtz
happy 2014
beesting
PostPosted: Sun Jan 05, 2014 6:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would love a VST editor for the Andy!
ProFete
PostPosted: Wed Apr 02, 2014 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am very interested in this as well and would be willing to pay for it, me too
Synthbrass
PostPosted: Sat Aug 08, 2015 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for bumping this old thread but are there any news abot this Vst? I´d really love using it (in Fl Studio) and I am also willing to pay for it!
Stefan Leutwyler
PostPosted: Sat Aug 22, 2015 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow that would be super nice. i am very interested in a vst editor for andromeda and for sure i am willing to pay fort this software.
I made my own cubase editor in which i can save the banks and with 8 controllers connected to the CC:Gen Purp A - H. So i can route all the andromeda knobs to one of these 8 controllers. But a vst would be much more easyer!
Please go for it mate!
Pollux
PostPosted: Sat Sep 12, 2015 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Everyone!
This thread Is not dead Very Happy But I have some good news, and some bad news. The bad news Is that, when I formatted my hard-drive I forgot to backup a source-code folder, and this was one of the projects I lost. The good news Is that I justttt started recreating this editor (along with a Juno-106 one)
Infrablue
PostPosted: Mon Oct 05, 2015 6:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
So good to hear you are still at it. VERY interested! Such data losses hurt BADLY. I know it. lol
Pollux
PostPosted: Mon Apr 04, 2016 8:14 am    Post subject:   Reply with quote  Mark this post and the followings unread
I have started development on this plugin again.
Functionality and code wise, I am back to the point where I have most of the buttons & knobs on the front of the Andromeda controllable by my VST. Very Happy Very Happy I haven't scratched the surface in regards to controlling modulation assignments yet. That's next, along with adding an A6-GUI like I had before.
The so-so news: The plugin only works on Reaper, and FL Studio. Those are the only DAW's which support SysEx, and have the extremely flexible routing configurations needed for this plugin to work. (The one's I've tested on with no success, were BitWig Studio (No Sysex support), Cubase (Sysex can only be sent from MIDI Tracks. And one cannot insert VST's to MIDI tracks) , and Ableton Live 9 (No Sysex support).
ProFete
PostPosted: Wed Apr 06, 2016 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
good news
sonar cakewalk also fully support sysex...
Pollux
PostPosted: Thu Apr 07, 2016 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tonight, or sometime this weekend, I will add some additional functionality to the VST (LFO, and Envelope Dynamics parameters), and I've decided to post an alpha release version here for all to enjoy, play with, and give feed back on.
sunny pedaal
Audio files: 12
PostPosted: Thu Apr 28, 2016 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
great
would it work under bidule ? ( free to use as standalone version )
Pollux
PostPosted: Thu May 05, 2016 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've updated my original opening post. Why don't you let us know Very Happy
