  Muied Lumens Frequencies
Dual gate slew
Page 1 of 1 [6 Posts]
isak
PostPosted: Sat May 25, 2013 10:21 am    Post subject:  Dual gate slew Reply with quote  Mark this post and the followings unread
Hi Yves.
I have few quotations about this module.
1. As i read and from what i understand The BS170 is only for the led lighting, correct?
It have nothing to do the main operation of this module?
2. can I use only with one section of the module for 2 vco's, If yes, do I need to buffer the output to control 2 vco's?
3. From what i read the gate works only with log mode, Can I use the gate mode with the Lin mode as well, if yes, how?
4. I want only one pot for both modules, but I can only find 1M Lin dual pot, is that ok to use?
My main goal is to be able to control 4 vco's with the Dual gate slew module.
I thank you in advance,
Isak E.
yusynth
PostPosted: Sun May 26, 2013 1:31 pm    Post subject: Re: Dual gate slew Reply with quote  Mark this post and the followings unread
Hi Isak
1. Yes it is correct.
2. Yes you can and it's not necessary to buffer the output for two VCOs
3. I made the LIN slew not gated intentionally because it does not work correctly. The gate FET in linear mode happens to operate as a current source/sink which interfere with the slew function, this is why I deactivated the combination of the LIN mode and the GATE mode.
4. There are dual log pots (www.musikding.com) if you use linear all the slew range will be concentrated in a very short run of the potentiometer wiper, acting more like an ON/OFF than a continuous adjustment.
isak wrote:
Hi Yves.
Isak E.
Yves
isak
PostPosted: Sun May 26, 2013 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Yves.
that's is a damn cool glide module. Smile
isak
PostPosted: Mon May 27, 2013 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Another question if I may please...
I'm gonna use the module with midi to cv, do you maybe see any problem, maybe I need to buffer the output of the midi to cv before going into the module?
This what gonna use with your module.
http://www.acxsynth.com/midi2cvlite/midi2cvlitefr.htm
Thanks again.
yusynth
PostPosted: Mon May 27, 2013 1:09 am    Post subject: Reply with quote  Mark this post and the followings unread
It should work fine together.
Yves
isak
PostPosted: Mon May 27, 2013 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you Smile
