Joined: Apr 03, 2004 Posts: 24075 Location: The Netherlands, Enschede
Audio files: 277
Posted: Thu Jun 13, 2013 3:24 pm Post subject:
Skrog Productions wrote: | Hi , could i update my old photos that come up on the radio page when Epicyclus port is on, Thanks.. |
Was going to do that, someone else was faster, Thanks _________________ Jan
Audio files: 705
audiodef
Audio files: 53
Posted: Fri Jun 14, 2013 6:08 am Post subject:
Muied Lumens wrote: | audiodef wrote: | Updated my description (it's on page 1 of this thread).
(This is for streaming metadata.) |
You normally supply the metadata yourself - this is what will show up in people's players when you are playing. Is that what you meant? |
D'oh! I forgot about that. Yeah, that's what I meant. _________________ There's an invisible radio gnome playing a gong from a flying teapot - don't miss out! |
Audio files: 277
Posted: Wed Jun 19, 2013 10:25 am Post subject:
The time is neigh ... just a couple more days ... may I invite you to run a port test please?
That is, the people not having a * yet in http://electro-music.com/wiki/pmwiki.php?n=Calendar.20130622 . _________________ Jan
mtvic
Joined: Feb 03, 2003 Posts: 523 Location: Townbank Cape May NJ
Audio files: 277
Posted: Thu Jun 20, 2013 11:48 am Post subject:
tick tock tick tock
pretty please test your ports? _________________ Jan
shanemorris
Audio files: 92
Posted: Thu Jun 20, 2013 11:56 am Post subject:
I made an announcement on the FB event group and tagged the remaining untested ones. I suspect they will be coming in today and tomorrow. _________________ ElectroCasa |
Audio files: 277
Posted: Thu Jun 20, 2013 12:16 pm Post subject:
thanks :-) _________________ Jan
Synthrabbi
Joined: Jan 31, 2013 Posts: 10 Location: Northern California, USA
Posted: Thu Jun 20, 2013 7:29 pm Post subject:
about to do so right now |
Joined: Mar 28, 2006 Posts: 1353 Location: Kansas City, Mo USA
Posted: Thu Jun 20, 2013 7:49 pm Post subject:
shanemorris wrote: | I made an announcement on the FB event group and tagged the remaining untested ones. I suspect they will be coming in today and tomorrow. |
Shane, I hope I can test tomorrow afternoon -- I just got home and I'm beat this evening. Thanks! _________________ -- Kevin
http://kevinkissinger.com |
JovianPyx
Audio files: 224
Posted: Thu Jun 20, 2013 7:59 pm Post subject:
Synthrabbi has tested successfully, please put a dot/star thingy for him. _________________ FPGA, dsPIC and Fatman Synth Stuff
Acoustic Interloper
Joined: Jul 07, 2007 Posts: 2067 Location: Berks County, PA
Audio files: 89
Posted: Thu Jun 20, 2013 8:10 pm Post subject:
The string-picking fingernails that I trimmed two weekends ago are almost back at perfect length. So, we can check that off _________________ When the stream is deep
my wild little dog frolics,
when shallow, she drinks. |
Synthrabbi
Posted: Fri Jun 21, 2013 1:39 am Post subject:
JovianPyx wrote: | Synthrabbi has tested successfully, please put a dot/star thingy for him. |
What he said...
Certified by the law firm of Dunn & Dunn |
rdorsche
Joined: Jan 23, 2010 Posts: 84 Location: Syracuse, NY, USA
Posted: Fri Jun 21, 2013 6:21 am Post subject:
(intentional double post - the same message is on the Facebook EM 2013 Solstice topic page)
Hello Everyone!
I pre-recorded my set, since my time slot has a direct conflict with my son's high school graduation ceremony!
But no worries. Charles Shriner is doing me an awesome favor an broadcasting the file for me from his port at my allotted time:
0130 GMT (Robert Dorschel)
I've changed the name of my performance to
"Requiem for the Cicada"
Hopefully all will go well. If not? I have the recording to share with whomever would like a copy (or it will eventually end up on soundcloud).
Thanks and good luck to all the performers!
~Robert
The picture that goes along with the broadcast is here:
https://www.dropbox.com/s/iz1kwshuu5dnlv5/Cicada_cover.jpg |
Audio files: 277
Posted: Fri Jun 21, 2013 10:24 am Post subject:
Done, thanks! _________________ Jan
Audio files: 277
Posted: Fri Jun 21, 2013 3:12 pm Post subject:
mtvic (victroneek)'s time slot was moved up to fill the empty space. I had forgotten to list him anyway all settled there.
Poster updated too now. _________________ Jan
Ganzha
Audio files: 27
Audio files: 277
Posted: Sat Jun 22, 2013 11:01 pm Post subject:
MP3 of my Improvisation Subject description: Improvisation for the 2013 June Solstice Event |
This is another improvised composition performed in real-time on my DIY analog modular synthesizer. It is a continuation of techniques that I've developed over the last few years.
My interest has been to construct music that uses pseudo-randomness -- that is, events that appear to be random but over time reveal themselves as part of an entire texture.
Also, I pondered the possibility of an analog sequencer with enough steps to fill a very long loop (I consider a Very Long Loop to be a loop that is so long that it's identity as a loop isn't apparent -- in general > 20 seconds). The solution that I came up with is to mix the outputs from four VCO's and use them as a control voltage. At the beginning of the Very Long Loop, all the oscillators are reset via a sync signal. This assures that at any given clock position in the loop, the sampled control voltage would be consistent, thus realizing a sequential pattern the same length as the loop.
I chose for today's work to use un-quantized voltage samples to yield microtones.
My thought is that, though the sequence is too long to be human-detectable, the sequence would create a sense of unity to the improvisation.
The resulting patch for this performance is dependent upon a human performer. The patch's control signals manage the complex control voltages and the sample/hold function. The human, in turn, plays the keyboards, makes many adjustments to the patch, and reacts to the events.
Thus, my goal was to create a kind of real-time composition from complex, microtonal material along with spontaneous human input that is required to make this work.
Description: |
Kevin Kissinger's improvisation for the Electro-Music June 2013 Solstice Streaming event |
Download |
Filename: |
EM_Solstace_June_2013_KevinKissinger.mp3 |
Filesize: |
53.13 MB |
Downloaded: |
2021 Time(s) |
EdisonRex
Audio files: 172
Joined: Jan 07, 2009 Posts: 1196 Location: Scottish Borders
Audio files: 155
Audio files: 705
loopzz
darkvortex
Radio Master
Joined: Aug 19, 2011 Posts: 206 Location: Melbourne, Australia
Posted: Sun Jun 23, 2013 6:33 am Post subject:
Here's my recording from today's event.
Made with my ever-evolving live set in Ableton Live. Virtual synths are Ableton Operator, Korg Legacy M1, and Alchemy Player.
The puppy in the picture is my friends dog Rascal. He was acting as my roadie for this gig
Description: |
Crystal Dreams Live 20130623 (CC-BY-NC 3.0 AU) |
Filesize: |
77.2 KB |
Viewed: |
747 Time(s) |
Description: |
electro-music.com June Solstice 2013 by Crystal Dreams (CC-BY-NC 3.0 AU) |
Download |
Filename: |
20130623 - June Solstice 2013.mp3 |
Filesize: |
49.54 MB |
Downloaded: |
1833 Time(s) |
