lucid
Joined: Dec 03, 2012 Posts: 19 Location: Slovakia, EU
Posted: Mon Mar 04, 2013 3:26 am Post subject:
elmegil wrote: | Do you have 2 150Ks? |
this
thanks |
logicgate
Posted: Mon Mar 04, 2013 6:50 am Post subject:
Hello guys!
Can I get away by using 1,87K 3500ppm tempcos for this project???
Cheers! |
Gaetano_AU
Posted: Tue Mar 05, 2013 3:59 am Post subject:
Boards Arrived Matthias, nicely packed, thanks :) |
Boards Arrived Matthias, nicely packed, thanks |
Posted: Tue Mar 05, 2013 2:14 pm Post subject:
logicgate wrote: | Hello guys!
Cheers! |
w/o doing the maths: i don't believe you will achieve the 1V/oct using the 1k87... _________________
Tech Buddy at Random*Source |
Posted: Tue Mar 05, 2013 2:18 pm Post subject:
payment details |
i sent out PMs/emails to all who ordered PCBs/panels. please check you PM's, i am missing the response of quite a few people. _________________
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Wed Mar 06, 2013 5:53 am Post subject:
I'm assuming the farnell pots I linked won't fit this project?
Any other sources (that are not wildly expensive)? _________________ LektroiD |
Posted: Wed Mar 06, 2013 2:11 pm Post subject:
they would fit the footprint, buuuut:
they are not high enough.
farnell offers other alps with a longer shaft, but alas, these are D-shaft, too. and D-shaft would not be cool with the LFO, since not all potentiometers are mounted with the same orientation...
BTW i built two modules with the alps (get them cheap here in germany , and with a full shaft), and they don't have enough tension IMHO. doesn't feel right to me. _________________
Posted: Wed Mar 13, 2013 2:42 am Post subject:
Re: payment details |
fonik wrote: | i sent out PMs/emails to all who ordered PCBs/panels. please check you PM's, i am missing the response of quite a few people. |
AlasdairMoons
Joined: Dec 03, 2011 Posts: 105 Location: East-Belgium
Posted: Thu Mar 14, 2013 12:54 am Post subject:
the tempco's are to reduce drift due to temperature changes. this gets more important the longer the takes are you recording, and if you are interested in more precise tuning between the tracks. _________________
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Fri Mar 15, 2013 12:24 am Post subject:
boards received in OZ all good
thanks again Matthias. _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
jp1971
Posted: Wed Mar 20, 2013 9:55 am Post subject:
PCB offer: Thomas Henry's 555-VCO |
Sorry for coming to this thread late. Are there any PCBs left? If so, I would like to order:
1x circuit PCB
1x eurorack PCB
1x front panel
Thanks,
jp1971 |
Posted: Thu Mar 21, 2013 8:11 am Post subject:
there are quite a few open orders, and i actually wanted to keep a few spares just in case something gets lost in the mail. but i will put you on the waiting list. _________________
doobedy
Posted: Fri Mar 22, 2013 12:38 pm Post subject:
Man I just noticed the prototype had an LFO switch and LED. I wish those had made it to the panel as well.
Is that just a switch changing capacitor values? How is the LED done? Not that I see room on the panels to fit anything on there. I was thinking of a wave folder to go between my two VCOS, maybe I could add an LED and LFO switch to that as a custom panel.
Did TH specifically ask you not expand his circuit in any way? |
modulardoom
Posted: Mon Apr 01, 2013 5:04 pm Post subject:
if it would be still possible i would like to order
1 circuit pcb
1 eurorack pcb
1 front panel |
Constantin
Posted: Sun Apr 07, 2013 3:58 am Post subject:
If there are still some pcbs available, I would be in for
4 circuit PCB
thanks
Constantin |
Posted: Thu May 30, 2013 10:44 pm Post subject:
interest in more of the PCBs/front panels?
i will gather/gain interest until 21 JUN 2013 and re-order what is needed...
for the front panels i would need to order at least 30pcs, though. the price for a single front panel would be 10.-EUR/13.-USD now. _________________
jackdamery
Posted: Fri May 31, 2013 2:11 am Post subject:
3 main boarde PCBs please and 4 euro pcbs |
Boerge
Posted: Fri May 31, 2013 3:08 am Post subject:
I would take 1 main PCB too.
regards
Boerge _________________ ...ich will doch nur löten... |
TheAncientOne
Joined: Dec 26, 2006 Posts: 144 Location: United Kingdom
Posted: Fri May 31, 2013 9:06 am Post subject:
fonik wrote: |
I know Rean do knobs for D shafts in all 4 compass points of orientation. If you've mounted the pot at an angle, you're out of luck. The Rean's are nice and slim too.
http://reanknobs.com/forums.html?id=26 _________________ Mike |
TheAncientOne
Posted: Fri May 31, 2013 9:30 am Post subject:
Oh, and I forgot: Another two are alive! A smooth build, once I found the errata notes. I used 100K trimmers for sine round, and got an easy +/-5V
One though for Fonik - could you think of leaving a larger footprint area, with perhaps multiple pinouts, (as the late Jurgen Haible did on his PCBs), for the timing caps. I have a lot of High quality 2n2 polystyrenes, (and yes - I will give batches of then out for postage), but I couldn't get them to fit. I just squeezed some 2n2 polypropylenes I had in stock into place, and I will try the COG's in future, but I think a little more flexibility in the capacitor area would be a good idea. There was plenty of PCB real-estate left. The capacitor footprint Jurgen used is no way unique or copyright, so there would be no problem in just 'lifting' it. I'm sure the man would be smiling down his approval if you did, anyway.
A minor point really. My thanks again to Thomas Henry and Fonik for a really nice VCO with a massive range., and a very easy build.
Note for other builders on transistor matching: I tested 2n3906's from a bag of 100 bought from 'Rapid' I was able to get 4 with gains identical out of 20 or so tested, and the maximum gain variation I read was +/- 10 on a nominal 230 median value. I think just using two from the same manufacturer and date code would be fine.
Description: |
Filesize: |
172.66 KB |
Viewed: |
726 Time(s) |
jackdamery
Posted: Fri May 31, 2013 9:32 am Post subject:
TheProf, I see you're in the UK too. Where did you get your 2k 3500ppm tempcos? |
Joined: Jan 07, 2009 Posts: 1196 Location: Scottish Borders
Audio files: 155
Posted: Fri May 31, 2013 1:24 pm Post subject:
Hi Matthias.
2nd order interest, could i please order.
4 - Main pcb.
Thanks.
Dave |
TheAncientOne
Posted: Fri May 31, 2013 2:36 pm Post subject:
I got one batch from 'Magic Smoke Eectronics' and the others from Farnell, but it seems they only have the 2K ones in SMT, now. I future I will be using the SMT ones because it's easier to get a closer bond the to the transistor package. The could even be mounted inside an IC socket to get a close contact with a socketed dual pair, and to avoid the effects of drafts. _________________ Mike |
JasonMichener
Posted: Sun Jun 02, 2013 2:42 am Post subject:
I would like:
2 x circuit
2 x euro
2 x panels
Thanks! |
