Fourier analysis & adding harmonics
Page 1 of 1 [8 Posts]
audiodef
Audio files: 42
PostPosted: Mon May 27, 2013 6:40 pm    Post subject: Fourier analysis & adding harmonics
Subject description: Experimentation advice sought
I'm doing some experimentation and for that, I want to:
1. Filter out everything above a certain frequency (probably 250 Hz). This is easy enough.
2. Deconstruct the signal as much as possible. I'm thinking Fourier analysis.
3. For each single frequency present, add n number of harmonics at amplitudes yet to be determined.
4. Mix that back into the original signal.
This isn't the experiment - just something I want to do as part of it. I figure you guys might know some way to make these steps happen.
Audiodef
Gentoo Studio
Audio files: 81
PostPosted: Tue May 28, 2013 3:44 am    Post subject: Reply with quote  Mark this post and the followings unread
You want to remove harmonics, and then add them bqck again? why not just leave them there to begin with?
I think u might be able to do some of this with isotope Iris. You can get a ten day trial on their website.
JacobWatters.com
audiodef
Audio files: 42
PostPosted: Tue May 28, 2013 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, no, I don't want to remove harmonics. I want to add additional harmonics, but under very controlled circumstances. And to add a further point, the signal in question is actual music, not just a tone, patch or sound.
Audiodef
Gentoo Studio
Audio files: 336
PostPosted: Tue May 28, 2013 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
To add harmonics to a signal, just distort it. Maybe you should look into waveshaping. It is hard to work out exactly what you want to do though...
Muied Lumens Base Star
Acoustic Interloper
Audio files: 79
PostPosted: Tue May 28, 2013 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
The low-pass filtering does remove harmonics, along with any high-frequency inharmonic signal components.
ChucK's audio analysis ugens would give you a way to operate in the frequency domain and then convert back. I haven't done that in ChucK, but I am sure folks on the ChucK mailling list have.
I did something along these lines to allow myself to sing in three-part harmony using a Max/MSP patch with an fft and ifft a few years back. Pure Data (PD) appears to have the required ugens, and like ChucK it is free.
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
audiodef
Audio files: 42
PostPosted: Tue May 28, 2013 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hm... I don't want to distort anything. The low-pass filtering would be just to remove everything above 250 Hz, harmonics and all. That's OK.
I figured I might be using ChucK or Supercollider or something like that.
I've been way too vague, and I'm sorry. I just didn't want to get boring. Razz
What I'm doing is experimenting with ways to make bass richer for people with cochlear implants who listen to music. See, bass is a bit thin. What I've found in some preliminary testing is that a fundamental frequency - a sine at 55 Hz - sounds noticeably fuller when I add two harmonics at 110 and 220 Hz with relative amplitudes of 1/4 and 1/8 (I started with the first harmonic being at a relative amplitude of 1/2, but that just resulted in octave unity). This was the perceived result with my implant.
So now I want to see if I can apply this by breaking down a music signal, filtering out the lowest fundamentals, and adding harmonics in the same way. If this does anything useful for perception, I can send this info to Advanced Bionics, and if they're so inclined, they can translate that into a future software upgrade for their external processors.
Audiodef
Gentoo Studio
[Q]
Audio files: 57
PostPosted: Tue May 28, 2013 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
This should do it.. Smile
http://www.klingbeil.com/spear/
only mac/windows Sad
audiodef
Audio files: 42
PostPosted: Tue May 28, 2013 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
SPEAR looks very useful, thanks!
I was able to run it on WINE (although I had to upgrade to the latest unstable version to run it).
Audiodef
Gentoo Studio
