inlifeindeath
Joined: Apr 02, 2010 Posts: 316 Location: Albuquerque, NM
Posted: Mon Nov 08, 2010 7:34 am Post subject:
Bass++ single voice pcb layout... |
Hey guys!
I've been trying to design a pcb for just a single Bass++ voice (the electronic peasent version). I've been using the free version of Eagle and the small size board they allow you is making it almost impossible! Has anyone laid one of these out? Doesn't have to be the EP version. Thanks! |
inlifeindeath
Posted: Thu Nov 11, 2010 5:21 am Post subject:
Quote: | Eagle and the small size board they allow you is making it almost impossible! |
I am curious about what makes it impossible. Is it because it can't route the design into the board size constraint? If so, maybe changing from DIP to SOIC packages will make it fit. Also, using SMT or 1/8 watt standard axial or thru hole resistors would help you fit the design. I don't want to assume.
Are you willing to to have a PCB manufactured from an Express PCB file? If so, maybe I can hack up my quad version into a single one. You did mention a version I am not familiar with. Is it different than the TH version? If so, what are the deltas? Am I asking too many questions? lol ....... MIne is strictly a TH version. No mods.
OK, lets see what we can do for you.
Bill |
PickNick
Posted: Thu Nov 11, 2010 6:28 am Post subject:
hey!
i already did one...
the first version is based on the original schemo...
the second consist the waveshaper function from EP.
i used eagle.
not the best design, but working:)
i can share if it's not problem... _________________ Allow theex.nl Last edited by PickNick on Sat Nov 24, 2012 3:35 pm; edited 1 time in total |
Posted: Thu Nov 11, 2010 8:30 am Post subject:
i used eagle.
i can share if it's not problem... |
Wow, nice ! Thanks for sharing that layout and how convenient is that? Already an Eagle layout.
Bill |
inlifeindeath
Posted: Thu Nov 11, 2010 10:48 am Post subject:
State Machine wrote: | Quote: | Eagle and the small size board they allow you is making it almost impossible! |
Bill |
It's a combination of the size of the board and probably my inexperience with the program. i'm really not set up to do SMT or afford manufactured boards, but thank you so much for the offer and tips. Definately appreciated!
PickNick, you are the man! thank you so much! i'll have to post some pics and soundfiles when i get it all put together! I love EM! |
inlifeindeath
Posted: Thu Nov 11, 2010 10:50 am Post subject:
also, here is the modded version I was talking about. I believe the EP posts on this forum, and if he's reading this, I love your site and kind of want to live out in the wilderness like you! haha anyways here's the link
http://www.electronicpeasant.com/projects/bassbox/bassbox.html |
PickNick
Posted: Thu Nov 11, 2010 2:57 pm Post subject:
thank you guys!
i will post the details soon.
i made this layout in the board editor,
because i always have some problem with the autorouter...
after that i used Gimp for the makeup:)
there is 3 jumpers.
maybe there is some error in the names...
i will double check the file and upload
if it's not problem for Bill and Thomas.
i planning to make another version with sweep decay,
because i don't like so much the EG now.
i looking for some more controllable bass drum sound.
now i use XRVCO, Ian Fritz Dual AD/AR, MFOS VCA and Wasp filter
to create my funny HardBass Sound:)
sorry for my english...too much beer in the past:) _________________ Allow theex.nl |
inlifeindeath
Posted: Thu Nov 11, 2010 3:43 pm Post subject:
haha don't apologize for drinking beers! i'm having a few Guinness tonight as well.
PickNick, you are a gentleman and a scholar! Last edited by inlifeindeath on Fri Nov 12, 2010 10:41 am; edited 1 time in total |
PickNick
Posted: Thu Nov 11, 2010 5:54 pm Post subject:
hehh...
you are really fast!
there is some rules//not mine// in this forum if you post some layout.
like...you have to put Thomas Henry name to the board...etc
i will do this in Gimp soon...
uhh
i hope i'm better than google translate:) _________________ Allow theex.nl |
furio
PickNick
inlifeindeath
Posted: Tue May 03, 2011 6:37 am Post subject:
yeah, there's some mis-labeling. I just made sure to follow the schematic before i installed anything on the board. _________________ http://www.youtube.com/user/borisandfef |
Posted: Wed May 11, 2011 10:09 am Post subject:
If I may interject:
Quote: | Now I'm very curios to understand the C3-C6 function and location |
C3,4,5,6 are 0.01 uF ceramic disk bypass capacitors that mount close to the power pins of IC 1 and 2. They are not shown on the schematic but, instead, are included as a note in the original TH schematic. I don't see these capacitors on any of the layouts just to give a heads up
Bill |
inlifeindeath
Posted: Wed May 11, 2011 4:03 pm Post subject:
Easy to miss but we caught it before you committed
Have fun!
Bill |
PickNick
Posted: Sat May 14, 2011 7:34 pm Post subject:
Perfect !!!
Bill |
furio
Posted: Sun May 15, 2011 1:59 am Post subject:
State Machine wrote: | C3,4,5,6 are 0.01 uF ceramic disk bypass capacitors that mount close to the power pins of IC 1 and 2. They are not shown on the schematic but, instead, are included as a note in the original TH schematic. I don't see these capacitors on any of the layouts just to give a heads up |
thanx Bill, I have read some text's about the bypass capacitors, maybe understand a bit. I wanna try to build the last PickNick's PCB, and thank him for the new one, hopefully with the bypass caps the stability of the audio output level results improved |
Posted: Sun May 15, 2011 7:52 am Post subject:
Quote: | thanx Bill, I have read some text's about the bypass capacitors, maybe understand a bit. I wanna try to build the last PickNick's PCB, and thank him for the new one, hopefully with the bypass caps the stability of the audio output level results improved |
Your most welcome. They do make the world of difference. The general rule is one cap per supply pin on every IC in a design. Generally as close as practically possible. I usually use 0.1 uF capacitors on everything.
Also feedback capacitors in operational amplifier circuits help keep oscillations under control. They form low pass filters with the feedback resistor but you must make sure you calculate a value such that you pass your intended band of frequencies but cut off the unwanted ones.
Bill |
PickNick
paulstone
Posted: Sat Jun 22, 2013 2:41 pm Post subject:
PickNick wrote: | hi all!
i made a new documentation for the single-side Bass++.
you have to connect the A-A, B-B and D-D pads.
i left the C12 elko...you have to install between the Impact Tone-Impact Volume pots.
use the original and Electronic Peasant
schematic to find the right part values.
i hope the part names now are ok!
pls let me know if you find some error.
Peter |
Hi guys hi PickNick
thanks for your pcb layout i want try to build it , will work fine ?
which is the value of C18 ?
thanks |
PickNick
Posted: Sun Jun 23, 2013 2:03 am Post subject:
hi paulstone!
yes, it works.
C18=C12 2.2uF
pls follow the schematic! _________________ Allow theex.nl |
paulstone
Posted: Sun Jun 23, 2013 3:01 am Post subject:
PickNick wrote: | hi paulstone!
yes, it works.
C18=C12 2.2uF
pls follow the schematic! |
lol now i understood i've installed eagle free for print the schematic
in the first page of this thread
thank you for help .
ciao
paul |
paulstone
Posted: Mon Jun 24, 2013 11:42 am Post subject:
yes, it works.
C18=C12 2.2uF
Hi PickNick
sorry if disturb again
i realised that there is many errors between the schematic in the first post and your layout , so i'm much confused
please have you the schematic update of your layout to share ? .
if schematic update no exist , even the pcb top layout with cap and resistor value can help me a lot .
thank you in advanced |
