  Various Artists Live streaming concert in memory of Antimon
Akai AX-60 problem with noise generator
Page 1 of 1 [6 Posts]
patrickvf1976
PostPosted: Tue Jan 15, 2013 11:54 pm    Post subject: Akai AX-60 problem with noise generator Reply with quote  Mark this post and the followings unread
My Akai AX-60 has a problem with the noise generator - the noise generator's output has become extremely low all of a sudden and I can't figure out what happened. It was working just fine yesterday and I was able to make some nice thunder and swoosh kind of sounds. Now it struggles to get to a reasonable volume. Everything else works just fine. Any ideas what could cause this problem?
patrickvf1976
PostPosted: Sat Jan 19, 2013 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
So.. any suggestions, advice, anything? Anyone? Help??
patrickvf1976
PostPosted: Tue Jan 29, 2013 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Still could use some help here. Any hints what to look for or even some schematics would do.
sneakthief
PostPosted: Tue Jan 29, 2013 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://manuals.fdiskc.com/flat/Akai%20AX-60%20Service%20Manual.pdf
first hit on google Razz
Either 1) the noise generator isn't working or 2) the circuit that turns off both noise generators for Noise A and B. 1 seems more likely.
page 40 says that TR4, TR5 and IC21 are responsible for the noise
On page 37, you'll find the noise schematic. It uses these parts:
IC21: BA715STD
TR4: 2SC 3330
TR5: 2SC 3383
Check along the signal path to see if you're getting noise. The schematic lists voltages next to the ECB's of the transistors - that's a good and easy place to start to see if either are blown.
Sneak-Thief - raw electrofunk
patrickvf1976
PostPosted: Tue May 28, 2013 11:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finally found some time to open it up and look into it.. what's the best way to check the signal path? I don't have an oscilloscope, just a multimeter which I use to check common components with (caps, op-amps, etc...) I never went that technical as in using a service manual other than some schematics from the web for my really old gear.
patrickvf1976
PostPosted: Tue May 28, 2013 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nevermind.. failed to read the part with the voltages.. freakin' ADD Rolling Eyes
So.. can the transistors be substituted for by regular Radioshack transistors or do they have to be exatly this type?
