  Muied Lumens Frequencies
Annimator and Ring Mod Question
Page 1 of 1 [15 Posts]
jmcecil
PostPosted: Sun May 26, 2013 5:59 pm    Post subject: Annimator and Ring Mod Question Reply with quote  Mark this post and the followings unread
I'm working on several of the Yusynth projects. Wow, thanks a ton. I can't believe how awesome and informative these things are to those of us just starting. THANK YOU!
1) On the Saw animator there are 12 100k resistors listed on the BOM. On the PCB I received from bride chamber the one nearest the edge of the PCB (R13?)is shown as a 10k on the PCB. Unfortunately, I can't read the circuit well enough yet to know which R# it really is. It's the one just to the right of CV1 and at the edge of the PCB. Anyhow, is that a typo on the PCB, or did that get turned into a 10K?
2)On the Dual Ring Modulator, I couldn't find 220 Ohm trimmers. Is something larger like a 250 or 500 ok?
Thanks for any help you can provide
Jeff
capicoso
PostPosted: Sun May 26, 2013 9:55 pm    Post subject: Re: Annimator and Ring Mod Question Reply with quote  Mark this post and the followings unread
For the saw animator, http://yusynth.net/Modular/Commun/SAWANIM/sawanim-COMP-LAY2.jpg
i suppose it's 100k. On the schematic R13 is 100k, usually the typos are in the pcb layout, always refer to the schematic since it's the original... the others are adaptations from the schematic, and errors can happen
for the ring modulator 250 is fine
yusynth
PostPosted: Mon May 27, 2013 1:13 am    Post subject: Reply with quote  Mark this post and the followings unread
As capicoso says Cool
Yves
jmcecil
PostPosted: Mon May 27, 2013 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you!
jmcecil
PostPosted: Wed May 29, 2013 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm ... closest trimmer I can find is 500 ohm. Is that to far out of range?
yusynth
PostPosted: Wed May 29, 2013 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
yes it's too high
Yves
jmcecil
PostPosted: Wed May 29, 2013 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
figured you'd say that Very Happy
No one seems to carry them in the US. The only ones in the 200->400 ohm range are the tripod kind. I have a bourns part number, but they don't seem to be carried by anyone.
Anyone know where you can get a 220 ohm trimmer in the US?
jmcecil
PostPosted: Mon Dec 23, 2013 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry to resurrect this topic, but I still can't find a 220 ohm trimmer anywhere. I've even tried contacting Bourns directly ... I can buy a lot of 1000 from them Razz
Anyone have a clue where to source a couple 220 ohm trimmers? I've tried 200 ohm, but can't get it to go anywhere near silent during the trimming process. Any help would be appreciated.
yusynth
PostPosted: Mon Dec 23, 2013 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
You may try using a 500 trimmer and use a 270 ohm resistor connected between the extreme legs of the trimmer, this way the circuit sees the good resistor value.
Otherwise I checked on the Mouser's site and there are some product references :
652-3296W-1-221ALF
652-3296W-1-221LF
652-3296Y-1-251LF
652-3296X-1-221LF
Yves
jmcecil
PostPosted: Mon Dec 23, 2013 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
652-3296W-1-221ALF
652-3296W-1-221LF
652-3296Y-1-251LF
652-3296X-1-221LF
Thank you for the reply ...
From what I can see, those are the parts that I can order in quantities of > 1000. I had actually contacted Mouser directly, and they tried quite hard to find some for me. They were really helpful and even suggested I try Bourns through a "demo" program.
Anyhow, if I read your suggestion correctly, I can take 1 270ohm resistor and solder it to the two outside legs of the 500ohm pot? I think I have both of those parts handy.
Thanks again ... I've built quite a few of your modules! I can't thank you enough for your site and info.
gregcomposition
PostPosted: Mon Dec 23, 2013 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
Maybe I'm wrong, but I think the popular 200 ohm trimmers could replace the 220 ohm? I used them in my Ring Modulator and they do the trick.
Embarassed Ups, you wrote that you have tried it and it doesn't work. Sorry, I missed your previous post.
If not - I've done a little research - here you have a 250 ohm trimmer with a 1 piece minimum order quantity:
http://www.newark.com/bourns/3299w-1-251lf/trimmer-pot-250-ohm-10-25turn/dp/06X8985
Best regards,
Greg
jmcecil
PostPosted: Mon Dec 23, 2013 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
gregcomposition wrote:
Hi!
Best regards,
Greg
Interesting. You used 200s in for this project? I can't get the signal to go even close to negated. Maybe there is something else wrong in my build.
gdavis
PostPosted: Mon Dec 23, 2013 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
Best regards,
Greg
I think you have another problem. 220 vs. 200 shouldn't cause an issue. The trimmers have a 10% tolerance anyway which means that a 220 ohm could actually be as low as 200.
gregcomposition
PostPosted: Mon Dec 23, 2013 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I made this module a couple months ago as the one of first modules made by myself. I reduced it to the only one ring mod (AxB), then connected all parts on a common universal PCB using just the schematic diagram. As you can see, there is a 200R trimmer among its. I don't remember yet if I've got some problems with trimming it but it's working as is.
All my best,
Greg
 Filesize:  110.26 KB
 Viewed:  87 Time(s)
jmcecil
PostPosted: Tue Dec 24, 2013 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I appreciate the information. I should mention that I am getting Ring action. I just have a lot of bleed. So that's why I thought it was a trimmer problem. But, I'll go back through and see if I have something else screwed up.
