Chuck on the Raspberry Pi?
Page 1 of 1 [9 Posts]
eem
PostPosted: Wed Dec 19, 2012 12:30 pm    Post subject: Chuck on the Raspberry Pi? Reply with quote  Mark this post and the followings unread
Hi all,
Does anyone ever tried/succeeded to run chuck on a Raspberry Pi? It would be the perfect platform for a cheap monitorless OSC/MIDI chuck station!
Nicolas
Electronique et Musique blog
eem
PostPosted: Mon Dec 24, 2012 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, here is where I am after some time trying to get Chuck run on the Raspberry Pi.
First thing to do, get chuck:
sudo apt-get install chuck
Chuck should install with no problem, but if you try to run it, you would get:
chuck test.ck
[chuck]: (via rtaudio): no devices found for compiled audio APIs!
[chuck]: cannot initialize audio device (try using --silent/-s)
So at this point I tried to install and run JACK, but for some reason, I cannot manage to start the server. Instead I get a "bus error", and I still have to work this out.
Meanwhile I noticed a "chuck.alsa" installed along with the regular "chuck". So I tried launching my test.ck with this chuck.alsa, and it worked. Good news!
Later on, I tried a sketch dealing with OSC receiving, and it failed, saying "undefined type 'OSCSend'..." So I still have to investigate a bit.. I will let you know!
Nicolas
PostPosted: Mon Dec 24, 2012 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't have one of these and I haven't done anything with chuck in a while, but your efforts to make them work look interesting. I look forward to reading more of your experimentation.
Steve
eem
PostPosted: Tue Dec 25, 2012 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, chuck v1.3.1.3 is now running on my RPi! Eventually I did not use the binary installed by apt-get. Instead I had to download the sources and compile chuck and other dependencies.
Requirements:
- alsa-lib-1.0.25.tar.bz2: http://www.alsa-project.org/main/forums.html/Download
- libsndfile-1.0.25.tar.gz: http://www.mega-nerd.com/libsndfile/
- chuck-1.3.1.3.tgz: http://chuck.cs.princeton.edu/
Install the ALSA library
On my RPi, chuck compilation failed because of "alsa/asoundlib.h" missing. I realized that whereas ALSA is installed and running properly, the include files are not installed. So I installed alsa-lib:
Code:
tar -xjf alsa-lib-1.0.25.tar.bz2
sudo ./configure
sudo make
sudo make install
Then the /usr/include/alsa directory appeared.
Install libsndfile
Code:
tar -xvf libsndfile-1.0.25.tar.gz
sudo ./configure
sudo make
sudo make install
Install chuck
I followed the instructions given at http://chuck.cs.princeton.edu/doc/build/:
Code:
tar xvzf chuck-1.3.1.3.tgz
cd chuck-1.3.1.3/src/
sudo make linux-alsa
I tested the newly created chuck with some of my sketches, and everything seems to be fine! The performances should be closely monitored though, with quite an high CPU usage.
One last thing, in order to get the sound from the headphone jack output while using the HDMI video:
Code:
sudo amixer cset numid=3 1
Here it is, I hope this will be useful to others!
Nicolas
PostPosted: Tue Dec 25, 2012 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very cool! Nice bit of research there. Smile
PostPosted: Tue Dec 25, 2012 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congrats!!! Glad to hear you got it working. Nice documentation for others who might want to give it a try.
Steve
witt0191
PostPosted: Sat Dec 29, 2012 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
very cool will try this next week
Scott
tony
PostPosted: Fri Jun 07, 2013 2:19 am    Post subject: not work with usb soundcard external Reply with quote  Mark this post and the followings unread
hi all I following your step its succsessfull , I am try with onboard soundcard it no problem but when using external usb sound card it not work, I got message
Code:
[chuck]: RtApiAlsa::getDeviceInfo: pcm device (hw:1,0) data format not supported by RtAudio.
[chuck]: RtApiAlsa::getDeviceInfo: snd_pcm_open error for device (hw:1,0), Device or resource busy.
[chuck]: RtApiAlsa::probeDeviceOpen: pcm device (hw:1,0) won't open for input.
[chuck]: cannot initialize audio device (use --silent/-s for non-realtime)
I dont know why, please if you know how to solve this problem, let Me know
thanks[/code]
nightstraveler
PostPosted: Fri Jul 04, 2014 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
When I try the steps described above I get the following when running
Code:
sudo make
in libsndfile directory
Code:
  CC     chanmap.lo
  CC     id3.lo
  CCLD   libcommon.la
  CCLD   libsndfile.la
GSM610/.libs/libgsm.a: member GSM610/.libs/libgsm.a(table.o) in archive is not an object
collect2: ld returned 1 exit status
make[2]: *** [libsndfile.la] Error 1
anyone else get this or know a way around it?
thanks![/list][/code]
